Page 3 of 3 1 2 3
Re: Letting the big car go and 1320........ [Re: Dave Hall] #2656366
05/17/19 07:10 PM
05/17/19 07:10 PM
Windsor ,Ca.
K
Keith Richards Offline OP
K
Windsor ,Ca.
^^^ Agree with Dave, anyone here with any experience using a TB will have no problem bumping in and leaving somewhere between 2-3rd yellow, we all had that TB learning curve. Probably already a high school kid some were working on software to plug in to the OBD2 port that will be able to put adjustable delay in it and race top bulb..... ;-)
Re: Letting the big car go and 1320........ [Re: rickseeman] #2656418
05/17/19 10:33 PM
05/17/19 10:33 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Originally Posted by rickseeman
The new cars are beyond belief. Nobody ever laid in bed at night and dreamed we would have cars like this available to us. Walk into the dealer with a small down payment and drive out with a new supercharged 797 hp Redeye. We are living in a dream world. But having said all that, in a bracket race, no new car has a chance against your current car. It has to do with traction and transbrake. Buy the new car if you like, but go to the track for fun, not to be competitive, they are too hard to drive.
iagree We are living the dream...I've posted this before but now seems like a good time...Demon Exorcism
Re: Letting the big car go and 1320........ [Re: Dave Hall] #2656430
05/17/19 11:04 PM
05/17/19 11:04 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Here the guys with the newer performance cars don't really race them with any regularity. They show up at the test and tunes and grudge night races mostly. They just show up to try out their new computer tune, shifter,, etc and the following week when it's back to the regularly scheduled bracket racing they are nowhere to be found. They are car guys who take their cars down the track sometimes and not necessarily serious drag racers..
Re: Letting the big car go and 1320........ [Re: Neil] #2656479
05/18/19 07:52 AM
05/18/19 07:52 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
There is a Local guy who got a very early hellcat challenger when they came out. It seems he got the benchmark one from chrysler because it ran exactly how they said, 11.30s stock tires and 10.80s on slicks. I saw it run something like 2 or 3 10.88s in a row when it was stock. Pretty impressive especially for something with forced induction.
68 Barracuda Formula S 340
Re: Letting the big car go and 1320........ [Re: dizuster] #2656502
05/18/19 09:35 AM
05/18/19 09:35 AM
Home
SRT6776 Offline
I hate internal combustion engines!
SRT6776  Offline
Home
Originally Posted by dizuster
I have a '16 scat pack challenger... it is absolutely amazing. I drive it year round... through the Michigan winters and all (with snow tires).
My little brother ran it last summer and it went 12.01@115mph in the dead middle of the muggy summer on a set of drag radials, so I'm sure in decent weather it's run well into the 11's without issue.
If you're looking for something you can cruise, enjoy, and click off some fun numbers... it's really hard to beat.
That being said... it is a REALLY SH*TTY bracket car. I ran it at monster mopar last year, and an NMCA race. The fly by wire throttle makes it nearly impossible to leave off the bottom bulb, and the consistency from pass to pass because of all the electronics leaves a lot to be desired. The 1320 might be a bit better because of the trans brake on the reaction times, but it's got the same motor as my car, so I can't see it being any more consistent.
I had the exact same thoughts of selling my turbo car, and buying a hellcat to dual purpose... but after making ~75 runs in my scat pack last year there is no way I can see one of these cars competitively bracket racing and going rounds in any sort of serious competition.
But again... if you're just looking for fun, the car is incredible. Comfortable, sounds good, goes good, stops good, turns good... can't deny that.
Get a pedal commander, it will fix that issue in 2 seconds.
https://www.youtube.com/watch?v=En8K76-C7sE
Re: Letting the big car go and 1320........ [Re: Keith Richards] #2656517
05/18/19 10:07 AM
05/18/19 10:07 AM
montana
BANDIT Offline
BANDIT  Offline
montana
I did the same thing year and a half ago, 2016 M-6 Hellcat. Fast, comfortable, kick-ass stereo, and my girlfriend can even drive it. Still have my tube chassis door car, Also bought a dragster over the winter, not gonna race much longer, but want to maybe make some 6 second passes before I hang it up. My son will prolly end up with the race cars. That being said, the HC is the most fun-per-dollar I’ve had yet. Jim.
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.35@165. 4400 DA
250” Neil and Parks Slip Joint. 7.36@183.
