Loosening oil pan drain plug
#2656544
05/18/19 12:16 PM
05/18/19 12:16 PM
Posts: 15,900 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
This baffles me. The last time I changed oil on my 1979 W150, what seemed to be the original (or very old at least) drain plug was clearly stripped and would not tighten back down. I got an aftermarket replacement from parts store. It tightened down as much as I could want it to. I don't put a torque wrench on it, but I put plenty of torque on it. Next time I was under truck, I noticed oil seeping from plug, so I got out wrench, and was able to tighten it again. Now, each time I drive the truck, it clearly loosens up some again and I'm able to re-snug it. Again, I can tighten it plenty so it does not feel stripped.
Do I have bad plug or is pan bad? As far as I can tell, it's the original oil pan (360). I've never had this problem. Either something is stripped and won't tighten, or it tightens good and stays.
Thank you.
Facts are stubborn things.
Re: Loosening oil pan drain plug
[Re: Andrewh]
#2656564
05/18/19 01:21 PM
05/18/19 01:21 PM
RapidRobert
Yes get a softer washer (stat O seal was mentioned a day ago, not my area) & some indian head brown cement.
[Re: RapidRobert]
#2656576
05/18/19 01:51 PM
05/18/19 01:51 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Oh, ok. I can't remember if it's copper or not (4 cars and bad memory haha).
I will check as soon as I get home.
Thanks!
[Re: larrymopar360]
#2656606
05/18/19 03:43 PM
05/18/19 03:43 PM
Posts: 25,881 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The current style drain plug with the built-in gasket is the best ever.
[Re: John_Kunkel]
#2656617
05/18/19 04:10 PM
05/18/19 04:10 PM
Posts: 10,735 North Dakota
6PakBee
North Dakota
I'm afraid you may be headed for this. Drain Plug
[Re: 6PakBee]
#2656667
05/18/19 07:47 PM
05/18/19 07:47 PM
Posts: 5,886 ohio
ruderunner
ohio
Did you possibly get a oversize drain plug and you're just cutting new threads.? That would feel tight before bottoming out.
Angry white pureblood male
[Re: ruderunner]
#2656677
05/18/19 08:20 PM
05/18/19 08:20 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Did you possibly get a oversize drain plug and you're just cutting new threads.? That would feel tight before bottoming out. Oh God please no. I hope I didn't do something that stupid but then I've been pretty absent minded lately. I don't think this is what happened. I think I would have noticed the packaging. I will double check this as well. I like the plug John_Kunkel posted. I'll grab one.
[Re: larrymopar360]
#2657091
05/19/19 11:59 PM
05/19/19 11:59 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
WOW Larry, Now you got me skeered to change my Earl. The plugs in my junk are reusable, Sept maybe for the plastic washer. Have been for many decades, big block, small block ,/6, or 3.6 modern junk. Please don't make an oil change hard. Then again there are Grand Kids needing the work. Keep america proud. As fir the "current style", been around fer decades, sans plastic washer...
I have mechanical Aptitude. I can screw up anything.
[Re: John_Kunkel]
#2657118
05/20/19 06:28 AM
05/20/19 06:28 AM
Posts: 4,740 Florida
BDW
The current style drain plug with the built-in gasket is the best ever. Where do you get these?
[Re: BDW]
#2657256
05/20/19 04:02 PM
05/20/19 04:02 PM
Posts: 6,289 nowhere
Sniper
nowhere
I prefer the AGS ODP00016 If only it were Magnetic as well.
[Re: Sniper]
#2657278
05/20/19 05:17 PM
05/20/19 05:17 PM
RapidRobert
You might be able to drill/tap to add a magnet
[Re: RapidRobert]
#2657583
05/21/19 02:04 PM
05/21/19 02:04 PM
Posts: 1,272 Northern Calyfornua
Sxrxrnr
Northern Calyfornua
https://www.amazon.com/gp/product/B06WD64H8Z/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1Once you resolve current issue. Has worked out exceptionally well changing oil on several of our cars,,,,particularly on our Benz where their engineers in their typical dopiness place a plastic shield under the engine to reduce air drag,,,takes many screws to remove,,,,and left no access hole below oil pan drain plug in order to remove it, so you must remove shield. Probably adds a 100 bucks in labor for a dealer oil change,,,so their is a method to their madness. Additionally on this car,,,oil filter is directly under the hood,,,so no reason at all to go under car to change oil. Works very well on our Mopar’s and other vehicles. Including motorcycles.
[Re: Sxrxrnr]
#2657702
05/21/19 07:12 PM
05/21/19 07:12 PM
Posts: 16,492 On the run…
BloFish
On the run…
Have one and use it often!
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: BloFish]
#2657724
05/21/19 07:58 PM
05/21/19 07:58 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Sxrxrnr, that is a cool tool. On my Power Wagon, so easy to get underneath and reach filter so I'm ok with draining that way.
As soon as someone mentioned plug gasket, I jumped online and order different brand one with the nylon type gasket and magnet. $10 including shipping and it will arrive for my next day off. The one John_Kunkel posted looks good but I had already ordered mine. The one that won't stay tight is "Needa Part" brand fyi from Autozone.
