Page 106 of 159 1 2 104 105 106 107 108 158 159
Re: Paint job on a budget!? CONTINUED..page 44........ #26558
12/30/06 08:50 PM
12/30/06 08:50 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
Looks normal for a first coat, which usually doesn't look very good.
The rustoleum marine paint does look interesting.
link
How much does the stuff cost and where do you get it? Is it a urethane like brightside?
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: Exit1965] #26559
12/30/06 10:03 PM
12/30/06 10:03 PM
I got it for 11 bucks a quart at Lowes. They have a small display of it at the end of one of their paint isles. I honestly couldnt tell you if its a urethane. The can is less than helpful. It goes on smooth though.
Re: Paint job on a budget!? CONTINUED..page 44........ #26560
12/31/06 11:51 AM
12/31/06 11:51 AM
Ok, I must have done something wrong. I had to sand all of the blue paint off this morning. I waited 24 hours and tried to wet sand before the second coat and it was just peeling off in spots and gummy in others where there was SEM self etching primer. On the flip side it was dry and hard on the other half of the decklid. I am thinking either I did not clean the surface as good as I should have or I did not wait long enough. So I just resurfaced the decklid and laid down more etching primer as I cut back down to the metal in spots. Do you think the rustoleum is not compatible with SEM etching primer? They sell a marine primer I am going to try if it does it again. Your thoughts??
Re: Paint job on a budget!? CONTINUED..page 44........ #26561
12/31/06 04:17 PM
12/31/06 04:17 PM
Sounds like it has to do with the primer or your surface prep.
You know you don't have to prime if you are using the Rustoleum, right? Just paint right on the bare metal.
Re: Paint job on a budget!? CONTINUED..page 44........ #26562
12/31/06 04:23 PM
12/31/06 04:23 PM
I primed all bare metal with several brands of rattle-can self etching primers with no drying or adhesion problems with regular Rustoleum. Maybe the primer absorbed your prep wipe with solvent and you didnt give it enough time to evaporate.
Bob
Re: Paint job on a budget!? CONTINUED..page 44........ #26563
12/31/06 04:52 PM
12/31/06 04:52 PM
I am definitely going to point the finger at my prep work. I just re sanded the whole panel and re primed it. After giving it the recommended drying time I scuffed it and re applied the paint with no thinning this time. ( the can says you don't have to. I will check it again tomorrow to see if I did any better.
Re: Paint job on a budget!? CONTINUED..page 44........ #26564
12/31/06 10:30 PM
12/31/06 10:30 PM
Bakersfield, CA
K
kenzo42 Offline
kenzo42  Offline
K
Bakersfield, CA
I'm pretty sure you're not suppose to paint directly over self etch. I'm assuming this was placed directly over metal?
You're suppose to seal it after self etch, if memory serves me.
SEM makes top of the line 1k stuff.
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: Exit1965] #26565
01/01/07 12:40 AM
01/01/07 12:40 AM
Exit,
Did you use rustoleum professional, or stops rust, first?
Who used Professional?
I can get easily get either here, and I am taking the car down to bare metal.
I'll go to brightside for the topcoat later
Re: Paint job on a budget!? CONTINUED..page 44........ #26566
01/01/07 12:59 PM
01/01/07 12:59 PM
I've been considering brightside or blue water myself taking into consideration the UV protection and "snow birding" in salty air and beach conditions.
I've been using Rust-oleum Professional. I can't recall what exactly Exit was using off the top of my head, or if it was posted.
As a primer, rust-oleum professional seems to sand down smoother, seal (bondo), and hold up better than primers I've used in the past such as Dui-color and another automotive primer whos name escapes me at the moment.
Re: Paint job on a budget!? CONTINUED..page 44........ #26567
01/01/07 05:46 PM
01/01/07 05:46 PM
I used Black Professional with no primer. Sanded plenty of it also during the learning curve.
Exit used Professional when he went through his white era. The red was Stops rust. IIRC.
Re: Paint job on a budget!? CONTINUED..page 44........ #26568
01/01/07 07:33 PM
01/01/07 07:33 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
Actually started with red professional, then canvas white standard stops rust, then brightside hatteras white.
