Sebring new vert top - what’s the going rate ? #2657367
05/20/19 10:43 PM
05/20/19 10:43 PM
Florida STAYcation
dOc … Offline OP
The village idiot's idiot
dOc …  Offline OP
Florida STAYcation
.... got a bud that found a cherry one but the top is junk !
Re: Sebring new vert top - what’s the going rate ? [Re: dOc …] #2657371
05/20/19 10:58 PM
05/20/19 10:58 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Do an online search for prices.
Re: Sebring new vert top - what’s the going rate ? [Re: stumpy] #2657375
05/20/19 11:06 PM
05/20/19 11:06 PM
Florida STAYcation
dOc … Offline OP
dOc …  Offline OP
Florida STAYcation
I would imagine that THOSE PRICES would be full retail ... not looking for that.
Re: Sebring new vert top - what’s the going rate ? [Re: dOc …] #2657380
05/20/19 11:19 PM
05/20/19 11:19 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I depends on if you are going to install it or the shop will and the quality of the material. Depends on the area you are in also. Not all online prices are full retail that is why you do a search to a see the differences.
Re: Sebring new vert top - what’s the going rate ? [Re: stumpy] #2657383
05/20/19 11:26 PM
05/20/19 11:26 PM
Florida STAYcation
dOc … Offline OP
dOc …  Offline OP
Florida STAYcation
I’ve never done a job like that and neither has he so shop installed would be the ticket. It’s a white car so would a white top hold up better in the Florida UV ?
Re: Sebring new vert top - what’s the going rate ? [Re: dOc …] #2657387
05/20/19 11:33 PM
05/20/19 11:33 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I would think so and it would look good too. I put a top on my PT Cruiser and it wasn't that hard. Found instructions on line and in the factory repair manual on disc from Ebay. Even redid the hydraulics. IIRC the top was around $350 with the window. Ebay shows them in the $200-$300 range with window for the sebring
Re: Sebring new vert top - what’s the going rate ? [Re: stumpy] #2657391
05/20/19 11:45 PM
05/20/19 11:45 PM
Florida STAYcation
dOc … Offline OP
dOc …  Offline OP
Florida STAYcation
Wow ... 350 for a PT ? Reasonable! ... glass window? I would think the Sebring would be a bit cheaper then ... a bigger demand
Re: Sebring new vert top - what’s the going rate ? [Re: dOc …] #2657392
05/20/19 11:49 PM
05/20/19 11:49 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Take a look on Ebay. some goods prices. I don't know about the sebring but the PT top was three layers. The outer water proof cloth and and pad and the inner cloth.
Re: Sebring new vert top - what’s the going rate ? [Re: stumpy] #2657397
05/20/19 11:57 PM
05/20/19 11:57 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Cost us close to $1k when we had one done. If you can find one in a wrecking yard with a good top you can swap the entire assembly
Re: Sebring new vert top - what’s the going rate ? [Re: Jim_Lusk] #2657503
05/21/19 11:12 AM
05/21/19 11:12 AM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Wow, can't believe it's been almost 20 years since I had my 300Hurst ragtop . . . anyhow, back then, I got the top (glass back window) from Legendary (was $450) and shop charged $450 to install . . . overall thought that was pretty good value ! Check with a shop to see what they would charge . . . sure you can do it yourself, but for the "hassle" factor - much rather have the pros do it . . .
Re: Sebring new vert top - what’s the going rate ? [Re: a12rag] #2657784
05/21/19 10:34 PM
05/21/19 10:34 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
Ive had 2 done.
1st one was on an 04 , glass back window - cost $1200 ,,,maybe 5 or 6 years ago
2nd one was on a 96,,, plastic back window , had different shop do it. $550 out the door. this one was just about 3 or 4 years ago
on both they supplied the top
the 04 was a black top
the 96 was a tan top
if this matters.
I was in both cars pretty cheap so it was cost effective to have them done and IMO really helped them sell .
Re: Sebring new vert top - what’s the going rate ? [Re: dOc …] #2657911
05/22/19 09:31 AM
05/22/19 09:31 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Have you considered shopping the salvage yards? I have bought a couple of Sebring convertibles over the years that have needed tops. I just bought good ones from a yard and installed them frame and all. Takes much less time and money.
Master, again and still
Re: Sebring new vert top - what’s the going rate ? [Re: DaveRS23] #2658076
05/22/19 04:55 PM
05/22/19 04:55 PM
Florida STAYcation
dOc … Offline OP
dOc …  Offline OP
Florida STAYcation
Thx guyz... good ideas but the JY idea down in the sunshine state is kind of wishful thinking!
Re: Sebring new vert top - what’s the going rate ? [Re: dOc …] #2658157
05/22/19 07:45 PM
05/22/19 07:45 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Lots of 'snow birds' down there. Not every car is a native. Maybe wouldn't hurt to look, just in case there was a good one.
Re: Sebring new vert top - what’s the going rate ? [Re: DaveRS23] #2658204
05/22/19 09:27 PM
05/22/19 09:27 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Around here the better quality factory material from the limited seems to hold up better and can be found somewhat intact compared to the other models..Complete top/frame assemblies go for about $45.00 at the pick and pull boneyards...
Re: Sebring new vert top - what’s the going rate ? [Re: dOc …] #2658208
05/22/19 09:43 PM
05/22/19 09:43 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
You didn't say what year the Sebring Convertible is, what year is it?
Re: Sebring new vert top - what’s the going rate ? [Re: SNK-EYZ] #2658386
05/23/19 12:52 PM
05/23/19 12:52 PM
Florida STAYcation
dOc … Offline OP
dOc …  Offline OP
Florida STAYcation
It’s a real clean 2004 with a 4 banger .... no v6 2.7s !!
I’ve only been to two JYs down here and I’ve not seen many Sebring vert cars and the tops I’ve seen IIRC ... weren’t all that good
