Piston-head clearance...how close? #2657436
05/21/19 08:28 AM
05/21/19 08:28 AM
an8sec70cuda Offline OP
How close have you run piston to head clearance? Application is steel rods, flattop pistons, and less than 6500 RPM.
Seems most like to see .035-.040" minimum. I've run one at .035" and never had an issue.
Just curious to see if anyone has run them tighter?
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Piston-head clearance...how close? [Re: an8sec70cuda] #2657446
05/21/19 09:12 AM
05/21/19 09:12 AM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
.035 is usually where I draw the line although the piston alloy can also affect it slightly. Todd
Re: Piston-head clearance...how close? [Re: an8sec70cuda] #2657483
05/21/19 10:25 AM
05/21/19 10:25 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Being slightly too close (.030") causes damage not easily detected: closes up the top ring groove and inhibits ring seal.
Boffin Emeritus
Re: Piston-head clearance...how close? [Re: an8sec70cuda] #2657557
05/21/19 12:52 PM
05/21/19 12:52 PM
I saw witness marks on all the outer edges of my old pump gas motor pistons at .035, none after changing it to .040+ up
The ring lands where fine, no damage but the edges where shiny, no carbon and the same marks on the heads work
that motor got shifted at or above 7000 RPM on every run also so shruggy
Re: Piston-head clearance...how close? [Re: Cab_Burge] #2657656
05/21/19 05:33 PM
05/21/19 05:33 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
My daily driven 11.3:1cr 360ci runs with 0.029-0.030" P-H clearance.
My fuelsystem limits the engine to somewhere around 5000-5500rpm.
Re: Piston-head clearance...how close? [Re: Cab_Burge] #2657659
05/21/19 05:48 PM
05/21/19 05:48 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Mine's been good with .040", even with some piston-to-bore clearances looser than I'd prefer. I wouldn't feel comfortable with much less, having seem other engines with witness marks like Cab mentioned when running a tad too close.
Re: Piston-head clearance...how close? [Re: Cab_Burge] #2657714
05/21/19 07:28 PM
05/21/19 07:28 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Compression height, skirt length, and rod ratio all affect how much extra P-H you need, but .040" is pretty much safe in everything.
Jenkins said 40 years ago don't run closer than you need for knock suppression - any closer = pumping loss. Some engines with small bores and excellent swirl can be knock-protected at .060".
Boffin Emeritus
Re: Piston-head clearance...how close? [Re: polyspheric] #2657922
05/22/19 09:50 AM
05/22/19 09:50 AM
Indy
FlyFish Offline
FlyFish  Offline
Indy
The 408 motor I just built for my Barracuda is 0.033 (piston is 0.005 out of the hole). Just got it running on Saturday, drove straight to the drag strip. Only made 5 passes on it (I lost in rd3). It held together and got me back home....I call that a win, lol. Ran 6.59 in bad air, on the brakes (would have been a 6.58). The car kept getting faster on every pass...even as the air got worse.
Edit: I shift at about 6500.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: Piston-head clearance...how close? [Re: FlyFish] #2658024
05/22/19 02:04 PM
05/22/19 02:04 PM
All the SB Mopar I've raced and help drag race always made more power after 7 to 10 runs or pulls on a engine dyno to seat the rings fully work
Once they level off we start to tune for max power wrench
