Why does everyone hate the 4.7 V8?
#2655318
05/14/19 12:07 PM
05/14/19 12:07 PM
Posts: 2,499 God's Country Maryland
GODSCOUNTRY340
I've read a lot of negative things about the 4.7 engine, especially when in a Dakota. Why all the negativity?
Re: Why does everyone hate the 4.7 V8?
[Re: GODSCOUNTRY340]
#2655336
05/14/19 12:59 PM
05/14/19 12:59 PM
Posts: 20,630 in a cattle trailer down by th...
Guitar Jones
Because people don't take care of their vehicles properly then whine about the thing having the durability of a potato chip.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Guitar Jones]
#2655339
05/14/19 01:02 PM
05/14/19 01:02 PM
Posts: 4,673 On the parachute mount
n20mstr
I had a Durango, VERY clean. The 4.7 gave up the head gasket at 147,000. It was a shame to junk it as like I said it was a super clean truck
....BAD A$$ STREET CAR.....
[Re: Guitar Jones]
#2655364
05/14/19 02:02 PM
05/14/19 02:02 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
The plastic timing chain guides are bad, most of the issues come from that, they get hot and get brittle and start breaking between apart around 100,000 and 150,000 miles, there are a few outliers that go more but most will start to have issues with start up rattle and progressively get worse and it seems to have no bearing on how well or poorly the engine was cared for, plastic like that just don't belong in an engine. The only time I have seen bottom end issues is when there are plastic bits plugging the oil intake. When the chain noise gets real bad most shops will diagnose a bad engine. The head gaskets and head surface seem to be very susceptible to overheating, if you have a water leak FIX IT, any overheating will blow a head gasket and probably need head re-surfacing, most shops diagnose this as a bad engine. Sometimes after sitting a while (usually a week or more but ocasionally just overnight) a lifter will bleed down and allow the rocker to fall off causing weird noises and severe misfires that most shops will diagnose as a "bad engine", typically we can just re-install the rocker in an hour and the engine keeps going. We see a lot of people bring their rigs to us with a "bad engine" and it does not need a new engine. We offer timing chains as a menu item here with all guides, tensioners and chains for $750 and if you want head gaskets at the same time $1500 plus $150 if you need them re-surfaced, most shops refuse to dig into one of these at all and most shops in the valley send their customers to us because you can't find a "good 4.7" in a junk yard.
[Re: HotRodDave]
#2655367
05/14/19 02:15 PM
05/14/19 02:15 PM
Posts: 15,831 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
And pretty hard to fill the shoes of the 318, which it was sort of doing. Sort of.
Facts are stubborn things.
#2655378
05/14/19 02:52 PM
05/14/19 02:52 PM
Posts: 17,840 S.E. Michigan
ZIPPY
S.E. Michigan
It doesn't seem to survive abuse and neglect quite as well as the 5.2 and 318. It is overshadowed by the 5.7 in larger vehicles.
Shopping used vehicles, personally it seems every time I have found what seemed like a deal on a vehicle with one, most of them either needed a timing chain related repair, or already had it replaced incorrectly and were throwing codes. The others that were even less expensive didn't have a timing chain issue had blown head gasket, cracked head, cracked block type of issues.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2655405
05/14/19 03:40 PM
05/14/19 03:40 PM
Posts: 16,811 Between Houston & Galveston TX
SattyNoCar
I lived with one in a 2002 RAM 1500 for almost 5 yrs. Never had any serious issue with it mechanically, but, no matter what I did or how I drove, it would only give me 14MPG. Downhill with a strong tail wind, 14. Around town in stop and go traffic.....14. I could get the MPG lower (easily) but never higher. When I owned this truck, there was a guy on here insisting he had essentially the same truck and he was knocking out 20+ MPG all day long.
And it was kinda gutless at lower RPM. There would be instances where I'd have to slow down for traffic, and just needed a little oomph to get back up to speed, no where near full throttle, and it wouldn't do it.
I had a dealer and an independent shop look at it to see if the computer needed to be reset or if anything was wrong and neither found anything. Both basically said it was just too small of an engine for such a big truck
I bought it when it just turned 40K miles, and I got rid of it when it had about 90K. For giggles, I recently found an old registration with the VIN on it and ran it thru Carfax. Truck is still going with over 250K on it somewhere up around Dallas. I wonder if it's still on the original engine.
John
[Re: Guitar Jones]
#2655477
05/14/19 07:01 PM
05/14/19 07:01 PM
Posts: 8,668 Buford, GA
I_bleed_MOPAR
Buford, GA
Because people don't take care of their vehicles properly then whine about the thing having the durability of a potato chip. Probably true but from all I've heard (first-hand) and read about them, I'll never own one. Plenty for sale around here (Daks & 'rangos) with bad 4.7s in 'em. Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: buildanother]
#2655535
05/14/19 09:30 PM
05/14/19 09:30 PM
Posts: 20,169 Park Forest, IL
slantzilla
Park Forest, IL
I had an '06 HO 4.7. I liked it other then the fact that at 25K miles I could not keep oil in it. When I traded it in with 60K on it it smoked so bad on startup it appeared the truck was on fire.
#2655564
05/14/19 10:20 PM
05/14/19 10:20 PM
Posts: 12,025 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Let's remember that the 4.7 is only 286cid. We kinda loose track just how small an engine it is with the use of the metric numbers. And is just a bit complicated and fragile especially for a truck engine. Lots of premature failures. Of course, some go on forever, but then some early 2.7s went a long way too.
The 4.7 is just a crap shoot. Some deliver a good life span with minimal intrusive repairs while others break parts that require major dollars to fix. You just never know which you will get.
Master, again and still
[Re: Jim_Lusk]
#2655572
05/14/19 10:46 PM
05/14/19 10:46 PM
Posts: 1,306 Laveen, Arizona
GTSDart340
Laveen, Arizona
Had an 01 Durango with the 4.7. I bought it with 170k. It ran buttery smooth, do I thought I had gotten lucky. That thought went out the window about a month later when my oil pressure dropped to zero at idle. Come to find out it burned a ton of oil. We drove it from Phoenix to LA and back (300ish miles one way) and went through 4 quarts of oil. We traded it in on a 16 Durango and got $50 for it lol. Only traded it in because I got severely injured and couldn't replace an engine.
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
