1971 charger vacume lines? #2659520
05/27/19 03:23 AM
05/27/19 03:23 AM
poplar bluff mo.
toplescuda Offline OP
I Whine
I Whine
poplar bluff mo.
Hope someone can help. I been putting our 71 charger rolling shell back togeather. And I'm at a point where need some help on what vacume lines run to what on the heater/a.c. I have a set of lines that pretty sure plug into the controls. And I have a grommet with 2 lines that was in the firewall one line pretty long. Not sure where they connect under the hood. And where they go under dash
Thank you in advance..
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: 1971 charger vacume lines? [Re: toplescuda] #2659640
05/27/19 01:53 PM
05/27/19 01:53 PM
So Cal, USA
Fab64 Offline
Fab64  Offline
So Cal, USA
Here is a link to Service Manuals. It doesn't list the Chassis Manual for 1971 Dodge, but I'm assuming the lines are the same in 1971 Plymouth? Look at page 24-62.
Re: 1971 charger vacume lines? [Re: toplescuda] #2660675
05/30/19 05:23 PM
05/30/19 05:23 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
Originally Posted by toplescuda
I been putting our 71 charger rolling shell back together.
I face a similar project with my '72. Do you have a build thread here documenting the work you are doing?
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: 1971 charger vacume lines? [Re: DynoDave] #2660823
05/31/19 05:14 AM
05/31/19 05:14 AM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
Not on this site. I have been posting pics along the way over the years as I been doing this car. As time and money allows
Most if any pics I post on facebook
1971 charger
Re: 1971 charger vacume lines? [Re: DynoDave] #2660954
05/31/19 01:41 PM
05/31/19 01:41 PM
Shoreline, Washington
72roadrunnergtx Offline
As mentioned, the factory service manuals have detailed schematics for the A/C controls. There is a difference between the ’71 and ’72 systems relating to vacuum line routing to note. The ’71 system uses a vacuum actuated water valve and uses a vacuum reservoir mounted under the battery tray. The system supply line running to the reservoir and the water valve hose are the two hoses that pass though the firewall near the blower motor. Another line from the vacuum fitting at the rear of the intake manifold would run to the reservoir.
The ’72s used a cable operated water valve, has a single line firewall pass-through grommet, that supply line runs directly to the intake manifold fitting, does not have a reservoir.
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
