Made some main caps
#2661656
06/02/19 09:24 PM
06/02/19 09:24 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Im “in process” of building a blown early hemi. I made some main caps for myself after seeing what is available for sale out there. Mine tie into the pan rail meat a whole lot more than any I’ve seen. This will necessitate the need for notches/ bulges in the pan, but that is easy enough to deal with.
Re: Made some main caps
[Re: TRENDZ]
#2661709
06/03/19 12:38 AM
06/03/19 12:38 AM
Posts: 43,124 Bend,OR USA
Cab_Burge
Is this block a 392 or a 354 block? back in the day I use to fool around with some of the early Chrysler Fire power motors, 1955 331 C.I., 1957 and 1958 392 C.I. motors. Many SO CA N/A racers suggested using the 354 motors instead of the 392 due to early heads where better on the intake angle and lifter angles They would increase the stroke to make them bigger. If yours is a 392 block is it a regular, RR or A-1 casting? The A1 was the preferred 392 block due to having the thicker full main webbing instead of the weaker blocks with the lighting done between the main webbing and cylinder walls
[Re: Cab_Burge]
#2661721
06/03/19 04:14 AM
06/03/19 04:14 AM
TRENDZ
Milwaukee WI
This is a 331 industrial engine. I sort of fell into this by accident. I was given a 241 hemi when a friend died. It was a basket case. Lots of cool old parts. In the time I spent trying to find the parts I needed/ wanted, I realized that some people in the early dodge hemi world are easily threatened when an outsider wants certain parts. Anyway, after searching local craigslist for parts for that engine, I came across this 331. Complete minus intake for $700. I searched the internet for parts for the 331, and quickly learned that the Chrysler hemi is supported by a whole slew of companies. I can get a new roller cam from damn near any cam company. The price and support made it much easier to go this route. Honestly never knew much about these engines, but they are growing on me.
[Re: moparx]
#2661807
06/03/19 11:23 AM
06/03/19 11:23 AM
TRENDZ
Milwaukee WI
4140 alloy steel. Done on my manual mill in the garage. Im pretty pleased with how it turned out.
[Re: moparx]
#2661866
06/03/19 01:42 PM
06/03/19 01:42 PM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
VERY nice machine work ! what grade material ? I'd love to be able to just make something like that for myself!
[Re: slantzilla]
#2661867
06/03/19 01:44 PM
06/03/19 01:44 PM
Posts: 17,840 S.E. Michigan
ZIPPY
S.E. Michigan
Very pretty looking work! They appear very robust for sure.
Rich H.
Esse Quam Videri
[Re: dodger mope]
#2661883
06/03/19 02:15 PM
06/03/19 02:15 PM
TRENDZ
Milwaukee WI
I didn’t keep track of time, but it was 3 weekends of “hobby time” It took longer than I thought it would. The caps weren’t the hard part. Getting the block ready was tricky, because my mill is worn some. The elevation of the table changes at the ends of the travel distance needed. It was difficult, but all the saddles are the same depth from the pan rail now. That made making the caps much easier. The block started out with one side at .124” and the other at .126” that would have made the cap plane surfaces tipped. Fixturing would have been difficult.
[Re: TRENDZ]
#2661920
06/03/19 05:13 PM
06/03/19 05:13 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
Done on my manual mill in the garage. This raises the bar a tad. lol The thing I admire most about this is that this is exactly how it was done by the pioneers of the sport. If they wanted something , they made it. And the biggest expense of " unobtanium " parts was the tooling and ability to make it happen. It is far rarer to see this today , as opposed to people opening their check book and having things made for them. And I don't have a problem with either. But the skill and determination that goes into making your own parts sets your build apart from the way it happens for most of us.
[Re: tubtar]
#2661992
06/03/19 08:44 PM
06/03/19 08:44 PM
dartman366
Mt. Vernon, Ohio
Only problem I find with them is,,,they are going to be hidden in a oil pan and no one will get to admire them,,,nice impressive work.
[Re: moparx]
#2662280
06/04/19 03:06 PM
06/04/19 03:06 PM
TRENDZ
Milwaukee WI
No heat treat. Was told 4140 in stress relieved state closely mimics elongation of cast iron. Im no metallurgist but that sounded good to me! Should I be concerned?
[Re: TRENDZ]
#2662364
06/04/19 08:26 PM
06/04/19 08:26 PM
dartman366
Mt. Vernon, Ohio
unless done in a controlled environment 4140 will move around during the treatment process and probably shrink, bend and/or twist a little.
