Re: Miller Time Intake [Re: WHITEDART] #2663506
06/07/19 01:41 PM
06/07/19 01:41 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Originally Posted by WHITEDART
[/quote] it's not going to make the exact same power as a sheet metal with two carburetors... however it's starting to get close.
Then you need a better sheet metal 2x4 smile
Re: Miller Time Intake [Re: Al_Alguire] #2663525
06/07/19 02:41 PM
06/07/19 02:41 PM
bean town ....Ca
W
WHITEDART Offline OP
W
bean town ....Ca
Then you need a better sheet metal 2x4 smile [/quote] . . How much weight does the sheet metal have to carry over a cast.. and I was referring to close as in the vicinity.. shruggy
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Miller Time Intake [Re: WHITEDART] #2663549
06/07/19 04:33 PM
06/07/19 04:33 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Sheet metal intakes where we run is a 5% penalty. That is 5% of the engine size in pounds. So for your car IF you ran NMCA rules it would be 22lbs I believe. Some of which would be the weight of the additional carb and lines, I'd bet the intakes are pretty close.
Now define what a "cast" intake is first smile
I could be wrong but under the NMCSA rules with your current combo you will be 2928lbs? Unless I missed something.
Re: Miller Time Intake [Re: WHITEDART] #2663611
06/07/19 08:02 PM
06/07/19 08:02 PM
bean town ....Ca
W
W
bean town ....Ca
11lb 11oz yup intake is . A couple pounds lighter drive
Re: Miller Time Intake [Re: WHITEDART] #2664317
06/10/19 10:04 AM
06/10/19 10:04 AM
an8sec70cuda Offline
That manifold looks awesome! And huge!
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Miller Time Intake [Re: Al_Alguire] #2664335
06/10/19 10:53 AM
06/10/19 10:53 AM
bean town ....Ca
W
W
bean town ....Ca
. 439 cubic inch base weight 2714 -50 lb for tier 2 body.. + 44 lb cat two head..2708.ish . Unless I read something wrong there used to be a weight deduct for two speed transmissions.. but I did not see it
Re: Miller Time Intake [Re: WHITEDART] #2664400
06/10/19 01:36 PM
06/10/19 01:36 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Yeah I must have had fat fingers on my phone calculator. If I even would have looked at that number a little closer I probably would have realized it was wrong smile Yep no more weight deduct for a glide, you get the honor of running the same weight with a glide or a clutch and 5 speed. Don't need to tell you which is faster smile I also forgot they did away with the penalty for the dry sump as well. 2708 is a bit lighter than we are but IMO puts you on the lighter end of things. If you were to build a smaller bullet you could get way down there with the two guys tearing it up this year. With their "3/4" chassis and clutches, one even has a 4 link, no penalty either. Things definitely need to be looked at and a decision made as to what direction we go. Seems they are leaning toward the "Jr Pro Stock" type car these days. Which I am sure is the direction it is headed.
Re: Miller Time Intake [Re: an8sec70cuda] #2664655
06/11/19 06:19 AM
06/11/19 06:19 AM
Mo.
racerx Offline
racerx  Offline
Mo.
iagree....and it's purity , it going to be interesting on the new combo.
