Sometimes racecars aren't fun
#2656403
05/17/19 09:57 PM
05/17/19 09:57 PM
Posts: 9,836 MI, usa
dvw
MI, usa
4.5 hr trip to Columbus. Out of the trailer the car wouldnt crank. Breaker bar turn, nope. Radiator low, yup. Pulled plug #2, nope. #4, nope, #6, Bingo, coolant gusher. Tow home tomorrow. Finish side job Sunday. Pull it apart Monday. In hind sight I thought I had a whiff of coolant last Satirday on the last pass. Did I check it, hell no. Dumb ass. Doug
Re: Sometimes racecars aren't fun
[Re: Dragula]
#2656436
05/17/19 11:36 PM
05/17/19 11:36 PM
Posts: 326 Alberta
Wookie316
Alberta
That sucks. Happened to me too a couple years ago. Same thing. Smelt water. Thought it was someone else. Ended up having a cracked head. Racing does suck at times.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
[Re: Wookie316]
#2656460
05/18/19 03:12 AM
05/18/19 03:12 AM
Posts: 20,179 Park Forest, IL
slantzilla
Park Forest, IL
Sorry to hear that. Bad way to start a race weekend.
[Re: dvw]
#2656464
05/18/19 05:37 AM
05/18/19 05:37 AM
Posts: 2,464 Sydney,Australia
tex013
Sydney,Australia
Sounds similar to my day today . At least i only drove one hour . I think i have sucked a intake gasket in , i hope . Must be that time of year , split the block same race last year Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#2656470
05/18/19 06:28 AM
05/18/19 06:28 AM
Posts: 2,923 A shed in England
Tig
A shed in England
Well I'm not the only one then. After a big repair job to fix wheelie damage we go out for our first pass with the front tight. It spins at the launch and hops around like a rabbit on amphetamine. Back to the pits and I loosen it up some (6 clicks on ext) Out for the next pass and skyward again, I lift instinctively but get back in it before it crashes down, go for second gear and somethings up, it feels like it's in 3rd ??. Anyway back in the pits we have only 3rd and reverse. And reverse where neutral is. After checking the linkage it dawns on me that I've likely jammed the sprag rollers on the ramps, lifting and getting back on it in 1st is a no no on 727's. Seems lately we cant go 2 passes without breaking something.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#2656473
05/18/19 07:13 AM
05/18/19 07:13 AM
Posts: 1,030 ohio
67mprfan
ohio
Hey Doug Sorry to hear about your car I was wondering why you didn't make a pass but I'm glad to meet you
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: dvw]
#2656515
05/18/19 10:05 AM
05/18/19 10:05 AM
Posts: 14,499 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
There can only be one cause for that issue that isnt a big pita......the gasket failed near a water passage.
[Re: fast68plymouth]
#2656549
05/18/19 12:36 PM
05/18/19 12:36 PM
Posts: 10,000 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Sucks, i know. Trying to go faster, i lost count on the number of weekends i went home broke! My fault, i would be better off with a milder combo, but,,,,,,,,,,,
#2656552
05/18/19 12:39 PM
05/18/19 12:39 PM
Posts: 4,980 new jersey usa
11secdart
new jersey usa
Hear ya man! Two years ago I qualified for the NED Bracket Finals as an alternate, the sunday before I broke the trans at a nostalgia race, ran home took the trans out brought it to my friend / trans guy he rebuilt it and had it done two days later I put it back in Tuesday night, worked half a day wednesday and finished it, loaded it in the trailer and left at 5.30 A. M. Thursday for Numidia Dragway ( about a two hour trip) I got there unloaded and on the first time shot the trans went again, my friend towed me back and we tried to figure out what happened i noticed the shifter was way out of adjustment, I reset it and it still wouldn't work and so I loaded it back in the trailer,. I asked my track manager if I could go home and get my D150 and race that( i do pretty well with it) she called the Division director and he said No not after you make a time shot, So i hung out the rest of the weekend to cheer on my track team. Got home and took the trans out and brought it to my friend , it turns out I had the shifter so far out of adjustment that when I tried to force it in to gear it broke the rod in the trans that operates the valve body so it got stuck between gears and fried the bands, He fixed it i put it back in and I checked the shifter linkage ten times to make sure it was correct, moral of the story: even when you are in a hurry, take the time to do it right!
[Re: parksr5]
#2656673
05/18/19 08:11 PM
05/18/19 08:11 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
That's a bummer sorry to hear... .
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
