measuring fuel pressure #2658896
05/24/19 09:27 PM
05/24/19 09:27 PM
NH
N
NHCharger Offline OP
N
NH
When measuring fuel pressure should you test the engine under load or can you just measure while in park and revving the engine. Two buddies telling me totally opposite methods.
My Dad always told me, when setting goals " avoid disappointment, aim low".
Re: measuring fuel pressure [Re: NHCharger] #2658901
05/24/19 09:42 PM
05/24/19 09:42 PM
When does it use the most fuel volume? work
Not in neutral tsk grin
I've drag raced for years and started dealing with fuel delivery problems on the first NHRA stocker I helped on, the original 1968/69 Plymouth GTX hemi automatic car that Steve and Linda Myers owned that she drove usually. I sold them the 426 Hemi motor and installed into their 440 car, I later rebuilt it and help them race it in NHRA during 1973 or 1974, CRS now whiney
Fuel delivery has caused a lot of grief for a lot of drag racers, a LOT of them from stock to Top Fuel shock
To answer your question you should test it in high gear above 3500 RPM at WOT until the RPM you normally lift at up scope
Let us know your results please, that can and will help others on here also thumbs
Re: measuring fuel pressure [Re: Cab_Burge] #2658915
05/24/19 10:22 PM
05/24/19 10:22 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Well, you can technically "test" fuel pressure anywhere choose, but like Cab says, at the top end after the system's had to keep the bowls full under WOT is where you'll find the system's limit.
Basically, you need enough pressure under that kind of demand to keep the jets fed & the engine from leaning out.
Some carbs' needles & seats will only tolerate 4.5 PSI - lowest I've seen was 2.5 PSI on a stock flathead Ford - and the Holley ballpark is around 7 PSI.
Those #s are easiest to achieve under low loads, but not so much under real demand.
I like to take that measurement as close to the carb as possible.
Re: measuring fuel pressure [Re: topside] #2658917
05/24/19 10:37 PM
05/24/19 10:37 PM
check the psi with a gauge hooked up right at the carb inlet at the end of the run however/wherever that is. Fuel demand/consumption is the greatest at that point & that is where it needs to be checked.
Re: measuring fuel pressure [Re: RapidRobert] #2658920
05/24/19 10:56 PM
05/24/19 10:56 PM
NH
N
N
NH
Thanks for the replies. I've been chasing this problem for a while. Car starts fine, idles fine, runs great up to 70-80 mph. When I press the pedal to 3/4 throttle she starts sputtering, anything past that she just lays over.
I initially thought it was fuel. Swapped carbs with a buddy, swapped fuel pumps, checked for kinks in fuel line, blew compressed air back thru line into tank, same issue.
Then tried timing, have adjusted it every which way, swapped the coil and distributor with my other Charger (both using Firecore RTR system), same issue. Sent a video to a Charger buddy in Texas, he thinks it's fuel related. LOL talk about chasing my tail.
I just swapped out the fuel pump push rod, even thou the existing comp cam one looked fine, since I had it out I replaced it was one I got from board member Maccanix, no change.
Re: measuring fuel pressure [Re: NHCharger] #2658926
05/24/19 11:13 PM
05/24/19 11:13 PM
AndyF Online content
AndyF  Online Content
Could be a bunch of things. Valve springs are shot, timing chain loose, partial blockage in your exhaust system, etc..........
Re: measuring fuel pressure [Re: AndyF] #2658931
05/24/19 11:21 PM
05/24/19 11:21 PM
NH
N
N
NH
New engine build. Hope it's not something the engine builder did. The last 440 he did for me runs great.
Re: measuring fuel pressure [Re: NHCharger] #2658941
05/25/19 12:05 AM
05/25/19 12:05 AM
Quote
Does this in all gears or just high gear?
