Stage 6 Valve Guide
#2655432
05/14/19 04:48 PM
05/14/19 04:48 PM
Posts: 3,842 N.E. Ohio
6bblFLASH
N.E. Ohio
Need guides for a stage 6 head . 2" long or so. .493 o.d. .375 stem. What I found is made to order only. 5 weeks wait
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Stage 6 Valve Guide
[Re: 6bblFLASH]
#2655455
05/14/19 06:02 PM
05/14/19 06:02 PM
fast68plymouth
So. Burlington, Vt.
4 options:
- wait til they’re available
- turn down a .502 guide
- ream hole in head to .500, use a .502 guide
- put a liner in the old guide
When I was messing with those heads on a semi regular basis....... if they needed guides(most did), I made them so I could use .502 guides.
[Re: fast68plymouth]
#2655458
05/14/19 06:09 PM
05/14/19 06:09 PM
Posts: 4,457 Washington
madscientist
Washington
4 options:
When I was messing with those heads on a semi regular basis....... if they needed guides(most did), I made them so I could use .502 guides. Yep. I always do option 2. Even on new stuff like W5 heads. I junked the original seats a guides because they were so crappy.
[Re: madscientist]
#2655462
05/14/19 06:18 PM
05/14/19 06:18 PM
6bblFLASH
N.E. Ohio
Machine shop doesn't want to put liners in them. Also don't want to ream the heads to common size.
I guess I could buy a reamer and do it myself.
Place that makes the guides said "call Indy,they order them from us". Called Indy said, "those heads are junk..."..
[Re: 6bblFLASH]
#2655463
05/14/19 06:22 PM
05/14/19 06:22 PM
fast68plymouth
So. Burlington, Vt.
I never had any problems reaming the heads.
Made any future repairs a lot easier too.
In my mind, it was the “no brainer” route to take.
[Re: 6bblFLASH]
#2655468
05/14/19 06:37 PM
05/14/19 06:37 PM
Posts: 31,073 Oregon
AndyF
Place that makes the guides said "call Indy,they order them from us". Called Indy said, "those heads are junk...".. If your shop doesn't want to do them then send the heads to Dwayne. He has been fixing Stage VI heads since they first came out.........
[Re: dart9ss]
#2655508
05/14/19 08:29 PM
05/14/19 08:29 PM
fast68plymouth
So. Burlington, Vt.
Even on new stuff like W5 heads. W5’s......... the stage VI of the small block world.
#2655549
05/14/19 09:56 PM
05/14/19 09:56 PM
madscientist
Washington
Even on new stuff like W5 heads. W5’s......... the stage VI of the small block world. LOL. Ain't that the truth.
#2655587
05/15/19 01:06 AM
05/15/19 01:06 AM
Posts: 13,202 aZLiViN
J_BODY
aZLiViN
Even on new stuff like W5 heads. W5’s......... the stage VI of the small block world. Having played in both of those arenas, it’s little wonder I haven’t embraced the LS swap
