Piston-head clearance...how close?
#2657436
05/21/19 08:28 AM
05/21/19 08:28 AM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
How close have you run piston to head clearance? Application is steel rods, flattop pistons, and less than 6500 RPM. Seems most like to see .035-.040" minimum. I've run one at .035" and never had an issue. Just curious to see if anyone has run them tighter?
Re: Piston-head clearance...how close?
[Re: an8sec70cuda]
#2657483
05/21/19 10:25 AM
05/21/19 10:25 AM
Posts: 4,210 New York
polyspheric
New York
Being slightly too close (.030") causes damage not easily detected: closes up the top ring groove and inhibits ring seal.
Boffin Emeritus
[Re: an8sec70cuda]
#2657557
05/21/19 12:52 PM
05/21/19 12:52 PM
Posts: 43,285 Bend,OR USA
Cab_Burge
I saw witness marks on all the outer edges of my old pump gas motor pistons at .035, none after changing it to .040+ The ring lands where fine, no damage but the edges where shiny, no carbon and the same marks on the heads that motor got shifted at or above 7000 RPM on every run also so
[Re: Cab_Burge]
#2657659
05/21/19 05:48 PM
05/21/19 05:48 PM
BradH
I saw witness marks on all the outer edges of my old pump gas motor pistons at .035, none after changing it to .040+ The ring lands where fine, no damage but the edges where shiny, no carbon and the same marks on the heads that motor got shifted at or above 7000 RPM on every run also so Mine's been good with .040", even with some piston-to-bore clearances looser than I'd prefer. I wouldn't feel comfortable with much less, having seem other engines with witness marks like Cab mentioned when running a tad too close.
[Re: Cab_Burge]
#2657714
05/21/19 07:28 PM
05/21/19 07:28 PM
polyspheric
New York
Compression height, skirt length, and rod ratio all affect how much extra P-H you need, but .040" is pretty much safe in everything. Jenkins said 40 years ago don't run closer than you need for knock suppression - any closer = pumping loss. Some engines with small bores and excellent swirl can be knock-protected at .060".
Boffin Emeritus
[Re: polyspheric]
#2657922
05/22/19 09:50 AM
05/22/19 09:50 AM
Posts: 1,178 Indy
FlyFish
Indy
The 408 motor I just built for my Barracuda is 0.033 (piston is 0.005 out of the hole). Just got it running on Saturday, drove straight to the drag strip. Only made 5 passes on it (I lost in rd3). It held together and got me back home....I call that a win, lol. Ran 6.59 in bad air, on the brakes (would have been a 6.58). The car kept getting faster on every pass...even as the air got worse. Edit: I shift at about 6500.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
[Re: FlyFish]
#2658024
05/22/19 02:04 PM
05/22/19 02:04 PM
Cab_Burge
All the SB Mopar I've raced and help drag race always made more power after 7 to 10 runs or pulls on a engine dyno to seat the rings fully Once they level off we start to tune for max power
