What is making guys not want to just use the factory injection systems
Cuz i have everything i need right now. Going that route is more money.
If there was a solution to make running fuel injection cheaper would people go for it?
Given that most junk yard engines come with intake manifold with injectors etc it doesnt take much to get them to run.
Going the carb route you have to buy the MSD ign kit, a carb intake and a carb. I presume to go out and buy that stuff would cost like $1000.
I had a comlete 6.4 crate engine and needed a way to run it.
I picked up a 6.4 engine and body harness, pedal, PCM on ebay for $120.
I have less than $100 of connectors, relays and terminals and a few hrs into modding the factory engine harness and making a compatible body harness to make the whole lot run standalone. Just need the PCM reflashed to run stand alone and will be all good to go for around the $300 mark.
A bit off topic but just putting it out there
