Page 1 of 3 1 2 3
VALVE SPRING COIL BIND QUESTION #2659670
05/27/19 02:19 PM
05/27/19 02:19 PM
Queensland Australia
moparmacka Offline OP
I understand the theory behind setting up valve springs close to coil bind eg 0.050-0.060. However, is it that critical in a street strip engine that isn’t seeing constant high RPM. I have found a float issue in my new bullet at approximately 7000rpm. Problem is, I only have 0.640 lift (nett with deflection measured at the retainer), and any solid roller spring worth their salt sets up anywhere from 0.160 to 0.200 from coil bind. And no I can’t shim my current springs any more. It isn’t a pressure issue, more like a frequency problem.
Some say don’t worry and others say it’s super critical. Thoughts please?
Thanks in advance.....
Re: VALVE SPRING COIL BIND QUESTION [Re: moparmacka] #2659685
05/27/19 04:02 PM
05/27/19 04:02 PM
Valve float causes all kinds of havoc in the valve train, it ain't a ship, don't float them tsk work
As far as distance to coil bind that is done, to my understanding from several different cam techs, is to prevent harmonics from the coils in the springs at the upper RPM.
On your deal, problem, you didn't say if it is a flat tappet or roller cam and or what seat and open pressures your dealing with so if it is floating them at 6400 not do to hydraulic lifters pumping up the you have two choices, change the springs to another type and or shift it before 6200 RPM shruggy work
BTW I set all my motors up with more seat pressures than most cam company recommend and shoot for within 10 lbs. at the open height to start with based on lower seat pressures allow the lifters to float at max lift more than when you have more seat pressures on flat tappet type lifters, solid or hydraulics up 140 to 175 on the seats and up to 375 lbs. at max lift and try to get from .050 to .100 from coil bind. Which is not always do able with the valve springs available today.
I'm bless to have a large supply of new and old valve springs, a very good valve spring tester and a lot of valve spring shims to shoot for perfect on all 16 springs wrench up
Please let us know what you do and the results scope That will help others on here as well thumbs
Re: VALVE SPRING COIL BIND QUESTION [Re: moparmacka] #2659713
05/27/19 05:47 PM
05/27/19 05:47 PM
A727Tflite Offline
A727Tflite  Offline
How do you know it’s a float issue ?
What are the symptoms?
Re: VALVE SPRING COIL BIND QUESTION [Re: Cab_Burge] #2659726
05/27/19 06:29 PM
05/27/19 06:29 PM
Solid roller.
Re: VALVE SPRING COIL BIND QUESTION [Re: A727Tflite] #2659727
05/27/19 06:31 PM
05/27/19 06:31 PM
We could hear it on the dyno and when I removed the rockers and there was a text book pattern on the valve tips.
Re: VALVE SPRING COIL BIND QUESTION [Re: A727Tflite] #2659730
05/27/19 06:34 PM
05/27/19 06:34 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
It could be as simple as a similar spring with a different spring rate is needed. As you mentioned, the spring you're using is hitting a frequency that is causing it to go in to surge, it's likely a similar spring of a different rate won't do this.
Tom Vigue has done some testing on his spintron where he mentioned running the spring around 0.200" from bind without any issues.
Alan Jones
Re: VALVE SPRING COIL BIND QUESTION [Re: LA360] #2659739
05/27/19 07:17 PM
05/27/19 07:17 PM
Found some cool iskys but .160 from coil bind.
Re: VALVE SPRING COIL BIND QUESTION [Re: moparmacka] #2659842
05/28/19 05:51 AM
05/28/19 05:51 AM
Locomotion Offline
Locomotion  Offline
You said you "only have .640" lift". Lift isn't the primary factor in valve float. Lobe shape is! Cams with .400" - .500" lift can float early if not properly set up. (i.e.: NHRA Stock Eliminator cams often referred to as having "square" lobes".)
If you can't "shim" your springs more, can you get more pressure (open as well as seat) from the other end using -.050" locks and/or retainers?
I'm no cam expert, but I had valve train issues and caught retainer damage before it let go all the way. Going from 160/360 to around 200/400 made a difference and even helped maintain more consistent valve adjustments between checks.
Re: VALVE SPRING COIL BIND QUESTION [Re: Locomotion] #2659846
05/28/19 06:24 AM
05/28/19 06:24 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
What is stopping you from adding more shim? I recently shimmed mine to .050-.060 and had to add a good amount of shims, but comp said as long as I could get the valve seal on not to worry about the shim stack. I haven't run it yet to see if there is a performance difference, i wasn't having a problem before but did this off of comps recommendation.
