Re: Picked up this beauty this weekend!!!
[Re: 4x4 Roundup]
#2656474
05/18/19 07:14 AM
05/18/19 07:14 AM
Posts: 2,412 Weatherford, Texas
RapidusMaximus
Weatherford, Texas
Got a little more done yesterday, finally got the front drums off, shoes and drums were grooved into each other, what a whipping. The good news is O'Reilly's had all but a couple of the parts local so with any luck I'll have it ready for a test drive today. On a side note...so far I've put a battery, alternator and voltage regulator on and it's still showing discharge on the alt gauge and at the battery the volt tester is only picking up 12.7 volts...any suggestions?
1968 Plymouth GTX 1974 Dodge P/U Long Bed Stepside 318 2019 Ram 2500 6.4, auto, 4WD
[Re: RapidusMaximus]
#2656475
05/18/19 07:32 AM
05/18/19 07:32 AM
Posts: 7,833 east side of Ohio
basketcase
east side of Ohio
just for piece of mind have the parts tested. Just because they are new doesn't mean they are good.
1981 Dodge D150 360 auto
[Re: basketcase]
#2656483
05/18/19 08:25 AM
05/18/19 08:25 AM
RapidusMaximus
Weatherford, Texas
just for piece of mind have the parts tested. Just because they are new doesn't mean they are good. Good idea, after I finish the brakes I'll do one last check for bad grounds and broken wires then get the parts validated
#2656557
05/18/19 12:47 PM
05/18/19 12:47 PM
Posts: 8,671 Buford, GA
I_bleed_MOPAR
Buford, GA
Nice! On your charging problem- did you check the bulkhead connector? Seems I remember them being a problem on trucks also. Missed a chance on a '75 locally. Called about it yesterday right after ad came up and the first guy that showed up bought it. Story of my life- day late and a dollar short. Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: I_bleed_MOPAR]
#2656680
05/18/19 08:27 PM
05/18/19 08:27 PM
Posts: 15,894 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Definitely clean up the bulkhead. On mine '79 Power Wagon, they looked really bad. I got a finger nail file (aka emory board I believe) and cut it down in width to fit inside everywhere I needed and cleaned all the points. It definitely helped with headlights dimming at idle.
Facts are stubborn things.
#2656888
05/19/19 01:56 PM
05/19/19 01:56 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
It can be bad when a wheel cylinder leaks out and then everything sits! I had a set of rear drums on an old police car that were like that! I really thought I was going to have to cut one of them off. I finally got it off and did a reverse somersault in the process.
[Re: scannman70]
#2659269
05/26/19 07:38 AM
05/26/19 07:38 AM
RapidusMaximus
Weatherford, Texas
Well, had to stop on the truck for a week, spent the last week in Philly sitting in a training class... . Oh well, got back 2am Friday morning and was in the shop by 9am, gave up on the disc brakes for now and completely overhauled the power drum system, shoes, hydraulics, hardware, new drums, new master cylinder, brakes are now bled and it's got an excellent pedal. Changed a leaky freeze plug and and cleaned all the bulkhead connecters and grounds, won't know if the charging issue is fixed until I fill it back up with anti freeze and fire it back up today. Also found out yesterday...the hard way...that a 72 W100 DOES NOT...have 4.5 inch bolt pattern wheels, had a set of nice wheels and tires stacked in the corner that I would use for test driving until I figured out what I wanted to put on the truck permanently...since the truck came with 4 flats...free of charge of course...image my surprise sitting on my backside rotating a wheel endlessly trying to get it on...then grabbing a tape measure and going...oh "S".... Still some tinkering to try and get done today...see if I can find a tire shop open, adjust the emergency brake cable, clean the interior...some more...anybody got any leads on a new rubber floor mat...this ones like crunchy as a potato chip....
#2659278
05/26/19 08:38 AM
05/26/19 08:38 AM
I_bleed_MOPAR
Buford, GA
www.lmc.comProbably others also but just remember them from my last truck. Hopefully, I'll have use for them again soon. Tim
[Re: Soopernaut]
#2659390
05/26/19 04:54 PM
05/26/19 04:54 PM
RapidusMaximus
Weatherford, Texas
Good info, thanks. Got a little more done today, still showing no charge at the battery so I took the bulkhead connectors apart...again...pulled the instrument panel, cleaned everything, put it all back together, still no charge...ugh...adjusted the emergency brake...that was fun...not. Oh well...back at it tomorrow...
#2659419
05/26/19 07:12 PM
05/26/19 07:12 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Good info, thanks. Got a little more done today, still showing no charge at the battery so I took the bulkhead connectors apart...again...pulled the instrument panel, cleaned everything, put it all back together, still no charge...ugh...adjusted the emergency brake...that was fun...not. Oh well...back at it tomorrow... Sorry it didn't fix things for you, but cleaning the bulkhead will serve you well anyhow!
[Re: larrymopar360]
#2659468
05/26/19 09:23 PM
05/26/19 09:23 PM
RapidusMaximus
Weatherford, Texas
...driving me nuts, going to backtrack everything in the morning...really don't want to start unwrapping harnesses, that'll be last ditch...
[Re: basketcase]
#2659538
05/27/19 08:02 AM
05/27/19 08:02 AM
RapidusMaximus
Weatherford, Texas
Well...kinda...the alternator tested good and I talked them into trading out the voltage regulator figuring with the alternator testing good it HAD to be the voltage regulator...nope.
