Re: Sealing Intake on 440
[Re: 469runner]
#2660060
05/28/19 03:42 PM
05/28/19 03:42 PM
RapidRobert
yes, suprformance (sp) (a sponsor here) has em I believe & 440source does for sure.
[Re: BSB67]
#2660144
05/28/19 08:57 PM
05/28/19 08:57 PM
Posts: 2,345 west palm beach, florida
modelmakerinc
Intake manifolds are not clearanced where they cross over the front and Rear rails. This holds the intake off the head surface.
[Re: BSB67]
#2660163
05/28/19 09:42 PM
05/28/19 09:42 PM
RapidRobert
^^^ for sure mockup & see if clearancing is needed.
[Re: modelmakerinc]
#2660169
05/28/19 09:59 PM
05/28/19 09:59 PM
Posts: 43,232 Bend,OR USA
Cab_Burge
[Re: 469runner]
#2660966
05/31/19 02:04 PM
05/31/19 02:04 PM
Posts: 960 Chicago
PurpleBeeper
Chicago
How do your bolt holes line up? If the heads/block have been milled & the intake/head faces haven't been milled enough, the intake will sit high on it's own....basically, the intake bolt holes will be higher up than the head bolt holes making the bolts hard to start & the intake not seal. You can mill the intake to fix this. This is the situation I had on a motor & adding the paper gaskets only made it worse (couldn't even begin to start the intake bolts)
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: 469runner]
#2660967
05/31/19 02:20 PM
05/31/19 02:20 PM
Posts: 25,894 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I've never liked the bathtub gasket by itself; using tin snips, I trim the bathtub gasket just outside the embossed ridges around the ports and use a thick composite gasket to do the actual port sealing. This way the bathtub acts as a valley cover only.
