Help me hook, please!!
#2661942
06/03/19 06:37 PM
06/03/19 06:37 PM
Posts: 223 California
70Drop
California
After a lot of time and money, my car 60-fts slower this year than last. Here is the basic info on the car: - Street/strip 70 Duster, has run 10.50's @ 128 mph, 1.55 60-fts.
- 440/500 with ported Eddy heads and 260 degrees @ 0.050 solid roller. I shift at 5.8K rpm. Engine is very torquey
- 727, 9.5” converter, flashes to 4500 rpm. I'm foot-braking the car
- Steel body, 3300 lbs With me in it
- Calvert mono leafs and shocks, Caltrac bars, 9x30 M/T ET Pro Drag radials
What's changed lately: - SS springs to current Mono-leafs
- New Calvert rear shocks, set to 7 (used to be Comp Engineering)
- Re-positioned leaf-spring perches (they broke). Pinion angle now 2-degrees down to driveshaft. It used to be a bit more than this
- Bias-ply 10.5 x 30 changed to current 9x30 radials
I was out at the ANRA event over the weekend and got 60-fts anywhere from 1.9 to 1.58. The tires spun a lot. Even the 1.58 was spinning pretty good. The 1.58 came from 11 lbs In the tires. If I run more or less pressure it results in more spinning. My pressures on the radials are below M/T's recommendations, but the low pressure is needed to prevent spinning. The tires also move an inch or two on the rims on each pass (even after gluing). Speculation is that the low pressures contribute to this The 9-inch radials were recommended to me. My gut told me to go with 10.5” tires, but I was told the 9-inch tires should work fine My 10.5” bias tires seemed less finicky and more consistent
Re: Help me hook, please!!
[Re: 70Drop]
#2661944
06/03/19 06:50 PM
06/03/19 06:50 PM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
What mountiing hole are you using for front spring mount? Upper or lower? Are your bars close to parallel to ground?
[Re: Sammy]
#2661963
06/03/19 07:41 PM
06/03/19 07:41 PM
70Drop
California
Gears are 4.10
If I put even 15 lbs in the tires, they spin like crazy. There's definitely something wrong. Somehow I don't think the tires are being loaded the way they should.
[Re: Sammy]
#2661966
06/03/19 07:45 PM
06/03/19 07:45 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
Yep, go to top hole, put 18 lb in the rears and then study how much rear lift (separation) your getting on the launch. I had the same set up with the Comp shocks, changed to Vikings and picked up .15, my 3750lb now goes low 1.4"s
1963 Plymouth Max Wedge 1971 Barracuda
[Re: Sammy]
#2661984
06/03/19 08:23 PM
06/03/19 08:23 PM
Posts: 1,443 central ohio
nss guy
central ohio
Tighten up your rear shocks all the way. You will be a happy camper. What he said and also put 20psi in those 30x9 radials and do very little burnout, just knock the dust and rocks off of them.
[Re: nss guy]
#2662023
06/03/19 09:45 PM
06/03/19 09:45 PM
Posts: 2,363 Cotati, CA
Dave Hall
Cotati, CA
Tighten up your rear shocks all the way. You will be a happy camper. DA's? Tighten the extension, not the compression. I would imagine severe separation in the back OR the front is allowing zero transfer. Torsion bars work really well because you're basically winding up a rubber band and storing energy that can do nothing but transfer all it's energy up when the car hits helping transfer to the rear. The bigger the bar, the less energy it will have without the ride being sky high. Some of the best transferring stockers I see are kind of ugly because the ride is so high. Check out Steve and Lisa Caldwell's stuff. HERE It ain't ugly and her wheelie bars are only there to save the chrome on the bumper. What he said and also put 20psi in those 30x9 radials and do very little burnout, just knock the dust and rocks off of them. OR put the M/T's back until you figure it out. From what I hear a lot around here is that once you figure out the E/T streets, the radials will make you faster.
[Re: 70Drop]
#2662044
06/03/19 10:22 PM
06/03/19 10:22 PM
Chargerfan68
New York, USA
Also, another thing to check is how much front travel you have. The calverts work best with at least 4” +.
