70 E-body rear shock coilover options
#2654927
05/13/19 10:53 AM
05/13/19 10:53 AM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Hey Gang. Have a friend with a 70 Convertible Challenger. He currently has air shocks to raise the rear slightly for tire clearance. The shocks assembly has developed a leak and therefore, we were looking into the possibility of rollovers rear shocks that are adjustable. Any suggestions?
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
Re: 70 E-body rear shock coilover options
[Re: hemi68charger]
#2654977
05/13/19 01:49 PM
05/13/19 01:49 PM
Posts: 43,243 Bend,OR USA
Cab_Burge
Are you wanting to convert the rear suspension to ladder bars or four link to eliminate the leaf springs or are you wanting to add additional weight carrying coil over H.D. shocks only?
[Re: Cab_Burge]
#2655116
05/13/19 07:44 PM
05/13/19 07:44 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
Shocks are not supposed to carry the weight of the car on a Mopar. If you are not satisfied with the ride height, do not resort to coil over shocks.
Change the leaf springs or have them rearched.
[Re: Magnum]
#2655180
05/13/19 10:10 PM
05/13/19 10:10 PM
hemi68charger
Houston, Tx
Change the leaf springs or have them rearched. Yes, I realize that.. But, he doesn't wanna go to that extreme. In the same spirit as the air shocks assisting, coil overs could too..
[Re: hemi68charger]
#2655221
05/14/19 12:27 AM
05/14/19 12:27 AM
Posts: 21,837 Kirkland, Washington
Pacnorthcuda
Change the leaf springs or have them rearched. Yes, I realize that.. But, he doesn't wanna go to that extreme. In the same spirit as the air shocks assisting, coil overs could too.. And that will put FAR more stress on the upper shock mounts than they were designed for. It’s not a good idea.
[Re: 540challenger]
#2655281
05/14/19 10:04 AM
05/14/19 10:04 AM
Posts: 2,867 Pattison Texas
CSK
Pattison Texas
Air shocks are fine as long as you dont air them up enough to clear N50 15 tires LOL, I run them on my Charger 45 psi, they work great, get the monroe brand, they dont get ruined if the air psi gets low, other brands get seal damage when run with low or no air psi.
