For Genius's only. Smarter than me.
#2655023
05/13/19 03:53 PM
05/13/19 03:53 PM
Posts: 289 Nevada
merpar
Nevada
My 483 ci. wedge. Has 6 mild passes, not one full throttle pass on motor. Backed car out to line up and load on trailer, pulled up to ramp. Just as I started to shut it off it developed a rattle in the motor. Not a rod or lifter noise, was like something loose. Got it home and jacked up the front end. Pulled valve covers off and oil pan. Everything looks perfect, not a scratch or ding visible. Rocker arms, push rods, valves, and springs all woking and intact. Took all the plugs out and hit the starter, spun over clean and quiet. So decided to let car down and put up on blocks. Just as it was almost all the way down I heard a clink, best discrip. I can think of. Was going to turn it over by the crank and check each cyl. rockers. Put a long ratchet on it and bingo. It would not move, what ever clinked wedged somewhere and can't turn the motor either direction. Pulled the drive shaft and the trans. turns using the output shaft. And looking at the flex plate and convertor, what I can see. Nothing. Any help on this would be deeply appreciated. Short of pulling the motor and trans I'm stumped !!!!! Help!!!!!
Re: For Genius's only. Smarter than me.
[Re: merpar]
#2655027
05/13/19 04:00 PM
05/13/19 04:00 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Try priming the engine. Could be a broken oil pickup tube.
[Re: merpar]
#2655051
05/13/19 04:41 PM
05/13/19 04:41 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Pull the starter and see if you can move it with a long screw driver on the ring gear.. if not your gonna have to pull the trans(slide it off the conv while the conv is still bolted to the engine..or pull the engine and trans together so you can get it apart
[Re: MR_P_BODY]
#2655063
05/13/19 05:10 PM
05/13/19 05:10 PM
Posts: 20,195 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I had to cut off a backed off convertor bolt laying on my back at Norwalk 25 years ago. I had to use a hacksaw blade holding it in my hand because it was jammed up top. Never even missed a time trial but what a pain in the butt.
[Re: merpar]
#2655135
05/13/19 08:22 PM
05/13/19 08:22 PM
Posts: 1,824 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
Am thinking we're on the right track. Started to remove the trans this afternoon, but at 75 yrs old pooped out. What a pain, flex plate shield, trans blanket tabs. And cutting off a bolt with a hack saw blade in hand. Not at my age. I'll break out the air tools tomorrow. Thank you everyone for your input. Will keep you informed on what I find. May have to wait till weekend if I can talk my son into helping. Thanks I'm right behind you nearing 70. I found that doing a little, walking away a few times during the day, you get more accomplished. I'm sure you'll find the problem and good luck.
[Re: Sammy]
#2655139
05/13/19 08:37 PM
05/13/19 08:37 PM
Posts: 4,694 Wichita
GY3
Wichita
Mine did the same thing last fall. Thought it was a torque converter bolt. Turned out to be the jankety 440Source balancer came apart and was bouncing off the timing cover.
[Re: Cab_Burge]
#2655250
05/14/19 08:15 AM
05/14/19 08:15 AM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
It does sound like a converter bolt issue. I always coat mine in red Loctite and try to let em cure overnight before firing the motor. That and I only use the ARP converter bolts after having issues w/ the piece of crap MP bolts that would stay tight no matter what I did.