Re: measuring fuel pressure [Re: NHCharger] #2658942
05/25/19 12:40 AM
05/25/19 12:40 AM
I need to make sure you understand that pressure is not the true indicator of enough fuel volume delivery, if it is running out of fuel at 3/4 to wot in high gear make sure the needles and seats are big enough to flow enough fuel into the motor to make sure it isn't being starved by them scope work
I had that happen on a new Holley list # 9375-3 1050 CFM dominator carb, the factory sent it out with one .110 needle and seat in the primary bowl and the secondary bowl had a .120 size in it. It ended up needing .120 in both bowls to not run the front cylinders out of fuel in the 1/4 mile puke shruggy
Lots of things can influence are results work
Re: measuring fuel pressure [Re: Cab_Burge] #2658978
05/25/19 07:35 AM
05/25/19 07:35 AM
VA
dragon slayer Offline
VA
Doesn't this all depend on what the motor size and HP is? Are we talking 1000hp race car, or a 500hp street car? Service manuals have the test procedure for mechanical pumps, which I assume you are talking about. Pressure test at carb inlet, and volume test. There also is a static bench test and vacuum test.
What electronic ignition? What motor, carb. etc
Have seen Mopar electronic boxes that stop working effectively at higher rpm.
So this can be a lot of things including intake to fuel pump, filter etc...
Re: measuring fuel pressure [Re: dragon slayer] #2659053
05/25/19 12:06 PM
05/25/19 12:06 PM
NH
N
N
NH
Sorry, should have provided more info. 440 out of a 76 motor home. Motor didn't run when I bought car due to numerous electrical issues. Motor was rebuilt, .30 over, stock pistons, cast crank, Weiland Intake, 750 Eddy, Firecore RTR ignition system. My buddy who is a mechanic and diehard Mopar guy gave me a cam that he had but wasn't going to use on his stock 67 GTX. It's a Direct Connection P4286677, 272 duration, 48 overlap.He thinks the ignition system is faulty but I have the same set up in my other Charger and swapped distributors and coils and still had the same problem.
I have tried all different combinations of jets and metering rods without any change. As I mentioned I swapped carbs with a friend who have a 440 with no difference.
I just test drove it and tried it running in just second and first gear. Same issue.
Re: measuring fuel pressure [Re: NHCharger] #2659063
05/25/19 12:40 PM
05/25/19 12:40 PM
Quote
I'm thinking not fuel (unless the fuel delivery system pieces was woefully inadequate/or has a malfunction from day 1). When you swapped ignitions has it had a non RTR firecore dizzy setup in there?
Re: measuring fuel pressure [Re: RapidRobert] #2659065
05/25/19 12:54 PM
05/25/19 12:54 PM
God's Country Maryland
GODSCOUNTRY340 Offline
As stated in your other post, if the other fuel pump pushrod got ground off there's a good chance it ground off the lobe on the cam that it rubs against. That would be the first thing I'd look at. If that lobe is ground down it's not pumping much fuel.
Re: measuring fuel pressure [Re: GODSCOUNTRY340] #2659176
05/25/19 09:03 PM
05/25/19 09:03 PM
NH
N
N
NH
Robert- The Firecore system is all this car has ever had in it. In order to use the RTR set up you need to modify the engine wiring harness by tying the blue and brown wires together and run a single wire to the coil. Then cut out the wires going to the ballast resistor and orange box. I contemplated swapping the engine wiring harnesses with my other Charger with the RTR system but that would be a PITA. I'm wondering now if the wire I ran from the splice with the blue and brown wires is heavy enough, not sure that would make a difference.I'll check the size of that versus the other harness and also check the splice tomorrow.
There was actually nothing wrong with the com cam fuel push rod I took out. But since it was out and I bought an NOS one I installed the NOS rod and will keep the other as a spare.
Re: measuring fuel pressure [Re: NHCharger] #2659187
05/25/19 09:30 PM
05/25/19 09:30 PM
I'm wondering if you can "easily" swap back in an OE type ECU or even a points dist setup to confirm/elim the RTR. With some jumpers/temporary stuff so you dont have to do any (or very little) cutting/hacking.
Re: measuring fuel pressure [Re: NHCharger] #2659204
05/25/19 10:45 PM
05/25/19 10:45 PM
What rocker arms are you using? Do you know how much lifter preload you have on the pushrod end between the retainer and the top of the retainer groove in the lifters?
I'm thinking like AndyF is going towards, maybe it is pumping up the lifters causing the problem work scope
Re: measuring fuel pressure [Re: NHCharger] #2685787
08/08/19 06:54 PM
08/08/19 06:54 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Did issue get resolved ?
