Made some main caps #2661656
06/02/19 09:24 PM
06/02/19 09:24 PM
Milwaukee WI
TRENDZ Offline OP
TRENDZ  Offline OP
Milwaukee WI
Im “in process” of building a blown early hemi. I made some main caps for myself after seeing what is available for sale out there. Mine tie into the pan rail meat a whole lot more than any I’ve seen. This will necessitate the need for notches/ bulges in the pan, but that is easy enough to deal with.
Re: Made some main caps [Re: TRENDZ] #2661663
06/02/19 10:03 PM
06/02/19 10:03 PM
michigan
6pakdakota Offline
6pakdakota  Offline
michigan
They look great.
Re: Made some main caps [Re: 6pakdakota] #2661678
06/02/19 10:42 PM
06/02/19 10:42 PM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
Yes...very nice. I was really hoping that guy re-doing the 392 blocks back in 2015 would have had his $hit together by now...I wanted to do a Nostalgia build, but blocks are few and far between....We have a number of them down at the shop, but each has its own set of issues when you get going on one.
Re: Made some main caps [Re: TRENDZ] #2661709
06/03/19 12:38 AM
06/03/19 12:38 AM
Is this block a 392 or a 354 block?
back in the day I use to fool around with some of the early Chrysler Fire power motors, 1955 331 C.I., 1957 and 1958 392 C.I. motors.
Many SO CA N/A racers suggested using the 354 motors instead of the 392 due to early heads where better on the intake angle and lifter angles work They would increase the stroke to make them bigger.
If yours is a 392 block is it a regular, RR or A-1 casting? The A1 was the preferred 392 block due to having the thicker full main webbing instead of the weaker blocks with the lighting done between the main webbing and cylinder walls work scope
Re: Made some main caps [Re: Cab_Burge] #2661721
06/03/19 04:14 AM
06/03/19 04:14 AM
Milwaukee WI
TRENDZ Offline OP
TRENDZ  Offline OP
Milwaukee WI
This is a 331 industrial engine. I sort of fell into this by accident. I was given a 241 hemi when a friend died. It was a basket case. Lots of cool old parts. In the time I spent trying to find the parts I needed/ wanted, I realized that some people in the early dodge hemi world are easily threatened when an outsider wants certain parts. Anyway, after searching local craigslist for parts for that engine, I came across this 331. Complete minus intake for $700. I searched the internet for parts for the 331, and quickly learned that the Chrysler hemi is supported by a whole slew of companies. I can get a new roller cam from damn near any cam company. The price and support made it much easier to go this route. Honestly never knew much about these engines, but they are growing on me.
Re: Made some main caps [Re: TRENDZ] #2661735
06/03/19 07:06 AM
06/03/19 07:06 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
It might take a tad more than a bulge on the pan rail , but I really like where you are going with this.
I had three of these years back and each had a spun rod bearing.
The word round the camp fire was soft crank shafts , but it could have easily been an oiling problem that led to it.
But they seem to be coming back with the street rod guys in a big way.
Re: Made some main caps [Re: TRENDZ] #2661789
06/03/19 10:52 AM
06/03/19 10:52 AM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
WOW!!! Well done!!!
Re: Made some main caps [Re: ccdave] #2661796
06/03/19 11:03 AM
06/03/19 11:03 AM
moparx Online content
moparx  Online Content
VERY nice machine work ! up what grade material ?
beer
Re: Made some main caps [Re: moparx] #2661807
06/03/19 11:23 AM
06/03/19 11:23 AM
Milwaukee WI
TRENDZ Offline OP
TRENDZ  Offline OP
Milwaukee WI
4140 alloy steel. Done on my manual mill in the garage. Im pretty pleased with how it turned out.
Re: Made some main caps [Re: TRENDZ] #2661864
06/03/19 01:34 PM
06/03/19 01:34 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Awesome work! boogie
Re: Made some main caps [Re: moparx] #2661866
06/03/19 01:42 PM
06/03/19 01:42 PM
an8sec70cuda Offline
beer
iagree I'd love to be able to just make something like that for myself!
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Made some main caps [Re: slantzilla] #2661867
06/03/19 01:44 PM
06/03/19 01:44 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Very pretty looking work! They appear very robust for sure.
Rich H.
Esse Quam Videri
Re: Made some main caps [Re: TRENDZ] #2661872
06/03/19 01:48 PM
06/03/19 01:48 PM
I think that type later 331 C.I. block was used by Chrysler and Dodge from 1954 to 1958 in passenger cars, H.D. trucks, boats and industrial applications confused It should be a good block up
Re: Made some main caps [Re: slantzilla] #2661873
06/03/19 01:48 PM
06/03/19 01:48 PM
in the middle
dodger mope Offline
dodger mope  Offline
in the middle
i got to ask---how many hours? nice work
Re: Made some main caps [Re: dodger mope] #2661883
06/03/19 02:15 PM
06/03/19 02:15 PM
Milwaukee WI
TRENDZ Offline OP
TRENDZ  Offline OP
Milwaukee WI
I didn’t keep track of time, but it was 3 weekends of “hobby time”
It took longer than I thought it would. The caps weren’t the hard part.
Getting the block ready was tricky, because my mill is worn some. The elevation of the table changes at the ends of the travel distance needed. It was difficult, but all the saddles are the same depth from the pan rail now. That made making the caps much easier. The block started out with one side at .124” and the other at .126” that would have made the cap plane surfaces tipped. Fixturing would have been difficult.
Re: Made some main caps [Re: TRENDZ] #2661920
06/03/19 05:13 PM
06/03/19 05:13 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
This raises the bar a tad. lol
The thing I admire most about this is that this is exactly how it was done by the pioneers of the sport.
If they wanted something , they made it.
And the biggest expense of " unobtanium " parts was the tooling and ability to make it happen.
It is far rarer to see this today , as opposed to people opening their check book and having things made for them.
And I don't have a problem with either.
But the skill and determination that goes into making your own parts sets your build apart from the way it happens for most of us.
Re: Made some main caps [Re: tubtar] #2661992
06/03/19 08:44 PM
06/03/19 08:44 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Only problem I find with them is,,,they are going to be hidden in a oil pan and no one will get to admire them,,,nice impressive work. bow
Re: Made some main caps [Re: TRENDZ] #2662267
06/04/19 02:05 PM
06/04/19 02:05 PM
did you heat treat after machining ?
beer
Re: Made some main caps [Re: moparx] #2662280
06/04/19 03:06 PM
06/04/19 03:06 PM
Milwaukee WI
TRENDZ Offline OP
TRENDZ  Offline OP
Milwaukee WI
No heat treat. Was told 4140 in stress relieved state closely mimics elongation of cast iron. Im no metallurgist but that sounded good to me!
Should I be concerned?
Re: Made some main caps [Re: TRENDZ] #2662364
06/04/19 08:26 PM
06/04/19 08:26 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
unless done in a controlled environment 4140 will move around during the treatment process and probably shrink, bend and/or twist a little.
