440 intake decision #2660487
05/29/19 10:04 PM
05/29/19 10:04 PM
middle Tennessee
mopower440 Offline OP
middle Tennessee
Im ready to buy an aftermarket aluminum intake for my 440 dart! Its a street car that may see some track time but i DO want it to be as quick as possible on the street. It has stock 452 heads currently but will go aluminum soon hopefully. Ok, i REALLY want the performer RPM so bad i can taste the aluminum!!, BUT, i run a thermoquad, and by the time i take the height of the RPM intake, plus the carb adapter plate, im almost posotive it will not fit under my flat hood, and i dont want to cut my hood. I wish i knew someone close by that i could borrow the RPM intake and just mock it up on my car to be sure, but i cant see spending 300 bucks to buy the intake with the chances it will fit being so low. SO, i need to figure out which one to get that will clear the hood. Ive read that intake shoot out and still cant decide. Im guessing its between the Torker 2 and the holley street dominator,,? Any opinions are greatly appreciated. I need to decide soon as i have a lead on both the SD and torker 2 right now used.
Thanks!
Re: 440 intake decision [Re: mopower440] #2660494
05/29/19 10:34 PM
05/29/19 10:34 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I ran the Holley Street Dominator on my old 906 headed 440 and it worked good. Ran a best of 11.49 @ 116 in my 63 Sport Fury. Ron
Re: 440 intake decision [Re: mopower440] #2660535
05/30/19 08:26 AM
05/30/19 08:26 AM
Castle Rock, CO
pwr440 Offline
pwr440  Offline
Castle Rock, CO
Mopower,
I've ran the RPM and Street Dominator on my mild 440 and i can only tell you that from a "butt dyno" perspective I could not tell a difference. My engine
has Stealth heads, the larger Summit cam, and Hedman headers. Like I said...mild combo. Anyways since you're concerned about hood clearance I wouldn't
hesitate one bit on using that Street Dominator.
Britt
Re: 440 intake decision [Re: pwr440] #2660537
05/30/19 08:31 AM
05/30/19 08:31 AM
an8sec70cuda Online content
an8sec70cuda  Online Content
Use the Holley Street Dominator! I've tested it back to back against the Edelbrock Performer RPM on a mid 11 sec 440 combo in a 3700 lb car and they ran almost identical.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 440 intake decision [Re: mopower440] #2660539
05/30/19 08:48 AM
05/30/19 08:48 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I had an Indy intake that wouldn't fit under the hood a few years ago. I just measured the amount it was too tall and had that much milled off at a machine shop. Cost about $75 if I remember correctly. Since I didn't have the chance to run both, I don't know what,if any, the performance penalty might have been. Or maybe cut the top flange off the adapter and have it welded to the intake after having the intake cut down till it all fits under the hood.
And I have had good luck with the Holley intake, myself.
Master, again and still
Re: 440 intake decision [Re: mopower440] #2660545
05/30/19 09:14 AM
05/30/19 09:14 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
If you have to run a spread bore and have to have a flat hood, without doing any machine work your choices are limited to
whatever manifolds already have a spread bore flange. Like a stock '70s iron thing, a Performer non-rpm, or a Street Dominator.
The Performer non-rpm is good for a huge car like a C body but I don't think you need that.
The stock iron stuff, is stock iron stuff.
That leaves the street dominator as the best overall choice.
Rich H.
Esse Quam Videri
Re: 440 intake decision [Re: ZIPPY] #2660546
05/30/19 09:19 AM
05/30/19 09:19 AM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
I’ve always liked the CH4B for the street.
Re: 440 intake decision [Re: Montclaire] #2660551
05/30/19 09:35 AM
05/30/19 09:35 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
One of the best antiques out there ! twocents
Re: 440 intake decision [Re: mopower440] #2660735
05/30/19 08:07 PM
05/30/19 08:07 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Maybe the Holley SD is the right choice. But honestly, I don't know how anyone can make any recommendations with virtually no information regarding the motor, car, and use details.
