Wire Harness Pin #2656068
05/16/19 05:29 PM
05/16/19 05:29 PM
Milan Ohio
ct440rod Offline OP
ct440rod  Offline OP
Milan Ohio
2007 dodge Ram left rear door wire harness broken wires I fix them once but they broke again. Does anyone know how to take the pins out of connector I don't have much wire to work with anymore
thanks
Re: Wire Harness Pin [Re: ct440rod] #2656261
05/17/19 01:11 PM
05/17/19 01:11 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
Here is a link to a previous thread about issues with a door harness. Towards the bottom there is mention of an aftermarket replacement harness that is available. Don't know if this will help or not. If not consider this a bump. smile
https://board.moparts.org/ubbthread...31098/2004-dr-dead-door.html#Post2631098
Re: Wire Harness Pin [Re: Jwilli500] #2656264
05/17/19 01:15 PM
05/17/19 01:15 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
Guess I should've just linked to the part too, so here that is, but the thread discusses ways to get it a little cheaper...
https://www.dormanproducts.com/p-78790-645-506.aspx?year=2004&make=Dodge&model=Ram%25201500&parttype=Door%2520Wiring%2520Harness&origin=YMM
Re: Wire Harness Pin [Re: Jwilli500] #2657196
05/20/19 11:15 AM
05/20/19 11:15 AM
Milan Ohio
ct440rod Offline OP
ct440rod  Offline OP
Milan Ohio
I was hoping someone could tell me how to take the pins out of connector and I can fix myself ..
Re: Wire Harness Pin [Re: ct440rod] #2657316
05/20/19 07:59 PM
05/20/19 07:59 PM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
Show us a picture of the connector and we can probably tell you how to remove the pins. There are several different style of connectors, each with its own process for removing the pins. Not all off us have a 2007 Ram to go look at. Gene
Re: Wire Harness Pin [Re: poorboy] #2659332
05/26/19 12:21 PM
05/26/19 12:21 PM
Milan Ohio
ct440rod Offline OP
ct440rod  Offline OP
Milan Ohio
Hope this helps
Re: Wire Harness Pin [Re: ct440rod] #2659518
05/27/19 02:37 AM
05/27/19 02:37 AM
Freeport IL USA
Freeport IL USA
Originally Posted by ct440rod
Hope this helps
Is this the female end of the plug, or the male end of the plug? Each end unlocks the wire differently. It appears to be the female end, but I can't tell for sure the way the picture is taken. Gene
Re: Wire Harness Pin [Re: poorboy] #2660883
05/31/19 10:47 AM
05/31/19 10:47 AM
Milan Ohio
ct440rod Offline OP
ct440rod  Offline OP
Milan Ohio
Male
Re: Wire Harness Pin [Re: ct440rod] #2660953
05/31/19 01:40 PM
05/31/19 01:40 PM
There is probably a spring loaded retaining tab on one side of the connector that needs to be press down so the connector will slide out, I use a small thin needle to get mine out on the earlier plugs, I push it in from the opposite side from the wire and pull on the wire while working on them, lots of fun whistling
You can do THIS up wrench
Re: Wire Harness Pin [Re: Cab_Burge] #2661056
05/31/19 09:10 PM
05/31/19 09:10 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
