Re: data logging on a budget?
[Re: RustyM]
#2657722
05/21/19 07:53 PM
05/21/19 07:53 PM
Posts: 1,824 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
i would like : afr ( right and left banks preferably but could get by with one ) rpm manifold vacuum driveshaft speed g force
fuel pressure, oil pressure etc would be nice but budget just isn't there. Rough winter for me health wise and i'm way behind on work. Look into RPM PERFORMANCE Data logger DL10 basic setup. Very reasonable and they have excellant customer service.
[Re: RustyM]
#2657760
05/21/19 09:08 PM
05/21/19 09:08 PM
Posts: 31,050 Oregon
AndyF
fuel pressure, oil pressure etc would be nice but budget just isn't there. Rough winter for me health wise and i'm way behind on work. A Holley Terminator EFI system would get you data logging for AFR, RPM, Manifold pressure, Manifold Temp, Coolant Temp, Ignition timing, fuel pressure, and oil pressure. It also has 4 additional inputs which could handle driveshaft speed, oil temp, brake pressure, etc. And you get start retard, high speed retard, launch control, warning limits on the sensors, etc. For another $500 you can add traction control..........
[Re: AndyF]
#2657870
05/22/19 07:22 AM
05/22/19 07:22 AM
Posts: 4,688 On the parachute mount
n20mstr
hard to beat a Racepak sportsman, 800.00 range. ReSale on them is great if you ever decide to not use it
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#2657871
05/22/19 07:31 AM
05/22/19 07:31 AM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
Talk to the guys over at DIYAutotune.com about on of their mega squirt EFI controllers. You can make a very capable data logger out of one and later have the benefit of being able to go fuel injected or just have it control your ignition. A side effect of most EFI systems is the ability to data log.
68 Barracuda Formula S 340
[Re: Sammy]
#2658084
05/22/19 05:05 PM
05/22/19 05:05 PM
Posts: 202 Barboursville, VA
belvedere383
Barboursville, VA
Holley sells a logging dash part #553-109 i think. It has a built in gps speedo, accelerometer, and comes with oil pressure, air temp sensor, and water temp.
i think it sells for around 1000-1100 but it has a really nice digital dash that comes with it.
65' Belvedere
496'' Stroker Indy Heads
[Re: RustyM]
#2658283
05/23/19 06:06 AM
05/23/19 06:06 AM
Posts: 117 Aus
hysteric
Aus
Best ideas /companies for data logging on a budget? say, 5 to 8 channels? Innovate. It gets expensive when you start buying sensors especially the Racepak. Otherwise the RPM is good value. It also depends how much you want to do yourself to save money.
[Re: J_BODY]
#2658336
05/23/19 10:46 AM
05/23/19 10:46 AM
Posts: 12,588 Great Neck,LI,new york
hemi-itis
I have a racepak sportsman and through some faults of my own, and RP issues... I’ve hardly used it. Something else I NEED to spend some time with. Major electronic learning curve!!
[Re: J_BODY]
#2658529
05/23/19 07:35 PM
05/23/19 07:35 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
I have a racepak sportsman and through some faults of my own, and RP issues... I’ve hardly used it. Something else I NEED to spend some time with. Is that on your boat Jay? I bought the Racepak Drag logger dash. Not cheap
"Just a Bracket car dressed up like a streetcar"