68 Barracuda Formula S 340
Re: VALVE SPRING COIL BIND QUESTION [Re: Bad340fish] #2659965
05/28/19 11:26 AM
05/28/19 11:26 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
What spring?
what installed height?
Re: VALVE SPRING COIL BIND QUESTION [Re: B1MAXX] #2660007
05/28/19 12:17 PM
05/28/19 12:17 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Originally Posted by B1MAXX
What spring?
Closed & open pressures w/ current spring?
How close to coil bind w/ current installed height?
What type (diameter & wall thickness) & length are the pushrods?
How much deflection between measuring lift w/ soft spring and measuring with actual spring?
What type of rocker arms & what ratio?
What type of cam lobe ("Drag", "Endurance", ?)?
What's the hot lash setting?
Also, what could you "hear" on the dyno? And what did the dyno data indicate (e.g., valvetrain "crash", or no incremental gains or even losses of measured air flow at RPM intervals, or screwy AFR readings, or...)?
Re: VALVE SPRING COIL BIND QUESTION [Re: moparmacka] #2660065
05/28/19 02:58 PM
05/28/19 02:58 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Spintron has rudely schooled me on coil bind. Back in the day, everyone assumed that (with symmetrical springs) each coil will collapse separately and simultaneously, and the inter-coil distance will shrink but remain equal to full lift.
This never happens. The top coils smack each other long before full lift, and this collision is added & subtracted to the position and stored energy of every coil.
A spring at full chat looks like a slinky.
Boffin Emeritus
Re: VALVE SPRING COIL BIND QUESTION [Re: polyspheric] #2660100
05/28/19 05:00 PM
05/28/19 05:00 PM
BradH Offline
BradH  Offline
But did you see anything that shows the benefit of setting up the spring to lift closer to coil bind to help reduce the harmonics or spring surge? Or is it a tradeoff where it can help tame the surge, but at the price of weakening the spring prematurely? work
"Full chat" - You're originally from the UK, right? Never heard that expression used elsewhere...
Re: VALVE SPRING COIL BIND QUESTION [Re: BradH] #2660124
05/28/19 06:51 PM
05/28/19 06:51 PM
New York
polyspheric Offline
polyspheric  Offline
New York
All of the reccos I've seen are just trying to avoid coil bind while using the shortest spring. Other benefits? IDK.
Boffin Emeritus
Re: VALVE SPRING COIL BIND QUESTION [Re: B1MAXX] #2660827
05/31/19 05:53 AM
05/31/19 05:53 AM
PAC 1343. Installed at 1.870.
Re: VALVE SPRING COIL BIND QUESTION [Re: BradH] #2660829
05/31/19 06:04 AM
05/31/19 06:04 AM
255@1.870
610@1.230
7/16 full taper with 0.165 wall
Deflection is approximately 0.020 with spring
T&D rockers 1.6 ratio
Crane 0.427 SR lobe with 1.050 base circle
0.020-0.022 hot
You could hear a flutter at 7000. The dyno reflected this with a squiggly line then suddenly drops off. Also tips of valves have a snow angel pattern.
Re: VALVE SPRING COIL BIND QUESTION [Re: moparmacka] #2660930
05/31/19 11:37 AM
05/31/19 11:37 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
set up looks ok. What is the condition of the valve job/ guide?
Re: VALVE SPRING COIL BIND QUESTION [Re: moparmacka] #2660932
05/31/19 11:39 AM
05/31/19 11:39 AM
BradH Offline
BradH  Offline
Not that I'm an expert on this stuff, but nothing appears "wrong" from the parts description above.
What type of cylinder heads, valves (material, length & size) and spring retainers (material)? Trying to get a sense for how heavy the valvetrain components are...
An "out of the blue" question: How old is that Crane lobe design? There have been lots of advancements in lobes over the years w/ the advent of Spintrons, etc., and some newer designs are promoted as having better high RPM dynamics than comparable older lobes.
Re: VALVE SPRING COIL BIND QUESTION [Re: moparmacka] #2660950
05/31/19 12:35 PM
05/31/19 12:35 PM
Does that cam have the early Hi Low No Pop lobes on it? They had inverted flanks, those lobes would start to open the valves and then let them close a little and then go to max lift scope
they didn't make them very long either work shruggy
Cam lobe designs have changed a bunch in the last 30 yrs, especially drag race lobes shruggy
Good luck on finding and fixing this problem up
Re: VALVE SPRING COIL BIND QUESTION [Re: B1MAXX] #2661006
05/31/19 04:53 PM
05/31/19 04:53 PM
I haven’t removed the heads. Was hoping to just swap out the spring.
Page 1 of 3 1 2 3
