Aftermarket Glass thoughts #2661242
06/01/19 03:11 PM
06/01/19 03:11 PM
TN
68rtcharger Offline OP
TN
I was curious if anyone has used aftermarket glass for your car? I have a couple large stacks of factory glass I could polish out and look "okay" I have been kicking around the idea of ordering a complete set of aftermarket glass
What is your thoughts? Pro Cons?
Re: Aftermarket Glass thoughts [Re: 68rtcharger] #2661264
06/01/19 04:43 PM
06/01/19 04:43 PM
BlueRacer69 Offline
BlueRacer69  Offline
I have no personal experience myself with any of the aftermarket glass, but heard its a little thinner then the factory stuff. Don't know how true that is. Just something I heard.
Re: Aftermarket Glass thoughts [Re: BlueRacer69] #2661286
06/01/19 05:59 PM
06/01/19 05:59 PM
TN
TN
I have heard the same thing. Im curious if would effect window sealing or would leak air bad
Re: Aftermarket Glass thoughts [Re: 68rtcharger] #2661295
06/01/19 06:37 PM
06/01/19 06:37 PM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
PPG glass.. is the only after market glass to get... still American made ,,most or all others are junk.. j..I bought and had pro install,, they said it's the best..just did my 77 Volare.. ..perfect fit..windshield..I found them on line..I picked it up at their warehouse in NJ..If you can't find them I may be able dig out the info.. Wiffy doesn;t throw out anything...
Re: Aftermarket Glass thoughts [Re: dynamite] #2661347
06/01/19 09:05 PM
06/01/19 09:05 PM
TN
TN
Thank you!
I found PPG Auto Glass online, but the website showed no glass available for my application (68 Charger)
Re: Aftermarket Glass thoughts [Re: 68rtcharger] #2661376
06/01/19 10:56 PM
06/01/19 10:56 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
It may be that Pilkington makes the glass, I don't know...AMD and whoever else sells the glass may be the only vendors.
There's AMD front & back glass in one of my cars ('68 Road Runner), and it seems fine as far as fit & finish, and the windshield fits the rubber gasket (also replaced) properly.
Re: Aftermarket Glass thoughts [Re: 68rtcharger] #2661386
06/01/19 11:27 PM
06/01/19 11:27 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Thank you!
All your going to get from PPG for a 68-70 Charger is the front windshield in tint only....if you want any other glass, or clear for the car, contact ECS or AMD, depending on your wallet and requirements...
Re: Aftermarket Glass thoughts [Re: 68rtcharger] #2661387
06/01/19 11:33 PM
06/01/19 11:33 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
All the glass now, PPG or aftermarket is running .200 thick/5mm OEM stock glass was only .050 thicker...
Re: Aftermarket Glass thoughts [Re: DAYCLONA] #2661417
06/02/19 07:43 AM
06/02/19 07:43 AM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
I just bought new windshield for 70 cuda. (Local glass place)117 bucks tax and out the door. I can't tell any differance in it and any other windshield... The only job it has to do is not leak. (And that's not really the glass) and keep the things on the outside...outside
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: Aftermarket Glass thoughts [Re: toplescuda] #2661623
06/02/19 07:32 PM
06/02/19 07:32 PM
TN
TN
Anyone heard of www.VintageGlass.com ?
They quoted me a price for all 8pcs for the Charger. I would need to call them to confirm if the quote included shipping, but if so, they came in 400 less than AMD
Re: Aftermarket Glass thoughts [Re: 68rtcharger] #2661624
06/02/19 07:36 PM
06/02/19 07:36 PM
TN
TN
Well I answered my own question, per their Facebook page shipping is included.
Re: Aftermarket Glass thoughts [Re: 68rtcharger] #2661683
06/02/19 11:06 PM
06/02/19 11:06 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I'd go with AMD....Vintage Glass has a bad rap
Re: Aftermarket Glass thoughts [Re: 68rtcharger] #2661691
06/02/19 11:31 PM
06/02/19 11:31 PM
Ohio
P
PDR Dude Offline
PDR Dude  Offline
P
Ohio
I have a Cuda convertible with a drivers door class that's aftermarket Doesn't fit worth a hoot. The curvature is incorrect. It's possible that its hardtop glass also. Fortunately on a convertible, the glass is down the majority of the time. Some of the repoped windshields I've seen are wavy. Ran into a situation recently on a late model car where the aftermarket replacement glass had to be replaced with factory, because the lane departure cameras could not be correctly calibrated. The cameras on that vehicle are attached to the windshield. So just a slight difference in curvature caused an issue. Inspect closely prior to install...
Re: Aftermarket Glass thoughts [Re: DAYCLONA] #2661745
06/03/19 08:32 AM
06/03/19 08:32 AM
TN
TN
10-4
Thank you for the heads up.
Re: Aftermarket Glass thoughts [Re: DAYCLONA] #2661746
06/03/19 08:35 AM
06/03/19 08:35 AM
TN
TN
10-4. Thank you fir the heads up!
Re: Aftermarket Glass thoughts [Re: 68rtcharger] #2661778
06/03/19 10:14 AM
06/03/19 10:14 AM
JERSEY
RJS Offline
RJS  Offline
JERSEY
My 71 Charger has front and rear windshields from AMD along with the drivers door. Looks very nice and fit was perfect. The color/shading on driver's door is different than my factory glass and it is the un-tinted style. The Chrysler logo's are bigger than factory glass also.
As time goes on I will add the other 3 pieces to my car so all will at least look the same.
I bought through Summit so returns or problems would be easy if needed.
Ron
Re: Aftermarket Glass thoughts [Re: 68rtcharger] #2661786
06/03/19 10:37 AM
06/03/19 10:37 AM
Eau Claire, WI
Charger727 Offline
Charger727  Offline
Eau Claire, WI
I put a full set of side glass from AMD in my 71 duster. Fit was fine, no serious issues, but I did notice a slight waviness towards the top of the door glass. Definitely not as good as factory, but fine for a driver.
Re: Aftermarket Glass thoughts [Re: RJS] #2661801
06/03/19 11:07 AM
06/03/19 11:07 AM
north central IL
Big-Bo-Hemoth Offline
north central IL
I just went through this with my '71 charger with tinted glass. I needed windshield and back glass. All of the used stuff had problems: chips, deep scratches, pits etc that I probably could not polish out. A local shop had an extra AMD tinted windshield for an excellent price so I bought it and it fit perfect. So I thought I would try the backlight from AMD/Jegs. First one came in with a 10" diameter hump on drivers side that was about 1/4" high. I could not attach my dual suction cup handle to that side. Pass side was flat so the handles would seat here. You could feel the difference with your hand. Defective glass was returned for exchange. Second one came in with same defect. Sent that one back and Jegs called AMD and they found that all of their stock had the same defect. Now back to search for used again. Glad that shipping was taken care of and they refunded my $. No gripe with Jegs but I wish AMD would have checked before sending X 2.
Re: Aftermarket Glass thoughts [Re: Big-Bo-Hemoth] #2661975
06/03/19 08:14 PM
06/03/19 08:14 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
My "ACC" glass, or whatever it is, is not very good. I've struggled and had to do a few workarounds to get a decent door seal [hard top]. The windshields are also thinner than AMD.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
