Page 2 of 3 1 2 3
Re: Picked up this beauty this weekend!!! [Re: 4x4 Roundup] #2656474
05/18/19 07:14 AM
05/18/19 07:14 AM
Weatherford, Texas
RapidusMaximus Offline OP
Weatherford, Texas
Got a little more done yesterday, finally got the front drums off, shoes and drums were grooved into each other, what a whipping. The good news is O'Reilly's had all but a couple of the parts local so with any luck I'll have it ready for a test drive today. On a side note...so far I've put a battery, alternator and voltage regulator on and it's still showing discharge on the alt gauge and at the battery the volt tester is only picking up 12.7 volts...any suggestions?
1968 Plymouth GTX
1974 Dodge P/U Long Bed Stepside 318
2019 Ram 2500 6.4, auto, 4WD
Re: Picked up this beauty this weekend!!! [Re: RapidusMaximus] #2656475
05/18/19 07:32 AM
05/18/19 07:32 AM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
just for piece of mind have the parts tested. Just because they are new doesn't mean they are good.
1981 Dodge D150 360 auto
Re: Picked up this beauty this weekend!!! [Re: basketcase] #2656483
05/18/19 08:25 AM
05/18/19 08:25 AM
Weatherford, Texas
Weatherford, Texas
Good idea, after I finish the brakes I'll do one last check for bad grounds and broken wires then get the parts validated up
1968 Plymouth GTX
Re: Picked up this beauty this weekend!!! [Re: RapidusMaximus] #2656548
05/18/19 12:28 PM
05/18/19 12:28 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Does my heart good to see another old Dodge truck getting some love!!
Thanks!!!
Facts are stubborn things.
Re: Picked up this beauty this weekend!!! [Re: RapidusMaximus] #2656557
05/18/19 12:47 PM
05/18/19 12:47 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
Nice! up
On your charging problem- did you check the bulkhead connector? Seems I remember them being a problem on trucks also.
Missed a chance on a '75 locally. Called about it yesterday right after ad came up and the first guy that showed up bought it. frown
Story of my life- day late and a dollar short. shocked
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: Picked up this beauty this weekend!!! [Re: I_bleed_MOPAR] #2656680
05/18/19 08:27 PM
05/18/19 08:27 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Definitely clean up the bulkhead. On mine '79 Power Wagon, they looked really bad. I got a finger nail file (aka emory board I believe) and cut it down in width to fit inside everywhere I needed and cleaned all the points. It definitely helped with headlights dimming at idle.
Re: Picked up this beauty this weekend!!! [Re: larrymopar360] #2656711
05/18/19 10:40 PM
05/18/19 10:40 PM
Weatherford, Texas
Weatherford, Texas
Thanks for the input guys, didn't get a chance to chase electrical issues today the brakes kicked my you no what...jeez...adjusters frozen, springs broken, cables broken...what a mess...good news though, got three of four wheels done...one to go... hammer dakota beer
1968 Plymouth GTX
Re: Picked up this beauty this weekend!!! [Re: RapidusMaximus] #2656888
05/19/19 01:56 PM
05/19/19 01:56 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
It can be bad when a wheel cylinder leaks out and then everything sits! I had a set of rear drums on an old police car that were like that! I really thought I was going to have to cut one of them off. I finally got it off and did a reverse somersault in the process.
Re: Picked up this beauty this weekend!!! [Re: larrymopar360] #2657024
05/19/19 09:11 PM
05/19/19 09:11 PM
Weatherford, Texas
Weatherford, Texas
I haven't done the front brakes on one of these old 4WDs in awhile...i forgot how much disassembly was required...sheesh... hammer
1968 Plymouth GTX
Re: Picked up this beauty this weekend!!! [Re: RapidusMaximus] #2658395
05/23/19 01:16 PM
05/23/19 01:16 PM
Pennsylvania
scannman70 Offline
scannman70  Offline
Pennsylvania
Get a disc brake front end from the spindles out for a 3/4 ton mid 70s Chevy truck, You have to get the correct axel u joint and use the chevy end, and it will all bolt right together.
Probably have to add in a proportioning valve too. with all drum brakes My 72 did not have one....
