Help me hook, please!! #2661942
06/03/19 06:37 PM
06/03/19 06:37 PM
California
70Drop Online content OP
70Drop  Online Content OP
California
After a lot of time and money, my car 60-fts slower this year than last. Here is the basic info on the car:
    • Street/strip 70 Duster, has run 10.50's @ 128 mph, 1.55 60-fts.
    • 440/500 with ported Eddy heads and 260 degrees @ 0.050 solid roller. I shift at 5.8K rpm. Engine is very torquey
    • 727, 9.5” converter, flashes to 4500 rpm. I'm foot-braking the car
    • Steel body, 3300 lbs With me in it
    • Calvert mono leafs and shocks, Caltrac bars, 9x30 M/T ET Pro Drag radials
What's changed lately:
  • SS springs to current Mono-leafs
  • New Calvert rear shocks, set to 7 (used to be Comp Engineering)
  • Re-positioned leaf-spring perches (they broke). Pinion angle now 2-degrees down to driveshaft. It used to be a bit more than this
  • Bias-ply 10.5 x 30 changed to current 9x30 radials
I was out at the ANRA event over the weekend and got 60-fts anywhere from 1.9 to 1.58. The tires spun a lot. Even the 1.58 was spinning pretty good. The 1.58 came from 11 lbs In the tires. If I run more or less pressure it results in more spinning.
My pressures on the radials are below M/T's recommendations, but the low pressure is needed to prevent spinning. The tires also move an inch or two on the rims on each pass (even after gluing). Speculation is that the low pressures contribute to this
The 9-inch radials were recommended to me. My gut told me to go with 10.5” tires, but I was told the 9-inch tires should work fine
My 10.5” bias tires seemed less finicky and more consistent
Re: Help me hook, please!! [Re: 70Drop] #2661944
06/03/19 06:50 PM
06/03/19 06:50 PM
New York, USA
Chargerfan68 Offline
New York, USA
What mountiing hole are you using for front spring mount? Upper or lower? Are your bars close to parallel to ground?
Re: Help me hook, please!! [Re: Chargerfan68] #2661947
06/03/19 06:56 PM
06/03/19 06:56 PM
California
California
I'm using the lower hole. The bars are pretty close to parallel
Re: Help me hook, please!! [Re: 70Drop] #2661948
06/03/19 06:56 PM
06/03/19 06:56 PM
California
California
Parallel to the ground, I mean
Re: Help me hook, please!! [Re: 70Drop] #2661959
06/03/19 07:29 PM
06/03/19 07:29 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
I'm no expert by any means but 11lbs in a radial is almost half what everyone I know who uses radials run...and five lbs less than I used to run in bias plys of the same size.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: Help me hook, please!! [Re: A39Coronet] #2661960
06/03/19 07:32 PM
06/03/19 07:32 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Put the culverts in the top hole.
What gears do you have in the car?
Re: Help me hook, please!! [Re: Sammy] #2661963
06/03/19 07:41 PM
06/03/19 07:41 PM
California
California
Gears are 4.10
If I put even 15 lbs in the tires, they spin like crazy. There's definitely something wrong. Somehow I don't think the tires are being loaded the way they should.
Re: Help me hook, please!! [Re: Sammy] #2661966
06/03/19 07:45 PM
06/03/19 07:45 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Yep, go to top hole, put 18 lb in the rears and then study how much rear lift (separation) your getting on the launch. I had the same set up with the Comp shocks, changed to Vikings and picked up .15, my 3750lb now goes low 1.4"s
1963 Plymouth Max Wedge
1971 Barracuda
Re: Help me hook, please!! [Re: ozymaxwedge] #2661976
06/03/19 08:15 PM
06/03/19 08:15 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Tighten up your rear shocks all the way.
You will be a happy camper.
Re: Help me hook, please!! [Re: Sammy] #2661984
06/03/19 08:23 PM
06/03/19 08:23 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
What he said and also put 20psi in those 30x9 radials and do very little burnout, just knock the dust and rocks off of them.
Re: Help me hook, please!! [Re: nss guy] #2662023
06/03/19 09:45 PM
06/03/19 09:45 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
DA's? Tighten the extension, not the compression. I would imagine severe separation in the back OR the front is allowing zero transfer. Torsion bars work really well because you're basically winding up a rubber band and storing energy that can do nothing but transfer all it's energy up when the car hits helping transfer to the rear. The bigger the bar, the less energy it will have without the ride being sky high. Some of the best transferring stockers I see are kind of ugly because the ride is so high. Check out Steve and Lisa Caldwell's stuff. HERE It ain't ugly and her wheelie bars are only there to save the chrome on the bumper.
