advance spring kit?
#2661962
06/03/19 07:41 PM
06/03/19 07:41 PM
Posts: 2,863 middle Tennessee
mopower440
middle Tennessee
does anyone have a part number for an assorted distributor advance spring kit that can be found at oreillys or any of the local parts houses? I had one with several springs in it and cant find it. Can we use the spring kits for GM HEI distributors or are they different springs? Im asking because i can find those everywhere but only one mopar kit that only has 2 springs in it..
Re: advance spring kit?
[Re: mopower440]
#2662041
06/03/19 10:14 PM
06/03/19 10:14 PM
RapidRobert
I dont have a part # but you can mix/match any combo of springs that will put you just under the pinging point at WOT up thru the gears on your hottest/driest day AFTER you have first (1) set the initial & (2) the total (initial+mech amt & can not plugged in).
[Re: mopars4ever]
#2662165
06/04/19 10:06 AM
06/04/19 10:06 AM
mopower440
middle Tennessee
Mopar part 2932675 for the lightweight springs. The MR gasket kit 925B shows as a mopar kit not GM Releases hidden horsepower and boosts throttle response Optimizes ignition timing Designed specifically for 6 and 8 cylinder Chryslers Ensures full mechanical advance between 2000 and 2800 RPM Comes complete with easy to follow instructions for a hassle free installation The 925 B only has 2 springs and im wanting more of an assortment to get this thing dialed in..
[Re: mopars4ever]
#2662450
06/05/19 12:05 AM
06/05/19 12:05 AM
RapidRobert
some more info tho the Crane kit is no longer available I believe.
[Re: RapidRobert]
#2662505
06/05/19 08:24 AM
06/05/19 08:24 AM
Posts: 531 Charlotte, NC
Kowal
Charlotte, NC
Summit Racing has their own spring kit for Mopar distributors that works fine, I have used several.
Also, if you want to shorten the advance, I highly recommend the FBO advance limiter plate, works well and way easier than welding.
'69 Hemi Charger 500, ‘70 U code Challenger R/T (These and a bunch others at www.dkowal426.com) P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
[Re: Kowal]
#2662555
06/05/19 10:17 AM
06/05/19 10:17 AM
mopower440
middle Tennessee
Also, if you want to shorten the advance, I highly recommend the FBO advance limiter plate, works well and way easier than welding. Ya, I got the FBO plate but I think I need to stiffen up the curve as its advancing a little too quickly causing ping .
[Re: mopower440]
#2662646
06/05/19 01:08 PM
06/05/19 01:08 PM
RapidRobert
I think I need to stiffen up the curve as its advancing a little too quickly causing ping . part throttle or WOT?
[Re: RapidRobert]
#2662663
06/05/19 02:25 PM
06/05/19 02:25 PM
mopower440
middle Tennessee
I think I need to stiffen up the curve as its advancing a little too quickly causing ping . part throttle or WOT? Doesn't ping at part throttle at all, only when stabbing the secondarys open, then it pings. If I EASE into the secondarys, it doesn't ping..but tromp the pedal to the floor quick, she pings!
[Re: mopower440]
#2662737
06/05/19 05:13 PM
06/05/19 05:13 PM
Kowal
Charlotte, NC
I think I need to stiffen up the curve as its advancing a little too quickly causing ping . part throttle or WOT? Doesn't ping at part throttle at all, only when stabbing the secondarys open, then it pings. If I EASE into the secondarys, it doesn't ping..but tromp the pedal to the floor quick, she pings! My 440 was very similar. (slight cam, 9 something compression, Edelbrock 800 AVS). I pinged slightly at WOT in second gear only (4 speed). I played with the jets/rods, and this was as good as I got. So backed timing to 15 at idle and 33 total mechanical, that was just below the threshold that it would ping or not (on a very hot day). Used the Summit springs (they give you three sets to try), which had mechanical all in at about 2150 rpm. Runs great now, lost a little bit of “pull” at WOT versus running at 34 to 36 full mechanical advance but it is a street only car and it really runs across all scenarios (idle, part throttle, WOT) well. Note...I am running the ported vacuum advance, it did help part throttle responsiveness. Meaning behind the story, as everyone is saying you need to just keep playing with it. Remember there is a lot of tolerance stack-ups on an engine and through the distributor, so each engine is different. Plus today’s gas does mean everything isn’t quite the same as the stories from how to set up years ago.
