Re: D600
[Re: mopeman]
#2657831
05/22/19 12:35 AM
05/22/19 12:35 AM
Posts: 517 ND
dodgedon
ND
In this area tires are easy to find too. 9.00-20 and 10.00-20 are everywhere. New, used, recaps whatever you want. IF the truck has Dayton spoke type wheels guys will switch to 22.5 tubeless Radials.
Dodge trucks are some of the best built heavy duty trucks from any era.
67 Charger 383 auto 75 Dodge CNT 800 CAT Diesel 2012 Ram Crew cab 5.7 4x4
Re: D600
[Re: dodgedon]
#2659780
05/27/19 10:21 PM
05/27/19 10:21 PM
Posts: 615 Id
mopeman
Id
Well I made it home with her! No big issues, swapped out the voltage regulator for an over charging issue, and swapped out the windshield wiper motor and linkage bushings in the NAPA parking in Lewiston Id. Other than that, not a bad return trip. I took it slow and easy, doing between 45-50 mph and about 3000-3300 rpm.
Mopar or no car MoPar=Massivly Over Powered And Respected!
'93 W250 Ram '68 Charger '67 Coronet 500 my steet/strip rod-now a 6BBL!
Re: D600
[Re: SattyNoCar]
#2659792
05/27/19 11:17 PM
05/27/19 11:17 PM
Posts: 615 Id
mopeman
Id
Looks really clean! How many gallons per mile did it get?
I'm thinking around 10 mpg, but that is a guess. Topped the R/H tank off in Lewiston and it was around 1/4 left in McCall. Topped it up with 26 gallons and made it back to Mountain Home with about a 1/2 tank left. So some where around 30 to 35 gallons used for 340 miles.
Re: D600
[Re: mopeman]
#2660358
05/29/19 02:23 PM
05/29/19 02:23 PM
Posts: 43,355 Bend,OR USA
Cab_Burge
What are you going to do with this truck now?
Re: D600
[Re: Cab_Burge]
#2660813
05/31/19 01:11 AM
05/31/19 01:11 AM
Posts: 615 Id
mopeman
Id
What are you going to do with this truck now? At first I am going to do a full service to it, and then work it.I am trying to figure out the older fluids that the service manual calls for, before I work it, I will change all the oils and do a full tune up. After that, I will be using it to haul gravel for a lot of landscaping, haul hay, and I have a 1/4 mile driveway that needs a lot of attention. As I work it, I will be fixing it up. Eventually I'd like to do a full restoration, if I can find the parts.
Re: D600
[Re: mopeman]
#2660871
05/31/19 10:20 AM
05/31/19 10:20 AM
Posts: 6,571 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
What are you going to do with this truck now? At first I am going to do a full service to it, and then work it.I am trying to figure out the older fluids that the service manual calls for, before I work it, I will change all the oils and do a full tune up. After that, I will be using it to haul gravel for a lot of landscaping, haul hay, and I have a 1/4 mile driveway that needs a lot of attention. As I work it, I will be fixing it up. Eventually I'd like to do a full restoration, if I can find the parts. That was pre synthetic era so the trans and diff would have been 90W conventional oil and the engine likely 30W maybe 10w30. The new synthetic gear oil won't bother the diff but the synchros in the trans might might cause a fuss unless you use the stuff with the friction modifier in it. Nothing wrong with conventional gear oil if you are concerned about compatibility, especially given the intended use For the engine, 15w40 Rotella, Mobil Delvac etc will do the trick. Kevin
Re: D600
[Re: NITROUSN]
#2675091
07/07/19 07:24 AM
07/07/19 07:24 AM
Posts: 1,497 North East USA
BIGGERED
Reasonable Title
Reasonable Title
North East USA
Nice truck. Nothing special on the fluids. Jack the wheels off the ground and grease those king pins. Looking and your trip MPG wise I calculate it at 6mpg. A friends father now deceased was in to brass era cars, drove em all over the USA and Canada. Real old school gear head. He ran an add in Hemings for years selling all sorts of early oil, grease and gear lube. He had cans and bottles, many different grade stickers but only 3 drums of lube. Gear, oil and grease. Don’t forget the elimination of Sperm Whale oil from industrial lubricants came in 1972. That was a game changer. Red
Re: D600
[Re: Cab_Burge]
#2684845
08/06/19 01:34 AM
08/06/19 01:34 AM
Posts: 3,515 Turku, Finland
Forwardlook
Turku, Finland
It is good to here you are going to use it as it was built for A friend of mine has 6 or 8 early(1961 and later Dodge D500 and larger trucks to use on his farm Please post some pics if you get the chance! A four eye D700 or D800 has been on my dream list for years! Sweet truck Mopeman, way to go!
Re: D600
[Re: Forwardlook]
#2684948
08/06/19 12:28 PM
08/06/19 12:28 PM
Posts: 34,974 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
I see several old Dodge grain trucks around for sale near me ..Missed out on some deals too Viewed this one last week, not sure if its for sale yet ..looking into it
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: D600
[Re: mopeman]
#2685012
08/06/19 03:40 PM
08/06/19 03:40 PM
Posts: 1,882 Pittsburgh,PA
RTSrunner
Pittsburgh,PA
I'm thinking around 10 mpg, but that is a guess. Topped the R/H tank off in Lewiston and it was around 1/4 left in McCall. Topped it up with 26 gallons and made it back to Mountain Home with about a 1/2 tank left. So some where around 30 to 35 gallons used for 340 miles. Off topic but do you live in McCAll? My friend Dave and his wife own McCall Cycle motorcycle shop. RT
Re: D600
[Re: mopeman]
#2690263
08/22/19 09:27 AM
08/22/19 09:27 AM
Posts: 1,357 central Florida
VL21
central Florida
In looking at the pics Bigdad and you have posted, both have windshield chrome, vent divider chrome, chrome bumpers.
Does that mean they have Adventurer packages, or was the trim standard on the bigger trucks?
Either way, nice trucks!
It takes gasoline to interest me.