Re: Picked up this beauty this weekend!!! [Re: scannman70] #2659269
05/26/19 07:38 AM
05/26/19 07:38 AM
Weatherford, Texas
Weatherford, Texas
Well, had to stop on the truck for a week, spent the last week in Philly sitting in a training class... laugh2. Oh well, got back 2am Friday morning and was in the shop by 9am, gave up on the disc brakes for now and completely overhauled the power drum system, shoes, hydraulics, hardware, new drums, new master cylinder, brakes are now bled and it's got an excellent pedal. Changed a leaky freeze plug and and cleaned all the bulkhead connecters and grounds, won't know if the charging issue is fixed until I fill it back up with anti freeze and fire it back up today. Also found out yesterday...the hard way...that a 72 W100 DOES NOT...have 4.5 inch bolt pattern wheels, had a set of nice wheels and tires stacked in the corner that I would use for test driving until I figured out what I wanted to put on the truck permanently...since the truck came with 4 flats...free of charge of course...image my surprise sitting on my backside rotating a wheel endlessly trying to get it on...then grabbing a tape measure and going...oh "S".... work laugh2 Still some tinkering to try and get done today...see if I can find a tire shop open, adjust the emergency brake cable, clean the interior...some more...anybody got any leads on a new rubber floor mat...this ones like crunchy as a potato chip.... up
1968 Plymouth GTX
Re: Picked up this beauty this weekend!!! [Re: RapidusMaximus] #2659278
05/26/19 08:38 AM
05/26/19 08:38 AM
Buford, GA
Buford, GA
www.lmc.com
Probably others also but just remember them from my last truck. up Hopefully, I'll have use for them again soon. biggrin
Tim
'71 Charger 383/727
Re: Picked up this beauty this weekend!!! [Re: RapidusMaximus] #2659281
05/26/19 08:41 AM
05/26/19 08:41 AM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
Re: Picked up this beauty this weekend!!! [Re: basketcase] #2659295
05/26/19 10:04 AM
05/26/19 10:04 AM
Weatherford, Texas
Weatherford, Texas
Bingo! Thanks! Although, scrolling through that catalog may be hazardous to my wallet. whistling
1968 Plymouth GTX
Re: Picked up this beauty this weekend!!! [Re: RapidusMaximus] #2659370
05/26/19 04:14 PM
05/26/19 04:14 PM
Des Moines IA
Soopernaut Online content
Soopernaut  Online Content
Des Moines IA
The 69-74 W100 had a 5 on 5.5" bolt circle. The 80-93 W100/150 also had a 5 on 5.5" bolt circle. The 75-79 trucks were the odd ones with the small 5 on 4.5" bolt circle.
1970 Dodge d100/eventually going on a 77 D100 frame
Re: Picked up this beauty this weekend!!! [Re: Soopernaut] #2659390
05/26/19 04:54 PM
05/26/19 04:54 PM
Weatherford, Texas
Weatherford, Texas
Good info, thanks. Got a little more done today, still showing no charge at the battery so I took the bulkhead connectors apart...again...pulled the instrument panel, cleaned everything, put it all back together, still no charge...ugh...adjusted the emergency brake...that was fun...not. Oh well...back at it tomorrow... dakota
1968 Plymouth GTX
Re: Picked up this beauty this weekend!!! [Re: RapidusMaximus] #2659419
05/26/19 07:12 PM
05/26/19 07:12 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Sorry it didn't fix things for you, but cleaning the bulkhead will serve you well anyhow!
Re: Picked up this beauty this weekend!!! [Re: larrymopar360] #2659468
05/26/19 09:23 PM
05/26/19 09:23 PM
Weatherford, Texas
Weatherford, Texas
...driving me nuts, going to backtrack everything in the morning...really don't want to start unwrapping harnesses, that'll be last ditch...
1968 Plymouth GTX
Re: Picked up this beauty this weekend!!! [Re: RapidusMaximus] #2659472
05/26/19 09:40 PM
05/26/19 09:40 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
did you have the alternator and regulator testred?
Re: Picked up this beauty this weekend!!! [Re: basketcase] #2659538
05/27/19 08:02 AM
05/27/19 08:02 AM
Weatherford, Texas
Weatherford, Texas
Well...kinda...the alternator tested good and I talked them into trading out the voltage regulator figuring with the alternator testing good it HAD to be the voltage regulator...nope.
1968 Plymouth GTX
Page 2 of 3 1 2 3
