Re: Who makes the best race battery
[Re: Supersonic]
#266210
03/25/09 05:15 PM
03/25/09 05:15 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
I had a Sears Marine battery that last 7 years in the race-car. But if you want the most Powerful battery you can get its the 16 volt Rock battery. I have not had it a year yet but its night and day better than my 16 volt Turbo Start battery.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: MRMOPAR622]
#266211
03/25/09 05:37 PM
03/25/09 05:37 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
can you use the turbo start 16v agm charger with the rock batt.?
[Re: Supersonic]
#266212
03/25/09 05:43 PM
03/25/09 05:43 PM
Posts: 8,029 Tulsa OK
Bad340fish
Tulsa OK
If your red top is only 2.5 years old its still under free replacement warranty.
68 Barracuda Formula S 340
[Re: WILD BILL]
#266214
03/25/09 07:59 PM
03/25/09 07:59 PM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
I don't like optima's either. I run 2 interstate lead/acid batteries and have had good luck with them.
[Re: Bigcube]
#266215
03/25/09 08:36 PM
03/25/09 08:36 PM
Posts: 1,855 Staten Island N.Y.
Dap
Staten Island N.Y.
The two Optima yellow tops I bought 6 years ago are still doing the job. The Red top I bought 2 years ago is junk. I had it replaced 1 month after I bought it and not this one is garbage. I think I`ll try a Deka intimidator next.
PRH446 10.084 @ 135.21 mph N/A through chambered mufflers,3300lbs. Stock stroke wedge
[Re: rickstershemi]
#266218
03/25/09 10:06 PM
03/25/09 10:06 PM
KOS
IMHO....Odyssey hands down I run (ONE) PC-1200 weighs like 38# and it's a dry cell, I run the full gambit of electronics and no alternator, have round robin'd and has never failed me....it's on it's fifth year
Rickster
i agree.....had a PC 1700 over 6yrs of use several different vehicles never needed a boost and is still cranking in the car i sold it in
[Re: wyoming]
#266220
03/26/09 08:26 AM
03/26/09 08:26 AM
MRMOPAR622
Sweet Home Alabama
bonefish, That is what I am using the AGM Turbo Start charger. I called Rock batteries and they said it would work just fine and it does. If I can ever get the spare money I will get a Rock charger because it is much better. I don't sell any batteries just trying to help my fellow racers on here who have HELPED me many times. With the 16 volt Tubro Start I could not tell any difference than with the 12 volt Sears Marine battery. With the Rock battery it turns the engine about 2 times as fast as the other two.
[Re: MRMOPAR622]
#266221
03/26/09 08:33 AM
03/26/09 08:33 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
i ran 2 turbo starts for 3 years and now have 2 big marine 12vlt and i hate it ,once you get used to the 16vlt system going back to the 12vlt is like going from a big block to a small block(oop, i shouldnt have said that).but right now i just didnt want to spend 500.00 bucks on batts.mabey ill try just one 16vlt.
[Re: Bad340fish]
#266223
03/26/09 08:32 PM
03/26/09 08:32 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
So what your saying is your car is faster with the 12 volts?
i knew that was commin.