1971 Superbee - My 383/432 Stroker is having the same issues since rebuild last year
Auto Trans Rebuilt - Turbo Action Auto Valve Body - Works Perfect
3:91 Sure Grip
Motor runs awesome , idle , cruise , off idle , full throttle perfect up until about 5,200 Rpms and then it starts falling flat , like running out of fuel - Get out of the throttle , and then back into the throttle and off it goes
Off idle this motor will destroy the tires - 20/30 mph and into the throttle car sideways
There are times say cruising in first gear , jam the throttle control the tires , Rpms come up until 5,500 Rpms shift into second and it starts sputtering going flat like mentioned after 5,000 Rpms in second
440 Source Stroker Kit
Edelbrock E Street Heads - 75cc
Comp Cams and lifters - XE 275HL
NGK BKR6E Plugs
16 initial - 34 Total Timing
10.5 - 1 Compression
All eight cold cranking compression , air cleaner off throttle plates closed 195psi dead nuts all eight , verified two gauges
1971 Carter AVS 4968 750cfm initially , converted over to Edelbrock jets and metering rods - Ran pretty damn good honestly up until mentioned
Now running Edelbrock AVS 2 800 - Plug color decent with factory jetting , went slightly leaner on cruise metering rods - Same issue at higher Rpms - Tried .107 Secondary Jets , same issue
This carb off idle , cruise is just plain awesome , so smooth , but again higher Rpms
Mechanical fuel pump - Pump Rod and cam is perfect
Factory 5/16” fuel line
1971 Factory vapor line to three nipple breather on valve cover
Tried three different coils
Now on second carb
Thanx Scott
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: measuring fuel pressure [Re: bee1971] #2685794
08/08/19 07:10 PM
08/08/19 07:10 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Andy mentioned partial blockage in exhaust system in earlier post ?
My mufflers , Rhino Turbos many many many years ago , are pretty old but look great from the outside LOL
Sounds damn good
Rebuilt numbers 383 for the last 20 years , never had this issue at higher Rpms
Numbers 383 Was .030 over prior to this Stroker Kit , back then running the old Mopar 284/484 cam and built 906 heads
Flat tops where .025 in the hole until I kissed a piston one day after twenty years
Anyways
Hence this Stroker Kit with same numbers block
Running New Sealed Power stamped steel rockers and shafts with this Stroker Kit
Lifter preload I have written down somewhere
Comp Cams pushrods
Have not changed mechanical fuel pump or Chrome Mopar ECU with this higher Rpms issue
ECU has worked perfect prior for many years
Siberian Huskies
Re: measuring fuel pressure [Re: bee1971] #2685810
08/08/19 08:16 PM
08/08/19 08:16 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
If the motor goes flat at 5200 in each gear, it’s very unlikely a fuel issue.
This would mean you could roll on the throttle in first, experience the flat line of power at 5200, and then right after the shift into 2nd, and the corresponding drop in rpm....... the motor recovers and pulls good back to 5200.
My experience has been this situation has always been an ignition or valvetrain related issue.
I suppose it “possible” it’s a collapsed muffler condition, but I can’t imagine that having the on/off switch-like affect you get from ignition or valvetrain problems.
Fuel supply problems usually manifest themselves as; the motor just starts laying down, and no recovery occurs until the throttle is closed........ fuel bowls start refilling, then you step back down....... car accelerates for a bit, then lays back down as the bowls start to empty.
With the XE cam, you’re certainly a candidate for a valvetrain issue.
Another thing, if it’s somethiing other than fuel, you should be able to run it hard through the gears(wot), and not experience any issues if you keep the rpms below the point where the motor lays down.
So, if yours lays down at 5200, you should be able to go thru all he gears at WOT and shift at say 5000, and not experience any issues.
If it’s fuel supply, you wouldn’t be able to do that.
You’d probably get about 1/3 of the way through 2nd and it would lay down.
Re: measuring fuel pressure [Re: fast68plymouth] #2685825
08/08/19 09:03 PM
08/08/19 09:03 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Thanx man for the quick response
Great explanation ! !
I will experiment with this subject matter / test , more over the upcoming weekend , shifting at a lower RPM
The quick and easy I guess would bee a ignition module change first
Second would bee pulling the valve covers and
Really appreciate your advice
“Another thing, if it’s somethiing other than fuel, you should be able to run it hard through the gears(wot), and not experience any issues if you keep the rpms below the point where the motor lays down.
You’d probably get about 1/3 of the way through 2nd and it would lay down.”
Siberian Huskies
