ID purple shaft cam #2656975
05/19/19 05:55 PM
05/19/19 05:55 PM
AB
P
Pockets Offline OP
Pockets  Offline OP
P
AB
I’m trying to ID this cam. I can’t find the numbers anywhere.
Re: ID purple shaft cam [Re: Pockets] #2657134
05/20/19 07:41 AM
05/20/19 07:41 AM
an8sec70cuda Online content
an8sec70cuda  Online Content
Numbers on an MP cam will likely be no help. Measure a lobe.
CHIP
'69 road runner, 440-6, 4 speed, Dana 60
'70 'cuda, 575" Hemi, 727, Dana 60
'71 Demon 340, no drivetrain, on blocks behind the barn
'73 Chrysler New Yorker, 440, 727, 8.75....................FOR SALE
'06 GMC 2500HD LBZ Duramax
'17 Ram 1500 5.7 Hemi
Re: ID purple shaft cam [Re: an8sec70cuda] #2657158
05/20/19 08:35 AM
05/20/19 08:35 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I am pretty sure I can ID that one if you can hang on until I dig my decoder sheet out of the basement file.
They changed over time.
Oldest: Very oldest, Isky and Racer brown stuff....Oldest DC was paint dots-good luck...measure....
Middle: Internal cam grinder number-need to check the top secret decoder ring, that's what is shown in the pic, why they did this I have no idea....
Later: Around 2012-2013 timeframe...Cam-only engraved number (doesn't match fully packaged part number but is usually close, and is on the I sheet), but without the purple paint
Latest that I know of: cam-only engraved number (doesn't match part number but is close, and is on the I sheet), WITH purple paint
Off the top of my head, I think it is probably a 280/.474/110.
But that is just from memory so might want to hang on and give me a chance to look.
Rich H.
Esse Quam Videri
Re: ID purple shaft cam [Re: Pockets] #2657748
05/21/19 07:43 PM
05/21/19 07:43 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Finally made it to the basement file to check.
Grind number 111031 corresponds to cam P4120236.
This cam was used inside packaged kit marketed as P4120237.
This is the ubiquitous 292/.509/108 B/RB Wedge single bolt camshaft.
You've got yourself a .509. everyone's favorite! (???)
Thank you for calling Direct Connection,.and have a great day
-Rich
Rich H.
Esse Quam Videri
Re: ID purple shaft cam [Re: ZIPPY] #2657956
05/22/19 10:28 AM
05/22/19 10:28 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Who knows what Direct Connection / Mopar Performance secrets remain buried in someone's basement?
The Z-man does! laugh2
Re: ID purple shaft cam [Re: ZIPPY] #2657972
05/22/19 10:50 AM
05/22/19 10:50 AM
Zumbrota,MN
als499 Offline
als499  Offline
Zumbrota,MN
Amazing! Can you post the list , I have a few unknown Purple cams lying around, Thanks!
Re: ID purple shaft cam [Re: BradH] #2657992
05/22/19 11:56 AM
05/22/19 11:56 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
A Gentleman never tells wink
Only recently have I begun to focus a little bit and it's starting to pay off.
I can't, I don't have it in electronic format anymore that I can recall. Just on paper.
It would take several hours to enter all that data.
Rich H.
Esse Quam Videri
Re: ID purple shaft cam [Re: ZIPPY] #2658118
05/22/19 05:03 PM
05/22/19 05:03 PM
Denver, CO
BigBlockGTS Offline
BigBlockGTS  Offline
Denver, CO
Take a photo and post it if you can Zippy!
