Transmission yoke to bushing clearance ?? #2661957
06/03/19 07:24 PM
06/03/19 07:24 PM
Omaha Ne
TJP Offline OP
TJP  Offline OP
Omaha Ne
68 Road runner with an 833 4 spd
Does anyone have a tolerance for how much clearance is allowable between the trans yoke and output bushing??
I am assuming this would be measured as close to the housing as possible.
Next silly question, any chance of replacing the bushing without pulling the the trans and dismantling the output assembly ??
TJP
Re: Transmission yoke to bushing clearance ?? [Re: TJP] #2661969
06/03/19 08:03 PM
06/03/19 08:03 PM
A727Tflite Offline
A727Tflite  Offline
Google it and several sources are selling the original Miller Special Tool for removing this bushing, several bushing installers are available too.
Don’t worry about the clearance as long as you don’t have a worn slip yolk.
Never seen an undersized new bushing yet. In our Reman process we gauge this bushing and only about 1% of the used ones are oversized.
Re: Transmission yoke to bushing clearance ?? [Re: TJP] #2661977
06/03/19 08:15 PM
06/03/19 08:15 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
IMO, its just as easy to pull the tail shaft hsg and drive the bushing out and new one in.
Re: Transmission yoke to bushing clearance ?? [Re: A727Tflite] #2661978
06/03/19 08:18 PM
06/03/19 08:18 PM
Omaha Ne
TJP Offline OP
TJP  Offline OP
Omaha Ne
The car has a random noise that is hard to duplicate and describe. one would almost think the cluster gear is slopping back and forth. Is it only moticeble al low speeds under a light to no load condition
The drive shaft appears a bit short and there seems to be an excess amount of slop between the yoke and bushing. When taking up the clearance both directions (up and down or side to side) the noise it makes sounds a lot like the random noise being experienced.
Possibly a longer shaft or yoke may all that is needed but trying to get the info before pulling the shaft tomorrow. Do you happen to have a part # or source for those Miller tools ??
Thanks a bunch beer
Re: Transmission yoke to bushing clearance ?? [Re: gtx6970] #2661981
06/03/19 08:20 PM
06/03/19 08:20 PM
Omaha Ne
TJP Offline OP
TJP  Offline OP
Omaha Ne
on a 4 SPD. ???
Re: Transmission yoke to bushing clearance ?? [Re: TJP] #2661983
06/03/19 08:22 PM
06/03/19 08:22 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
on a 4 SPD. ???
Opps missed that part.
Never replace one in a manual.
But then , how hard is it to get the tail shaft off ?
I can have the corssmember out and tail shaft hsg off the auto in under an hour
Re: Transmission yoke to bushing clearance ?? [Re: TJP] #2662045
06/03/19 10:23 PM
06/03/19 10:23 PM
A727Tflite Offline
A727Tflite  Offline
Thanks a bunch beer
In a pinch you can use an old yolk by finding a few washers that slide on the yolk up against the radius then driving in the bushing. Just line the bushing up and start slowly.
I forgot to mention you will have to knock the soft cap out of the back of the standard yolk so it will allow the output shaft to travel through the yolk to get the bushing all the way in to the support.
Here are a few pics.
Remover is Miller 6957. Installer is 6951.
234DCBE4-5FFC-4BB4-8130-AB37CA949965.jpegB94DCF97-3ADF-4C15-80E5-BFBF17B794CA.jpegDBD8812C-2659-4166-8B81-901D9EE5EA86.jpeg
Re: Transmission yoke to bushing clearance ?? [Re: A727Tflite] #2662110
06/04/19 07:25 AM
06/04/19 07:25 AM
VA
dragon slayer Offline
VA
I am not sure how a longer drive shaft, or yoke resolves this if your talking about excess clearance in the bearing? Or other noise types coming from transmission. Are the universal joints ok? If you have a lift, might be worth dropping transmission and inspecting.
Re: Transmission yoke to bushing clearance ?? [Re: dragon slayer] #2662190
06/04/19 11:14 AM
06/04/19 11:14 AM
Omaha Ne
TJP Offline OP
TJP  Offline OP
Omaha Ne
The clearance measured at the transmission seal / boot is .035 to .040" measured with a dial indicator
The drive shaft could be about 1" longer while still leaving 1" of travel.
However the yoke appears fine and pushing it in the additional 1" has little to no effect on the clearance. So am I chasing a ghost or is the output bushing toast??
confused beer
Re: Transmission yoke to bushing clearance ?? [Re: TJP] #2662272
06/04/19 02:21 PM
06/04/19 02:21 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
confused beer
John Kunkle (spelling) on this board posted the specs on both the yoke, and the bushing, it was pretty tight if I recall .002-.003 clearance, the problem is aftermarket bushings are bigger, aftermarket yokes are smaller so it can be hard to fix. I have had to resort to having yokes hard chromed to tighten it up. Last one I did with bushing from brewer and a neapco yoke moves a lot, way more than an untouched original. I tell guys not to change the output bushing if it is still good, I believe originals were machined in the housing.
Re: Transmission yoke to bushing clearance ?? [Re: 4406bbl] #2662424
06/04/19 10:43 PM
06/04/19 10:43 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
The local driveline shop suggests bottoming the yolk then pulling it back out 3/4 of an inch to get the driveshaft measurement...
Re: Transmission yoke to bushing clearance ?? [Re: screamindriver] #2662512
06/05/19 08:35 AM
06/05/19 08:35 AM
nowhere
Sniper Online content
Sniper  Online Content
nowhere
Why?
Wouldn't it be easier to just bottom the yoke, measure the center to center and subtract?
Re: Transmission yoke to bushing clearance ?? [Re: TJP] #2662556
06/05/19 10:24 AM
06/05/19 10:24 AM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Check out my posting from a few months ago. Not your problem as described, but bushing/yoke clearance discussion relevant. Of particular interest is the copy and paste discussion created by a friend.
https://board.moparts.org/ubbthread...ing-driveline-vibration.html#Post2653208
Re: Transmission yoke to bushing clearance ?? [Re: Sxrxrnr] #2662606
06/05/19 11:50 AM
06/05/19 11:50 AM
Omaha Ne
TJP Offline OP
TJP  Offline OP
Omaha Ne
Thanks to all for the replies. Due to the limited use the car sees, the owner has decided to live with it for the time being rolleyes beer
Re: Transmission yoke to bushing clearance ?? [Re: Sniper] #2662874
06/05/19 10:57 PM
06/05/19 10:57 PM
Harrisburg, Pa.
Harrisburg, Pa.
Why?
If the driveshaft was in a straight line you could do that...But with any combination of driveline angles for a given vehicle just pulling it out 3/4 from bottom wouldn't give a true reading for driveshaft endplay..