4600 DA
242" Mullis Dragster. 6.90@ 200mph
Re: Letting the big car go and 1320........ [Re: SRT6776] #2657224
05/20/19 12:54 PM
05/20/19 12:54 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
[/quote]
https://www.youtube.com/watch?v=En8K76-C7sE [/quote]
The pedal commander simply changes the sensitivity rate of the throttle. Basically tells the PCM you're at 100% throttle when you've only travelled 50% with your foot. This is no different then what you can do with any tuner bumping the throttle % up. But the problem is not there, it's in the PCM itself.
The PCM has quite a few safety and drivability delays built into it. These are NOT parameters that a regular tuner has access too, only an FCA development PCM unit can take these changes.
But even at that... the cars still aren't good enough to foot brake off the bottom bulb unless you're guessing in between lights (or going in way deep).
Re: Letting the big car go and 1320........ [Re: dizuster] #2657229
05/20/19 01:11 PM
05/20/19 01:11 PM
Windsor ,Ca.
K
K
Windsor ,Ca.
Pretty good article on them here:
1320
Re: Letting the big car go and 1320........ [Re: Keith Richards] #3144499
05/14/23 01:41 AM
05/14/23 01:41 AM
Kansas
Thelma133 Offline
Thelma133  Offline
Kansas
That red challenger is gorgeous. I wish i had bought it. The new challengers are butt ugly. They don’t look sleek like the 70 model does. I don’t care how fast it goes, this red challenger is what brings back memories
Re: Letting the big car go and 1320........ [Re: Keith Richards] #3144717
05/15/23 11:24 AM
05/15/23 11:24 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
I've got about 80 passes and a few races on my 1320 since buying it late in 2021. All of the following comments are "YMMV"...
- Mine has the full upgraded interior and I weigh 200+; I don't recall exactly what it scaled last year, but definitely over 4300
- I'd say mine is basically a 12.0 car that has dipped into the 11.8s under really good conditions... or slowed down into the 12.2s-12.3s when the atmospheric conditions swing to the hot & humid side
- I see where some people post how their "stock" 1320s are busting mid-11s, but also know of folks who have never seen an ET slip faster than 12.x with theirs
- My original expectation was that it would be really consistent since it's "all electronics"... but it will do stuff like mysteriously slow down a tenth & 1 MPH for no apparent reason between passes
- I'd say the grains of water in the air is a big -- possibly the biggest -- predictor or performance with my car, even more so than the basic DA measurements; I've watched the DA fall significantly without any performance improvement because the humidity & water grains went up as the DA fell
- Heat soak hurts the car's consistency, too; I only started putting ice bags on the intake between passes the last time I raced in 2022, although I'm not even sure it helped
- Can't say if it's the car or the driver or both, but some days I've put together a string of decent .0x lights, and other events I swear I'm doing the same thing and can't get under .1x. FWIW, I don't deep stage. On a .500 pro tree, the best RTs I could get were in the .26-.30 range
- Factory-size 275/40R20 drag radials are totally hit and miss; they'll dead-hook or they'll spin & hop cuz the short sidewalls are unforgiving of less-than-ideal track prep; I made the decision to stop using the 20" setup at the track because it's simply too unpredictable
- You'll see it's pretty common for Scat Packs in general, and 1320s in particular, to be using either 18" or 17" rear wheel setups to get a bigger selection of tires with taller sidewalls for more consistent launches; I have alternate wheels with either 305/40R18 or 305/45R18 drag radials to use, instead
- Only a very small percentage of 1320 owners use the trans brake feature cuz the cars seem just as quick off the foot brake and the trans brake procedure is awkward to follow; I never bothered testing it after the general consensus is it's more of a gimmick than a benefit
I still love the car, but IMO it's not an effective bracket racer as delivered. I haven't gone back to the track since the last event I ran in fall 2022. Figured if I wanted to be serious about going rounds that I need to pull my head outta my a$$ and get the '73 back on the road & track, since it's still a legit street/strip car that gets driven to the track.
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Letting the big car go and 1320........ [Re: Brad_Haak] #3144747
05/15/23 01:12 PM
05/15/23 01:12 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I bought my 2020 T/A 392 & was going to sell my 68 Charger street strip car but I ended up keeping it, I LOVE the new Challenger, with drag radials 390/40/17 M&H it dead hooked every time 4 passes, had a 14 mph head wind, 1st pass was 11.79 @ 115 was the best, heat soke slowed it down by a tenth, no oil catch can but I deleted the PCV valve system & have two moroso breathers to atmosphere one on each valve cover, other than that it is stock, according to Wallace calculations it would have run about 2 tenths & 2 mph faster without the head wind, I am not so sure about that LOL, did I say I love my new challenger ???? just remembered I did set the REAR camber to 0 so it would plant the tire better, stock it was neg 1.7 in the rear. car is 4445 LBS with me in it.
Page 3 of 3 1 2 3
