Need electrical help
#2661875
06/03/19 01:53 PM
06/03/19 01:53 PM
Posts: 233 MN
Skid_Demon
MN
1966 Newport, 383, auto, stock except hei ignition. Fired up fine after long winter. Went for a joy ride a few days ago, now I have problems. Started it to move out of garage to wash windows, things OK. Tried to start to move back in, starter made the machine gun noise. Tested battery with meter, 12.5 volts. Put charger on. Battery up to 13.3v. Starter made same noise. Brought starter to parts store, tested good. Recharged battery, checked with load tester, passed. This morning, 12.7v at battery and same at large lead on relay. Tried jumping relay, same starter noise. I have 12.7 at battery, relay and starter. Goes down to 5-6v in key start position or jumping relay. Battery posts and cables clean. Any ideas? Thanks
Re: Need electrical help
[Re: Skid_Demon]
#2661893
06/03/19 02:59 PM
06/03/19 02:59 PM
Posts: 25,786 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Try bypassing each battery cable with a jumper cable.
[Re: John_Kunkel]
#2661910
06/03/19 04:47 PM
06/03/19 04:47 PM
Posts: 10,713 North Dakota
6PakBee
North Dakota
Sounds like a poor connection at the battery terminal (either/both + and -) and at the engine termination points for both cables.
[Re: Skid_Demon]
#2662034
06/03/19 10:07 PM
06/03/19 10:07 PM
RapidRobert
If the battery & starter are confirmed good & the cables/terminals (incl ground path) are good the only other thing I could think of is something fubared inside the eng greatly increasing drag (not likely I wouldn't think) or dist got bumped CCW greatly increasing the initial. I gotta Keep It Simple Sam & go with inadequate amperage reaching the starter (classic machine gun clicking). Can you set a known good battery by the LF wheel & jump it underneath directly to the starter with some jumper cables & see what happens. EDIT CW, missed that this is a BB
[Re: Skid_Demon]
#2662079
06/04/19 02:51 AM
06/04/19 02:51 AM
Posts: 4,848 Memphis
HemiRick
Memphis
Goes down to 5-6v in key start position or jumping relay. Your battery is bad.....
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: HemiRick]
#2662169
06/04/19 10:10 AM
06/04/19 10:10 AM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
I agree sounds like battery.Mine went last year.Started perfect and went to cruise.Went to leave and pretty much nothing.Got it home charged and checked volts.Was at 13.Turn on key and try to start and pretty much 4 or 5 volts.New battery fixed it.Starter could be drawing a huge load though.But you would think if it drew enough amps to drop volts to 5 cables would get real hot and or smoke.Check cables also.Ive seen them look great but have corrosion inside.I run 1 gauge on mine.Rocky
Chrysler Firepower
[Re: HemiRick]
#2662254
06/04/19 01:34 PM
06/04/19 01:34 PM
John_Kunkel
Rio Linda, CA
Goes down to 5-6v in key start position or jumping relay. Your battery is bad..... Or the cables. They can fail internally and look OK on the outside.
[Re: therocks]
#2662258
06/04/19 01:41 PM
06/04/19 01:41 PM
Posts: 19,396 north of coder
moparx
all good advice. "green" cable internals are not that uncommon. all it takes is a tiny crack in the insulation, moisture, and time. check your connections at ALL points. if you have those "clamp on" battery cable ends, TOSS 'EM & get NEW cables ! i've fixed more electrical issues than you can believe, caused just by those cable ends ! try jumping the battery cable to solenoid at the starter, and the relay, after determining what voltage is present at the battery cable[s]. that may narrow your search. electrical can be very frustrating at times, but we have confidence in you ! please keep us up to date on your progress.
[Re: moparx]
#2662303
06/04/19 04:53 PM
06/04/19 04:53 PM
Posts: 8,022 Tulsa OK
Bad340fish
Tulsa OK
Did they use a real load tester or did they use a digital tester? The digital testers do not put a load on the battery, they just check the internal resistance and spit out a number. They can be accurate but it is entirely possible for a battery to pass a digital test and fail an actual load test.
The severe voltage drop makes me think bad battery, or locked up motor.
68 Barracuda Formula S 340
