Sealing Intake on 440 #2659994
05/28/19 01:03 PM
05/28/19 01:03 PM
North Carolina
469runner Offline OP
North Carolina
I am using Aluminum Heads and an Aluminum Intake. I have had trouble getting the intake to seal. I have verified that the angle is correct by laying the intake on the engine and using feeler gauges all around the outside ports and under as well. I have been using the Fel Pro bathtub sheetmetal gasket. with a smear of sealer around the ports. I have heard Chrysler used a paper gasket set in addition to the sheetmetal one when aluminum intakes were used. Is this true and are they available? Thanks.
Re: Sealing Intake on 440 [Re: 469runner] #2660060
05/28/19 03:42 PM
05/28/19 03:42 PM
yes, suprformance (sp) (a sponsor here) has em I believe & 440source does for sure.
Re: Sealing Intake on 440 [Re: 469runner] #2660094
05/28/19 05:36 PM
05/28/19 05:36 PM
Buy the Fel Pro # 1215 440 bathtub kit as it comes with two sets of the good thin composite gaskets and it blocks the heat passage off on the stock type heads with the heat cross over in the stock type intakes also scope up
Re: Sealing Intake on 440 [Re: Cab_Burge] #2660107
05/28/19 06:53 PM
05/28/19 06:53 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
iagree Cheap, effective, and readily available. Go to most any auto supply and if they don't stock it, they can usually have it the next day.
Master, again and still
Re: Sealing Intake on 440 [Re: Cab_Burge] #2660110
05/28/19 06:56 PM
05/28/19 06:56 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
This x2.
I suggest spraying the gaskets with high tack to keep them from sliding. I also bend the valley trayon the intake off the car to help ease install.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: Sealing Intake on 440 [Re: Cab_Burge] #2660138
05/28/19 08:33 PM
05/28/19 08:33 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
The last time I got the Fel Pro 1215, it did not come with the thin gaskets, just the thicker 0.030" gaskets. But that was several years ago and maybe they supply the 0.015" gaskets now..
Re: Sealing Intake on 440 [Re: BSB67] #2660144
05/28/19 08:57 PM
05/28/19 08:57 PM
west palm beach, florida
modelmakerinc Offline
Intake manifolds are not clearanced where they cross over the front and
Rear rails. This holds the intake off the head surface.
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: Sealing Intake on 440 [Re: modelmakerinc] #2660161
05/28/19 09:41 PM
05/28/19 09:41 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Originally Posted by modelmakerinc
Some intake manifolds are not clearanced where they cross over the front and
Re: Sealing Intake on 440 [Re: BSB67] #2660163
05/28/19 09:42 PM
05/28/19 09:42 PM
^^^ for sure mockup & see if clearancing is needed.
Re: Sealing Intake on 440 [Re: modelmakerinc] #2660169
05/28/19 09:59 PM
05/28/19 09:59 PM
I've seen stock 440 end rails that had a chamfer on one side on the ends and not on the other side work scope
I have had to chamfer or shorten them also to make sure they don't hold the intake up from seating properly wrench
I've also seen guys grind their intake manifolds to get clearances to the end rails shruggy up
Bottom line is to check them and fix as needed scope up work
Re: Sealing Intake on 440 [Re: 469runner] #2660966
05/31/19 02:04 PM
05/31/19 02:04 PM
Chicago
PurpleBeeper Offline
Chicago
How do your bolt holes line up? If the heads/block have been milled & the intake/head faces haven't been milled enough, the intake will sit high on it's own....basically, the intake bolt holes will be higher up than the head bolt holes making the bolts hard to start & the intake not seal. You can mill the intake to fix this. This is the situation I had on a motor & adding the paper gaskets only made it worse (couldn't even begin to start the intake bolts)
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Sealing Intake on 440 [Re: 469runner] #2660967
05/31/19 02:20 PM
05/31/19 02:20 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I've never liked the bathtub gasket by itself; using tin snips, I trim the bathtub gasket just outside the embossed ridges around the ports and use a thick composite gasket to do the actual port sealing. This way the bathtub acts as a valley cover only.