I can assure you that there is a point that the SD will measurably under perform a dual plane intake.
And, if your're really interested in not giving up performance, I'm not sure why the use of something other than a TQ is not a consideration.
Re: 440 intake decision [Re: BSB67] #2660759
05/30/19 09:19 PM
05/30/19 09:19 PM
middle Tennessee
middle Tennessee
Thermoquads and quadrajet is all i know anything about.. I have no clue how a holley works. The engine is a .030 over 440, cast crank engine, stock 452 heads. Compression ratio is right at 9.4:1. MP 284/484 cam installed 4 degrees advanced. 3000 stall, stock iron intake, 3.23 gears FOR NOW..will be going to 3.55 or 3.91 in the near future.Initial timing is 18 and total 34. The thing makes crazy torque especially being in a lighter A-body, but wanting a little more up top. I will go with aluminum heads when money is saved up.
Re: 440 intake decision [Re: mopower440] #2660768
05/30/19 09:35 PM
05/30/19 09:35 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Get an SD
Re: 440 intake decision [Re: BSB67] #2660771
05/30/19 09:44 PM
05/30/19 09:44 PM
middle Tennessee
middle Tennessee
Get an SD
is that your opinion serious? You think it would be fine on the street when just cruising being a single plane and all? Didnt know if you are being serious or sarcastic because of my combo..
Re: 440 intake decision [Re: mopower440] #2660777
05/30/19 10:13 PM
05/30/19 10:13 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
Get an SD
you have a healthy cam, some stall, a torquey motor in a lightish car and might go to a pretty steep gear...the SD makes sense. I've read that the M1 single plane is similar to the SD, maybe someone else can confirm for you...
Re: 440 intake decision [Re: krautrock] #2660799
05/30/19 11:20 PM
05/30/19 11:20 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
He says he wants a street intake. That means a dual plane. Yeah it'll go flat after 5500rpm, because it's made to. Give it some gear and the dual plane of your choice and go have fun. Don't give up torque with a single plane on the street.
Re: 440 intake decision [Re: mopower440] #2660824
05/31/19 06:21 AM
05/31/19 06:21 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Had a couple of street dominators over the years on a few different cars, and never was I unhappy with performance. Them things were and are, everywhere, not because they're junk.
Re: 440 intake decision [Re: mopower440] #2660836
05/31/19 07:55 AM
05/31/19 07:55 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
You've basically got the old Direct Connection 13.5 second recipe.
Before the M1 intakes were available, and before the name change to Mopar Performance....Chrysler recommended the Holley Street Dominator for this setup.
No worries, that's the one you want for how you're using the car + it will support your future plans.
Rich H.
Esse Quam Videri
Re: 440 intake decision [Re: ZIPPY] #2660838
05/31/19 07:59 AM
05/31/19 07:59 AM
middle Tennessee
middle Tennessee
Just unsure being it IS a single plane and being used on the street, but many say that the way its made that it is still good on the low end side for the street..?
Re: 440 intake decision [Re: mopower440] #2660845
05/31/19 08:34 AM
05/31/19 08:34 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
performance wise you have 3 intakes that work the best and have been dynoed and track tested over and over again, Street dominator, M1 single plane and a edelbrock performer rpm. all will be within a hp or two of each other, all ran about the same quarter mile on the same car when tested back to back. now the m1 and the rpm are pretty tall. the street dominator is noticeably shorter than the others. so if you're worried about hood clearance the sd is the easy winner and keeps up performance with the other two. once you start getting more aggressive into the 650-700 hp range then you definitely want to switch intakes.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: 440 intake decision [Re: Jerry] #2660881
05/31/19 10:43 AM
05/31/19 10:43 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
I've heard that the Street Dominator was popular with the cops in the old 440 cars. Never saw it myself but it was a popular rumor back in the 70s.
Re: 440 intake decision [Re: mopower440] #2660904
05/31/19 11:34 AM
05/31/19 11:34 AM
Quote
I've heard that too.
