Re: Big torque big carnage- yoke upgrade suggestions needed
[Re: radar]
#2658180
05/22/19 08:42 PM
05/22/19 08:42 PM
Posts: 12,414 Taxes & Virus's R-US, NY
Dragula
I also run a 512 and they are a beast. We have been getting all our stuff from A&A and my Engine builder is the one who puts them together. . ....They are very helpful in getting the right parts for your build.....CRT is a trans guy on here as well and can supply you with the right parts I am sure as well. How did you learn to do your own?
[Re: dvw]
#2658218
05/22/19 10:00 PM
05/22/19 10:00 PM
Posts: 1,682 Philadelphia
radar
Philadelphia
My bet is you broke the joint and that broke the yoke? and then the tail shaft. Been down that trail myself. Worse case scenario. New tail shaft housing and possibly a tail shaft. I have a shaft here from a buddy's 66 Coronet. Broke the joint driving down the freeway. The shaft is bent at a 30 degree angle. Replaced the shaft and tail housing (along with welding up the floor pan and gluing the console back together). No other trans parts were replaced. been probably 10 years since, still fine. Doug I wish that was the deal. When the tailshaft went it didn’t just crack it pulled threads out of the main case in spots and chunks of case with 1/2 of the threaded holes in others. Honestly I can’t believe it didn’t break more stuff or leave all my ATF on the ground. I had just picked my 7 year old daughter up from school so I drove home real easy but she always asks to hear me bark the tires when we get back into our neighborhood so I stopped and gave the throttle a little stab- bang! Clang clang rattle rattle. My driveshaft loop is tied into the floor frame of the truck cab and all made from 1” .120”wall square tube- dumb strong so we were totally safe. She was really freaked out so I was really over doing the no big deal act- “we’re safe, close to home, I can push it into a parking spot and we can just walk home, I built it all myself once I’ll just do it again, it’s just a thing not a person, breaking stuff is just a normal part of the fun of hotrodding” She bought the act but then kept asking why I was kept sighing after I got under to inspect it. I’m actually looking forward to building another 727- it’ll give me a chance to try a different ratio lever and get more comfortable doing it. I don’t mind short road trips to find parts and drag them home. I don’t much enjoy dropping or installing transmissions though that sucks and buying whizbang billet driveline parts is fun but I’d rather keep the $$ in my pocket...
[Re: Dragula]
#2658226
05/22/19 10:10 PM
05/22/19 10:10 PM
radar
Philadelphia
My build might be a bit different than yours.....I did two of what we call a "super trans" and the parts alone were +$1300....I have yet to break one... Well I technically didn’t break the trans I broke the universal and slip yoke and they broke the trans! I tried to do a street build that would use the big inches to have more fun at lower rpms so I wouldn’t need a lot of fancy valvetrain parts or billet clutch drums & bolt in sprags. Plus the weak link was supposed to be the street tires not my driveline parts. I’m guessing we started cracking parts on the dyno this morning- the rolling road always makes me nervous it can be real hard on equipment. It was worthwhile but even if my problems didn’t start there my torque curve saw MASSIVE improvement down low so my 2400 stall probably never saw that much torque before this last time I flashed it. My buddy with the dyno was rolling into the stall before WOT this might have been the first time I shocked the driveline with all the power we found at flash stall.
[Re: radar]
#2658252
05/22/19 11:55 PM
05/22/19 11:55 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
Better change the sprag, or you are asking for trouble.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#2658272
05/23/19 01:39 AM
05/23/19 01:39 AM
Posts: 43,283 Bend,OR USA
Cab_Burge
Better change the sprag, or you are asking for trouble. At least check it to se if it is hurt or not I have all my race 727 built with bolt in spraques and solid steel or aluminum drums I have one of the older Pro Trans 426 hemi S.S. tranny from back in the early to mid 1990s when they where still using the 727 parts in the stock type cases, I rolled the rear spraque in it when it broke a ring and pinion in my Duster with that tranny in the car
[Re: Cab_Burge]
#2658310
05/23/19 09:21 AM
05/23/19 09:21 AM
Posts: 2,837 Connecticut
FurryStump
Connecticut
Some times that happens on chassis dyno’s. Not sure why, change of driveline angles because its strapped down or some thing else. I know of a max wedge car that had it happen. Check the sprag.
[Re: FurryStump]
#2658326
05/23/19 10:20 AM
05/23/19 10:20 AM
Posts: 4,450 Michigan
MarkZ
Worthy
Worthy
Just had a shaft made and upgraded to 1350 joints at the same time. Got the axle yoke from Dr. Diff with the rest of the parts to build the axle and the drive shaft shop provided the slip yoke. Drive shaft with joints and the yoke ran me $350.