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: Exit1965] #26569
01/02/07 01:01 PM
01/02/07 01:01 PM
Ive had a bit of experience in the past with painting and after buying the kit, and then spending 1000€ (around 1800$ or so) on metallic land rover paint, clear coat, primer and mixing agents. I painted my land rover with a paintgun and the results werent very good, as the gun didnt have a filter it started shooting lumps of paint at the car which messed things up, then the clear coat wouldnt land on the car well and exhausted and frustrated I decided that was it and Id pay someone to do a pro job. Note I did it outside. Now Im going to try brightside and am very hopeful, if not ill resort to having it done professionally.
Here are some pics of it painted with a compressor and paint gun:
more pictures here: http://www.marbellamist.com/defender/index.html
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: Exit1965] #26570
01/02/07 08:50 PM
01/02/07 08:50 PM
Hi guys,
It's been about three months since I've done this paint job and the paint is holding well.
I honestly forgot to give everyone an update and show you the writeup I made.
http://www.ss14.net/writeup_rollerpj.html
Unfortunately I'm going to eventually cease my website altogether....so someone read up while you can...or save it on your computer.
Also...feel free to let me know what you think.
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: kenzo42] #26571
01/02/07 10:38 PM
01/02/07 10:38 PM
Ok, so i'm not real impressed with Rustoleums boat paint. Heres what I did:
Sanded the panel with 220 then 400
Washed with mild soap and water
Dried
Wiped down with mineral spirits and let dry for 2 hours
Wiped down with tack cloth
Applied paint
Waited 48 hours
The paint started flaking right off. I guess I will try the professional series unless anyone can point out a step I did to cause poor adhesion.
Re: Paint job on a budget!? CONTINUED..page 44........ #26572
01/02/07 10:53 PM
01/02/07 10:53 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
Is it very humid over there? That can have an effect, but I'm not sure it would make it peel off like that.
Instead of going to rustoleum professional, you might consider a switch to brightside.
Re: Paint job on a budget!? CONTINUED..page 44........ #26573
01/02/07 11:41 PM
01/02/07 11:41 PM
Bakersfield, CA
K
kenzo42 Offline
kenzo42  Offline
K
Bakersfield, CA
How did you wipe w/ tack cloth? They can leave a residue if pressed hard.
Someone mentioned the powder from latex gloves causes adhesion issues too.
What kind of soap did you use?
Dried
Applied paint
Waited 48 hours
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: Ledman_70] #26574
01/03/07 07:00 AM
01/03/07 07:00 AM
Hey all, I was following this thread a while back, and recently painted my crx (actually did it like a month ago). I was in a hurry and kinda on a tight budget, so..
Used rustoleum stop rust gloss black for the top portions, and rustoleum professional safety red for the red parts.
Only used a quart to paint the whole car! I dunno how that happened but it did.
Thinned the paint about 30%.
NO WETSANDING between coats, but ONE final wetsand of 1500 to get out orange peel. Had no issues with dust particles causing pits, etc. All the dust came out and it was smooth.
Then did a quick (by quick I mean quick!) hand polish using 3m rubbing compound then turtle wax polish.
Was only trying to get an OEM quality job, so I am pleased with teh results, especially the cost, although it was quite a bit of work.
Sorry I only have two snaps as of now it's been really rainy and they arent very good pics, but the paint is comparable to any oem job out, probably better then some (after doing this I notice many oem jobs with LOTS of orange peel).
*Hood had peeling clear coat, and needs to be resanded, hard to tell in the pics though, but its wavy.
Re: Paint job on a budget!? CONTINUED..page 44........ #26575
01/03/07 08:58 AM
01/03/07 08:58 AM
Dried
Applied paint
Waited 48 hours
You didn't mention whether you primed or not. Does the boat paint require a primed surface?
I thought that was another difference between the brightside and the regular rustoleum; The Rustoleum adhered to bare metal but the brightside required a primed surface.
Re: Paint job on a budget!? CONTINUED..page 44........ #26576
01/03/07 10:48 AM
01/03/07 10:48 AM
Nice Job! How many coats did you do in total?
Re: Paint job on a budget!? CONTINUED..page 44........ #26577
01/03/07 01:02 PM
01/03/07 01:02 PM
St Andrews ,Manitoba ,Canada
C38coupe Offline
C38coupe  Offline
Very nice job, you did it yourself, you saved money, and your satisfied, what else can you say. I have a 2005 Dodge Caravan, magnesium green, it's got orange peel too. I will painting my 48 Chrys Coupe using this method with Tremclad Colonial Blue, I have done many test pieces all with good results, it's work, but so what, it's a learning experience and you get a sense of accomplishment, I love the look on people's faces when you tell them you did the paint with a roller and rust paint, Its classic..C38coupe
