BREAKER FOR ALTERNATOR #2655142
05/13/19 08:44 PM
05/13/19 08:44 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
Just installed a denso 1 wire alternator. I believe the output is about 65 amps. I believe that I need a breaker btwn the alt and the battery. Can't find a stud style breaker btwn 75-100 A. I don't have enough space to put one of those bulky breakers, not much free space in the engine bay. Anyone have a solution?
Re: BREAKER FOR ALTERNATOR [Re: A/MP] #2655154
05/13/19 09:15 PM
05/13/19 09:15 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
I use a 50amp fuse
Re: BREAKER FOR ALTERNATOR [Re: A/MP] #2655164
05/13/19 09:39 PM
05/13/19 09:39 PM
Why do you think you need anything as protection between the alternator and battery?
I don't use and I don't think any protection is needed as long as you protect the wire and connections work twocents
Re: BREAKER FOR ALTERNATOR [Re: Cab_Burge] #2655179
05/13/19 10:08 PM
05/13/19 10:08 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Use a fuse if it's for some kind of protection. Use a 200amp cole hersee can solenoid if you're wanting to interrupt the output for making passes.
Re: BREAKER FOR ALTERNATOR [Re: Cab_Burge] #2655181
05/13/19 10:12 PM
05/13/19 10:12 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
If the motor is running and you have a fault in the power cable, then you will feed the fault from both the battery and the alternator. I always fuse at the alternator and at the battery. I don't use breakers, just fuses. Think I have a 120 amp at the alternator and 300 amp fuses on the battery.
Re: BREAKER FOR ALTERNATOR [Re: A/MP] #2655380
05/14/19 02:54 PM
05/14/19 02:54 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Re: BREAKER FOR ALTERNATOR [Re: A/MP] #2655390
05/14/19 03:10 PM
05/14/19 03:10 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
I used this, and it works fine, but the circuit breaker looks like a much better setup.
Napa inline fuse
Re: BREAKER FOR ALTERNATOR [Re: Leigh] #2655413
05/14/19 04:00 PM
05/14/19 04:00 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Never used one, but if I did, it would be at the battery, not the alternator. MIDI fuses are available to 200A I think.
Re: BREAKER FOR ALTERNATOR [Re: CMcAllister] #2655435
05/14/19 04:57 PM
05/14/19 04:57 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Re: BREAKER FOR ALTERNATOR [Re: John_Kunkel] #2655444
05/14/19 05:35 PM
05/14/19 05:35 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Originally Posted by John_Kunkel
I used this stuff on my boat.. I just mounted it on a bracket.. its still
on there.. I used 2 of them and its on my race car at both ends
wave
Re: BREAKER FOR ALTERNATOR [Re: MR_P_BODY] #2655505
05/14/19 08:27 PM
05/14/19 08:27 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
I remember that style breaker on some military aircraft from the 70's. Must be a good design if they are still in use. Thanks
Re: BREAKER FOR ALTERNATOR [Re: John_Kunkel] #2655581
05/14/19 11:57 PM
05/14/19 11:57 PM
I don't remember my 1960 Piper 250 Comanche having one of those, it had a generator originally and got converter to 260 HP motor from the firewall forward before I bought it though work shruggy I do remember having a on and off switch mounted under the instrument panel for the alternator, maybe it had one on that also confused
Probably not a bad idea though when your at 12,500 ft. in the clouds and something starts to smell like burning wires work
Re: BREAKER FOR ALTERNATOR [Re: MR_P_BODY] #2655688
05/15/19 01:12 PM
05/15/19 01:12 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
A really high amp fuse is not going to protect anything in the car unless it's located at the battery and the main cable gets shorted directly to ground. Everything in the car will go up in smoke before it breaks a 300A fuse.