OR put the M/T's back until you figure it out. From what I hear a lot around here is that once you figure out the E/T streets, the radials will make you faster.
Re: Help me hook, please!! [Re: Dave Hall] #2662029
06/03/19 09:55 PM
06/03/19 09:55 PM
California
California
That Caldwell car is wild!
The shocks are single-adjustable Calverts. I don't know if they adjust the compression or the extension.
Re: Help me hook, please!! [Re: 70Drop] #2662044
06/03/19 10:22 PM
06/03/19 10:22 PM
New York, USA
New York, USA
Also, another thing to check is how much front travel you have. The calverts work best with at least 4” +.
Re: Help me hook, please!! [Re: 70Drop] #2662058
06/03/19 11:12 PM
06/03/19 11:12 PM
Cab_Burge Online work
Cab_Burge  Online Work
What size and type M/T radials are you using now? what width wheels also?
I ran the M/T 315x60x15 ET Street Radials on my old pump gas Duster on both 10 inch and 12 inch wide rims, those tires worked great on a good track, not worth a hoot on the street or on a mediocre track up I ran from 18.0 to 22.5 lbs. in them.
I also had a set of M/T ET Street bias plys of the same size, width and circumference on similar rims, they worked a bunch better on bad tracks and on the street up I ran from 9.0 to 12.0 lbs. on them, the best 60 Ft was 1.42 on the radials and around 1.47 on the bias plys shruggy
That car weighed 3450 lbs with me in it and the best ET and MPH was 9.993 at 134.7 MPH at Woodburn dragstrip in late August or mid September, CRS disease now whiney
That car had a 518 C.I. pump gas 400 block stroker motor with a set of Indy SR M.W. heads, Indy 400-3 intake with a Holley 1050 CFM Dominator carb, MSD 7 ignition, 727 with a Mopar helical cut 2.77 low gear set, T/A 069J 4200 SS Hemi converter and 4.10 Dana 60 on ladder bars with double adjustable Strange coil over with 15 inches extended length and right at 7.0 inches of travel, I used a set of 150 Lb. rated coil overs on them also up
That car would hook in a mud puddle in the middle of a rain storm grin whistling devil up work
Re: Help me hook, please!! [Re: Cab_Burge] #2662067
06/04/19 12:11 AM
06/04/19 12:11 AM
California
California
Thanks, Cab. The tires are ET Pro Drag radials, 9x30". The rims are 10"
Re: Help me hook, please!! [Re: 70Drop] #2662077
06/04/19 02:14 AM
06/04/19 02:14 AM
ma.
duspan Offline
duspan  Offline
ma.
how much preload would you use for the bars?
Re: Help me hook, please!! [Re: 70Drop] #2662124
06/04/19 08:25 AM
06/04/19 08:25 AM
Indy
FlyFish Offline
FlyFish  Offline
Indy
My Barracuda works best with my Caltracs set like this (all adjustments were made on a flat level surface):
Bottom hole, 1 flat preload driver side, 2 flats preload passenger side.
Rear shocks set on 6.
I also used Calverts front shocks (90/10). This combo gives a nice level launch and hooks well with my Hoosier drag radials set at 18 psi. 11 is really too low for the tire to work properly.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: Help me hook, please!! [Re: FlyFish] #2662134
06/04/19 08:46 AM
06/04/19 08:46 AM
an8sec70cuda Offline
The car will be quicker w/ more air pressure and tightening up the rear shocks. I'd try around 17 psi to start and go up from there. I run 20 psi, but you may not need that much.
My car always ran good w/ the rear shocks set on 9, full stiff (Rancho 9 ways). I use the bottom hole w/ no preload.
What front shock is on the car???????
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Help me hook, please!! [Re: an8sec70cuda] #2662182
06/04/19 10:45 AM
06/04/19 10:45 AM
California
California
The front shocks are Competion Engineering 90-10. My friend thought the front end felt stiff, so I removed the shocks for my last two runs of the day. That seemed to help a bit. I think I'll try different shocks.
Re: Help me hook, please!! [Re: 70Drop] #2662183
06/04/19 10:54 AM
06/04/19 10:54 AM
I'd suggest some Vikings for the front. All Viking shocks are double adjustable.
It's real easy to get some that are too loose or too stiff. Get some adjustables so you can find what your car needs.
The Calvert 90/10s are loose as hell and my car refused to hook w/ them. The Comp Engineering shocks are stiff and I've never cared for them. The Lakewood 90/10s worked better for me.
Like I said though, I run the Vikings now and love them. They are pretty cheap too...for a DA shock.
CHIP
