Alum head compression... #266090
03/25/09 01:59 PM
03/25/09 01:59 PM
East Bay Area
Bladeruner69 Offline OP
East Bay Area
Anyone think that 11.25 compression ratio is doable for a street car with aluminum heads on pump gas. Is this reasonable?
Re: Alum head compression... [Re: Bladeruner69] #266091
03/25/09 02:01 PM
03/25/09 02:01 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
With the right cam you can .
Re: Alum head compression... [Re: Bladeruner69] #266092
03/25/09 02:02 PM
03/25/09 02:02 PM
hemisurfer Offline
hemisurfer  Offline
yes
Chris
Re: Alum head compression... [Re: Bladeruner69] #266093
03/25/09 02:08 PM
03/25/09 02:08 PM
Western NC
68Bullit Offline
68Bullit  Offline
Western NC
I'm currently using stock Eddy heads on my small block with 10:6:1 compression and no problems with 93 octane, in fact, I've been thinking of trying 89 octane and maybe some timing adjustments to see if it pings any. Quench is the key for higher compression - .042" is best if I'm thinking correctly.
Re: Alum head compression... [Re: 68Bullit] #266094
03/25/09 02:15 PM
03/25/09 02:15 PM
Renton, Wa.
Classof70Chally Offline
super gas
super gas
Renton, Wa.
My sons stroker 500 is running Eddy heads with 11.25 CR and what I would call a middle of the road duration street cam (Not sure of exact numbers). It runs on the 92 oct we have here but when he goes to the track and flogs it he usually puts in about 10% race gas. I think 11.0 to one would be better for a street/pump gas motor, again depending on the cam and other factors.
Re: Alum head compression... [Re: JohnRR] #266095
03/25/09 02:36 PM
03/25/09 02:36 PM
East Bay Area
East Bay Area
Lots of overlap(108 lsa) and a lot of duration?
Re: Alum head compression... [Re: Bladeruner69] #266096
03/25/09 02:46 PM
03/25/09 02:46 PM
Newfoundland
codfish Offline
codfish  Offline
Newfoundland
INTAKE EXHAUST
ADV DURATION 307 318
DUR @.050 250 263
LOBE SEPARATION 113
DEGREED to 110
This is what Scott Brown speced for my stroked 440. It has RPM heads, .044" quench. Comp of approximately 11.3-1.
It runs fine on premium, and has a nice lope to the idle.
codfish
