Re: This rusty gear usable?
[Re: mopar dave]
#2658351
05/23/19 11:22 AM
05/23/19 11:22 AM
Posts: 4,457 Washington
madscientist
Washington
Cab, have you ever seen a gear come out of a rear housing rusted like that. I'm skeptical I did not get my gear back from the shop that preformed the work. The old switcharoo. It is a Strange/US gear and is not labeled any where. I've seen that many times. Transmission gears too. Especially when they sit and you have weird weather changes. Some oils don't actually stay on the gears as well as others and when they sweat, the oil works off the gears and then the rust sets in. Sitting in a box on the shelf and that will happen too.
[Re: madscientist]
#2658369
05/23/19 12:17 PM
05/23/19 12:17 PM
Posts: 19,405 north of coder
moparx
just went through a rear for a 58 chevy that was like that. the car had a 3:55 in it and my buddy wanted to use a 3:36 that he had rebuilt because the 3:55 was leaking at the pinion seal and was a tad noisy. the 3:36 had several gears that had some slight pitting, and he was worried they might "sing". put that rear in, works great, no noise, and decreased highway RPM as a bonus. this car is a cruiser and will not be raced, but his rear [pun intended ] will last for a long time.
[Re: moparx]
#2658376
05/23/19 12:32 PM
05/23/19 12:32 PM
Posts: 30,424 Florida STAYcation
dOrk !
The village idiot's idiot
Florida STAYcation
Rust pits storing oil ? ....couldn’t have said it bester!! I picked up a 8 3/4 pig some years ago .... a bit rusty on the ring gear ...., cleaned it up with some 600 and it was good to go !
[Re: mopar dave]
#2658433
05/23/19 03:07 PM
05/23/19 03:07 PM
Posts: 11,566 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
It is a Strange/US gear and is not labeled any where. A USGear, Richmond or any other decent aftermarket gear will have marks on it identifying who made it and/or the part number. The only gear I've ever seen without it was some cheapo Chinese junk. Unless it sat for a loooong time, it shouldn't have been rusted. Did you drive it to the shop?
[Re: mopar dave]
#2658558
05/23/19 09:12 PM
05/23/19 09:12 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
This is a GM 7.5 part#75-529 gear set, 37 & 7 teeth on the ring and pinion gears, Made In USA, and the little street sign with a "G" symbol is US Gear. If the ring gear didn't have that type of marks, and you were sure of what was in it, I'd go to see the fellows and make them aware of their mistake. But that's me.
[Re: mopar dave]
#2658597
05/23/19 10:42 PM
05/23/19 10:42 PM
Posts: 4,206 New York
polyspheric
New York
Those pits are deeper than the heat treatment. Every time that tooth is loaded hard, a tiny piece flakes off the edge of the pit. That tooth will fail across the pits earlier than a virgin tooth. Will it happen later today, or 20 years? Who knows.
Boffin Emeritus
