Best Fuel for my setup
#2658133
05/22/19 06:28 PM
05/22/19 06:28 PM
Posts: 55 CT
roadrunner2
CT
I have a 10:1 big block with iron heads. It’s 95% drag race 5% street driven. For performance what would be better, 93 octane street fuel or the 110/112 I’ve been using? Heads do not have hardened seats. Or another option I haven’t tried. Thanks.
RR
1968 Road Runner 383 727 3.91 8 3/4 3520 with driver 11.04 @ 124.26 with 1.67 60’ Done on G70-14 redlines thru factory manifolds New quickest ever 383 build in FAST. 10:1 451” replaced with 14:1 499”.
Re: Best Fuel for my setup
[Re: roadrunner2]
#2658185
05/22/19 08:49 PM
05/22/19 08:49 PM
Posts: 12,400 Taxes & Virus's R-US, NY
Dragula
93 hands down....I was at 10.7:1 with mine on 93 and went 9.70 on it with no issues...That same engine is now in my engine builders car with iron heads running on 91 and we went 10.72 with it last week....See my what will it run thread for more detail...
[Re: Dragula]
#2658338
05/23/19 10:53 AM
05/23/19 10:53 AM
Posts: 12,589 Great Neck,LI,new york
hemi-itis
Too much octane is a waste of money and in some combos will slow you down! After a WOT pull do a plug check.That will tell you if you need more octane!
[Re: roadrunner2]
#2658436
05/23/19 03:20 PM
05/23/19 03:20 PM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
It should run faster w/ 93 octane. Unless you have open chamber heads and no quench, then you may need the extra octane to keep it from detonating.
FWIW...my 11:1 hemi slows down a tenth and a little over 1 mph on VP 110 versus 93 pump gas.
[Re: tubtar]
#2658534
05/23/19 08:13 PM
05/23/19 08:13 PM
hemi-itis
My effective CR is 12:7 on pump junk and runs great with 4 lbs of boost through the exhaust out the rear bumper. Aluminum hemi head
