data logging on a budget? #2657658
05/21/19 05:47 PM
05/21/19 05:47 PM
Texas
RustyM Offline OP
RustyM  Offline OP
Texas
Best ideas /companies for data logging on a budget?
say, 5 to 8 channels?
Re: data logging on a budget? [Re: RustyM] #2657669
05/21/19 06:17 PM
05/21/19 06:17 PM
AndyF Offline
AndyF  Offline
I suppose it depends on what sort of inputs you need to data log. I've been using the 3 channels of data logging capability that are built into the Holley Sniper EFI setup. They are pressure only channels on the Sniper so I'm limited to things such as fuel pressure, oil pressure, transmission pressure, pan vacuum, brake pressure, PS pressure, etc. If you want temp and velocity inputs then you have to step up to something else.
Re: data logging on a budget? [Re: AndyF] #2657672
05/21/19 06:22 PM
05/21/19 06:22 PM
Texas
RustyM Offline OP
RustyM  Offline OP
Texas
i would like :
afr ( right and left banks preferably but could get by with one )
rpm
manifold vacuum
driveshaft speed
g force
fuel pressure, oil pressure etc would be nice but budget just isn't there.
Rough winter for me health wise and i'm way behind on work.
Re: data logging on a budget? [Re: RustyM] #2657722
05/21/19 07:53 PM
05/21/19 07:53 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Originally Posted by RustyM
i would like :
rpm
manifold vacuum
driveshaft speed
g force
Look into RPM PERFORMANCE Data logger DL10 basic setup.
Very reasonable and they have excellant customer service.
Re: data logging on a budget? [Re: RustyM] #2657760
05/21/19 09:08 PM
05/21/19 09:08 PM
AndyF Offline
AndyF  Offline
i would like :
rpm
manifold vacuum
driveshaft speed
g force
A Holley Terminator EFI system would get you data logging for AFR, RPM, Manifold pressure, Manifold Temp, Coolant Temp, Ignition timing, fuel pressure, and oil pressure. It also has 4 additional inputs which could handle driveshaft speed, oil temp, brake pressure, etc. And you get start retard, high speed retard, launch control, warning limits on the sensors, etc. For another $500 you can add traction control..........
Re: data logging on a budget? [Re: AndyF] #2657870
05/22/19 07:22 AM
05/22/19 07:22 AM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
hard to beat a Racepak sportsman, 800.00 range. ReSale on them is great if you ever decide to not use it
....BAD A$$ STREET CAR.....
Re: data logging on a budget? [Re: n20mstr] #2657871
05/22/19 07:31 AM
05/22/19 07:31 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Talk to the guys over at DIYAutotune.com about on of their mega squirt EFI controllers. You can make a very capable data logger out of one and later have the benefit of being able to go fuel injected or just have it control your ignition. A side effect of most EFI systems is the ability to data log.
68 Barracuda Formula S 340
Re: data logging on a budget? [Re: Bad340fish] #2657907
05/22/19 09:26 AM
05/22/19 09:26 AM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
https://www.rpmperf.com/data-loggers.html
Cant beat this product for the price.
Re: data logging on a budget? [Re: Sammy] #2658084
05/22/19 05:05 PM
05/22/19 05:05 PM
Barboursville, VA
belvedere383 Offline
Barboursville, VA
Holley sells a logging dash part #553-109 i think. It has a built in gps speedo, accelerometer, and comes with oil pressure, air temp sensor, and water temp.
i think it sells for around 1000-1100 but it has a really nice digital dash that comes with it.
65' Belvedere
496'' Stroker
Indy Heads
Re: data logging on a budget? [Re: RustyM] #2658188
05/22/19 08:51 PM
05/22/19 08:51 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Ha....I use my GoPro....poor mans data logger right there...lol
Re: data logging on a budget? [Re: Dragula] #2658261
05/23/19 12:59 AM
05/23/19 12:59 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I am carbureted and went for what is the best and that was RacePak.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: data logging on a budget? [Re: RustyM] #2658283
05/23/19 06:06 AM
05/23/19 06:06 AM
Aus
hysteric Offline
hysteric  Offline
Aus
Innovate. It gets expensive when you start buying sensors especially the Racepak.
Otherwise the RPM is good value. It also depends how much you want to do yourself to save money.
Re: data logging on a budget? [Re: hemi-itis] #2658302
05/23/19 08:49 AM
05/23/19 08:49 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I have a racepak sportsman and through some faults of my own, and RP issues... I’ve hardly used it. Something else I NEED to spend some time with.
Re: data logging on a budget? [Re: J_BODY] #2658336
05/23/19 10:46 AM
05/23/19 10:46 AM
hemi-itis Offline
hemi-itis  Offline
Major electronic learning curve!!
Re: data logging on a budget? [Re: hemi-itis] #2658390
05/23/19 01:04 PM
05/23/19 01:04 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
I use an AEM AQ1, I can log 8 channels plus it has a CAN to BUS input.
I log the following:
Fuel Pressure
Oil Pressure
Crank Case Vacuum
Oil Temp
Trans Oil Temp
Drive Line Speed
RPM
G-Force
Trans Brake Release
On the CAN to BUS the following:
AFR Right/Left
8 EGT's
I did it for way less than RacePak
Re: data logging on a budget? [Re: Biginchmopar] #2658411
05/23/19 02:12 PM
05/23/19 02:12 PM
Texas
RustyM Offline OP
RustyM  Offline OP
Texas
Thanks guys.
Biginchmopar: I'm used to the software from AEM so- thats something.
Thanks everyone, as usual, I get a good range of information .
In this case, to my surprise, I didn't find a solution I was hoping for which was- cheap! grin
I really just wanted to add driveshaft speed to what we are already taking ( afr/engine vac/rpm ) and was shocked that everything I looked at was well north of a grand to get set up and running.
What i learned here confirmed my research- data logging "costs what it costs" no matter which route you take.
I could get into EFI with data logging already there for about what Logging alone costs- but , we have a ton of money tied up in carbs right now.
I do think we may go that way when we do the Charger build though.
So, i'm down to comparing apples to apples at least .
Thanks again for everyones time to help.
Re: data logging on a budget? [Re: RustyM] #2658412
05/23/19 02:14 PM
05/23/19 02:14 PM
Texas
RustyM Offline OP
RustyM  Offline OP
Texas
next question for you Race guys:
How much did having driveshaft speed and g force data help you with chassis tuning?
Re: data logging on a budget? [Re: J_BODY] #2658529
05/23/19 07:35 PM
05/23/19 07:35 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Is that on your boat Jay?
I bought the Racepak Drag logger dash. Not cheap
"Just a Bracket car dressed up like a streetcar"
Re: data logging on a budget? [Re: RustyM] #2658574
05/23/19 09:51 PM
05/23/19 09:51 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
In one instant it cost me quite a bit of money.... we saw how the engine was being pulled down when the t-brake was released and adjusted the torque converter to a bit softer hit which in turn made it very VERY consistent off the line. Naturally after a season we pulled that trans for a new more unmanageable combo smile
Re: data logging on a budget? [Re: J_BODY] #2658624
05/23/19 11:44 PM
05/23/19 11:44 PM
Texas
RustyM Offline OP
RustyM  Offline OP
Texas
J: I just blew dr. Pepper right out my nose laughing!!!
You "have a way " with words!
hahahahahaha
