Re: Miller Time Intake
[Re: greendart408]
#2662766
06/05/19 06:39 PM
06/05/19 06:39 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Believe a full size spray can fits in the bottom .. Brett Miller really got after it.. this intake is going on the new motor. Which will be smaller in displacement and bigger everything else.. the other motor will stay together.. it has been a long journey Gathering parts and pieces for several years..
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: WHITEDART]
#2662775
06/05/19 06:55 PM
06/05/19 06:55 PM
Posts: 4,457 Washington
madscientist
Washington
This is going on a Ritter block isn't it????
[Re: WHITEDART]
#2662788
06/05/19 07:21 PM
06/05/19 07:21 PM
Posts: 11,719 Portage,michigan
B3422W5
Portage,michigan
No sir on a 9 inch deck R3... 3.79 crank?
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: B3422W5]
#2662795
06/05/19 07:42 PM
06/05/19 07:42 PM
WHITEDART
bean town ....Ca
No sir on a 9 inch deck R3... 3.79 crank? yes
[Re: WHITEDART]
#2662810
06/05/19 08:10 PM
06/05/19 08:10 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Is that a shear plate on top of the manifold?
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: Sammy]
#2662817
06/05/19 08:34 PM
06/05/19 08:34 PM
Posts: 19,375 Las Vegas
Al_Alguire
Las Vegas
I wonder if this intake would make as much power as a sheetmetal intake with 2 dominators? I'd like to try it out. I will tell you all rules comities that ponder these things would say NO. Most all carry weight for another carb and sheet metal intake. Now the definition of what constitutes a sheet metal intake, now there is a can of worms....
[Re: fast68plymouth]
#2662833
06/05/19 08:56 PM
06/05/19 08:56 PM
Posts: 1,893 Spahn Ranch
RMCHRGR
Spahn Ranch
Was it cut in half and welded back together? Bet the carb will weigh more than the intake.
'71 Duster '72 Challenger '17 Ram 1500
[Re: RMCHRGR]
#2662844
06/05/19 09:16 PM
06/05/19 09:16 PM
WHITEDART
bean town ....Ca
Was it cut in half and welded back together? Bet the carb will weigh more than the intake. . No this is the new casting that Brett Miller has design.. part number 420 .2.
[Re: Al_Alguire]
#2662846
06/05/19 09:20 PM
06/05/19 09:20 PM
WHITEDART
bean town ....Ca
I wonder if this intake would make as much power as a sheetmetal intake with 2 dominators? I'd like to try it out. I will tell you all rules comities that ponder these things would say NO. Most all carry weight for another carb and sheet metal intake. Now the definition of what constitutes a sheet metal intake, now there is a can of worms.... it's not going to make the exact same power as a sheet metal with two carburetors... however it's starting to get close.