[Re: 70Drop]
#2662058
06/03/19 11:12 PM
06/03/19 11:12 PM
Posts: 43,303 Bend,OR USA
Cab_Burge
What size and type M/T radials are you using now? what width wheels also? I ran the M/T 315x60x15 ET Street Radials on my old pump gas Duster on both 10 inch and 12 inch wide rims, those tires worked great on a good track, not worth a hoot on the street or on a mediocre track ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) I ran from 18.0 to 22.5 lbs. in them. I also had a set of M/T ET Street bias plys of the same size, width and circumference on similar rims, they worked a bunch better on bad tracks and on the street ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) I ran from 9.0 to 12.0 lbs. on them, the best 60 Ft was 1.42 on the radials and around 1.47 on the bias plys ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) That car weighed 3450 lbs with me in it and the best ET and MPH was 9.993 at 134.7 MPH at Woodburn dragstrip in late August or mid September, CRS disease now ![whiney whiney](/ubbthreads/images/graemlins/custom/whiney.gif) That car had a 518 C.I. pump gas 400 block stroker motor with a set of Indy SR M.W. heads, Indy 400-3 intake with a Holley 1050 CFM Dominator carb, MSD 7 ignition, 727 with a Mopar helical cut 2.77 low gear set, T/A 069J 4200 SS Hemi converter and 4.10 Dana 60 on ladder bars with double adjustable Strange coil over with 15 inches extended length and right at 7.0 inches of travel, I used a set of 150 Lb. rated coil overs on them also ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) That car would hook in a mud puddle in the middle of a rain storm ![work work](/ubbthreads/images/graemlins/custom/work.gif)
[Re: Cab_Burge]
#2662067
06/04/19 12:11 AM
06/04/19 12:11 AM
70Drop
California
What size and type M/T radials are you using now? what width wheels also? I ran the M/T 315x60x15 ET Street Radials on my old pump gas Duster on both 10 inch and 12 inch wide rims, those tires worked great on a good track, not worth a hoot on the street or on a mediocre track ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) I ran from 18.0 to 22.5 lbs. in them. I also had a set of M/T ET Street bias plys of the same size, width and circumference on similar rims, they worked a bunch better on bad tracks and on the street ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) I ran from 9.0 to 12.0 lbs. on them, the best 60 Ft was 1.42 on the radials and around 1.47 on the bias plys ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) That car weighed 3450 lbs with me in it and the best ET and MPH was 9.993 at 134.7 MPH at Woodburn dragstrip in late August or mid September, CRS disease now ![whiney whiney](/ubbthreads/images/graemlins/custom/whiney.gif) That car had a 518 C.I. pump gas 400 block stroker motor with a set of Indy SR M.W. heads, Indy 400-3 intake with a Holley 1050 CFM Dominator carb, MSD 7 ignition, 727 with a Mopar helical cut 2.77 low gear set, T/A 069J 4200 SS Hemi converter and 4.10 Dana 60 on ladder bars with double adjustable Strange coil over with 15 inches extended length and right at 7.0 inches of travel, I used a set of 150 Lb. rated coil overs on them also ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) That car would hook in a mud puddle in the middle of a rain storm Thanks, Cab. The tires are ET Pro Drag radials, 9x30". The rims are 10"
[Re: 70Drop]
#2662124
06/04/19 08:25 AM
06/04/19 08:25 AM
Posts: 1,178 Indy
FlyFish
Indy
My Barracuda works best with my Caltracs set like this (all adjustments were made on a flat level surface):
Bottom hole, 1 flat preload driver side, 2 flats preload passenger side. Rear shocks set on 6.
I also used Calverts front shocks (90/10). This combo gives a nice level launch and hooks well with my Hoosier drag radials set at 18 psi. 11 is really too low for the tire to work properly.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
[Re: FlyFish]
#2662134
06/04/19 08:46 AM
06/04/19 08:46 AM
Posts: 13,400 Marion, South Carolina [><]
an8sec70cuda
The car will be quicker w/ more air pressure and tightening up the rear shocks. I'd try around 17 psi to start and go up from there. I run 20 psi, but you may not need that much. My car always ran good w/ the rear shocks set on 9, full stiff (Rancho 9 ways). I use the bottom hole w/ no preload.
What front shock is on the car???????
[Re: 70Drop]
#2662183
06/04/19 10:54 AM
06/04/19 10:54 AM
an8sec70cuda
I'd suggest some Vikings for the front. All Viking shocks are double adjustable. It's real easy to get some that are too loose or too stiff. Get some adjustables so you can find what your car needs.
The Calvert 90/10s are loose as hell and my car refused to hook w/ them. The Comp Engineering shocks are stiff and I've never cared for them. The Lakewood 90/10s worked better for me. Like I said though, I run the Vikings now and love them. They are pretty cheap too...for a DA shock.
