Page 1 of 3 1 2 3
For Genius's only. Smarter than me. #2655023
05/13/19 03:53 PM
05/13/19 03:53 PM
Nevada
merpar Offline OP
merpar  Offline OP
Nevada
My 483 ci. wedge. Has 6 mild passes, not one full throttle pass on motor. Backed car out to line up and load on trailer, pulled up to ramp. Just as I started to shut it off it developed a rattle in the motor. Not a rod or lifter noise, was like something loose. Got it home and jacked up the front end. Pulled valve covers off and oil pan. Everything looks perfect, not a scratch or ding visible. Rocker arms, push rods, valves, and springs all woking and intact. Took all the plugs out and hit the starter, spun over clean and quiet. So decided to let car down and put up on blocks. Just as it was almost all the way down I heard a clink, best discrip. I can think of. Was going to turn it over by the crank and check each cyl. rockers. Put a long ratchet on it and bingo. It would not move, what ever clinked wedged somewhere and can't turn the motor either direction. Pulled the drive shaft and the trans. turns using the output shaft. And looking at the flex plate and convertor, what I can see. Nothing.
Any help on this would be deeply appreciated. Short of pulling the motor and trans I'm stumped !!!!! Help!!!!!
Re: For Genius's only. Smarter than me. [Re: merpar] #2655027
05/13/19 04:00 PM
05/13/19 04:00 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Try priming the engine. Could be a broken oil pickup tube.
Re: For Genius's only. Smarter than me. [Re: merpar] #2655030
05/13/19 04:04 PM
05/13/19 04:04 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I have no idea what the sounds would indicate , but I am fairly certain it is coming out.
Is it locked up in both directions ?
That just doesn't sound good.
Re: For Genius's only. Smarter than me. [Re: merpar] #2655031
05/13/19 04:05 PM
05/13/19 04:05 PM
Locomotion Offline
Locomotion  Offline
Flexplate is one possibility. Check for cracks and see if it will rotate backwards 360* while checking too.
Re: For Genius's only. Smarter than me. [Re: Locomotion] #2655034
05/13/19 04:16 PM
05/13/19 04:16 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Nothing fell in from the starter area? Did you unbolt the flex plate from
the trans
wave
Re: For Genius's only. Smarter than me. [Re: Locomotion] #2655039
05/13/19 04:22 PM
05/13/19 04:22 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Balancer locked up from rubbing on the T/C cover. Converter bolts locked against the back of the block. How was the oil pressure before problem. If it welded a bearing to the crank she can lock up tighter than a tick with no appearance of problem. Broken Cranks can to. Sorry to be the harbinger of doom, hope it is something easier.
Todd
Re: For Genius's only. Smarter than me. [Re: MR_P_BODY] #2655040
05/13/19 04:24 PM
05/13/19 04:24 PM
Nevada
merpar Offline OP
merpar  Offline OP
Nevada
Can't unbolt flexplate. Won't rotate. I don't use a oil pick up tube. Have a single pick up on side of oil pan. What ever it is, it's from the trans pump forward. Timing chain and gears appear to be clean and clear also.
Re: For Genius's only. Smarter than me. [Re: sasquatch] #2655048
05/13/19 04:36 PM
05/13/19 04:36 PM
Nevada
merpar Offline OP
merpar  Offline OP
Nevada
Thank you for the reply. Oil pressure was good, about 50lbs at about 2000 rpm. The entire valve train was functioning before the little tink. And the bottom end looks perfect. Starter is intact. I thiink my first major move will be to pull the trans. I'm about 90% sure its not in the engine. But that other 10% scares me.
Re: For Genius's only. Smarter than me. [Re: merpar] #2655050
05/13/19 04:40 PM
05/13/19 04:40 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
Flex plate bolt is my guess.
Maybe try unbolting trans some and see if it turns over .
Re: For Genius's only. Smarter than me. [Re: merpar] #2655051
05/13/19 04:41 PM
05/13/19 04:41 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Pull the starter and see if you can move it with a long screw driver on the
ring gear.. if not your gonna have to pull the trans(slide it off the conv
while the conv is still bolted to the engine..or pull the engine and trans
together so you can get it apart
wave
Re: For Genius's only. Smarter than me. [Re: MR_P_BODY] #2655063
05/13/19 05:10 PM
05/13/19 05:10 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I had to cut off a backed off convertor bolt laying on my back at Norwalk 25 years ago. I had to use a hacksaw blade holding it in my hand because it was jammed up top. Never even missed a time trial but what a pain in the butt.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: For Genius's only. Smarter than me. [Re: merpar] #2655066
05/13/19 05:30 PM
05/13/19 05:30 PM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
Just a long shot, pull the distributor and look in there.
Re: For Genius's only. Smarter than me. [Re: rickraw] #2655083
05/13/19 06:18 PM
05/13/19 06:18 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
I'm going with converter bolt (had one stop the motor from cranking, ruined the bolt boss) or broken converter drive plate. Hopefully it's simple and cheap!
Re: For Genius's only. Smarter than me. [Re: Leigh] #2655122
05/13/19 07:54 PM
05/13/19 07:54 PM
Nevada
merpar Offline OP
merpar  Offline OP
Nevada
Am thinking we're on the right track. Started to remove the trans this afternoon, but at 75 yrs old pooped out. What a pain, flex plate shield, trans blanket tabs. And cutting off a bolt with a hack saw blade in hand. Not at my age. I'll break out the air tools tomorrow. Thank you everyone for your input. Will keep you informed on what I find. May have to wait till weekend if I can talk my son into helping. Thanks
Re: For Genius's only. Smarter than me. [Re: merpar] #2655135
05/13/19 08:22 PM
05/13/19 08:22 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
I'm right behind you nearing 70.
I found that doing a little, walking away a few times during the day, you get more accomplished.
I'm sure you'll find the problem and good luck.
Re: For Genius's only. Smarter than me. [Re: Sammy] #2655139
05/13/19 08:37 PM
05/13/19 08:37 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Mine did the same thing last fall. Thought it was a torque converter bolt. Turned out to be the jankety 440Source balancer came apart and was bouncing off the timing cover.
Re: For Genius's only. Smarter than me. [Re: merpar] #2655166
05/13/19 09:43 PM
05/13/19 09:43 PM
The motors talking to you, it saying help grin
AKA aside those noise are a good warning, please let us know what you find wave
Re: For Genius's only. Smarter than me. [Re: Cab_Burge] #2655250
05/14/19 08:15 AM
05/14/19 08:15 AM
an8sec70cuda Offline
It does sound like a converter bolt issue. I always coat mine in red Loctite and try to let em cure overnight before firing the motor. That and I only use the ARP converter bolts after having issues w/ the piece of crap MP bolts that would stay tight no matter what I did.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: For Genius's only. Smarter than me. [Re: an8sec70cuda] #2655410
05/14/19 03:55 PM
05/14/19 03:55 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
I am betting the converter bolt is sandwiched inside the top freeze out plug on the engine.
Re: For Genius's only. Smarter than me. [Re: merpar] #2655428
05/14/19 04:45 PM
05/14/19 04:45 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
You know you have a nephew that can come give you a hand. up
Page 1 of 3 1 2 3
