Cruise Control Cable Length #2654765
05/12/19 09:18 PM
05/12/19 09:18 PM
Minnesota
RROD Offline OP
RROD  Offline OP
Minnesota
Do anyone know the lengths of the various throttle cruise control cables which connects the servo to the carburetor. This is for a 70 Challenger with a big block. The cable I need is P/N 3462371 which I was told is 36 inches in length. I have not been able to find that particular cable but have seen cable 3462369 which is for a 70 Coronet or Satellite body with a 318 on eBay. Can that cable or other cables be modified for what I need?
Re: Cruise Control Cable Length [Re: RROD] #2654950
05/13/19 12:18 PM
05/13/19 12:18 PM
NY
twodoorpost Offline
twodoorpost  Offline
NY
My records show that the 3462369 is 41", but I did not measure this one myself. I found the info on the internet. The 3462371 I measured myself at 36".
Re: Cruise Control Cable Length [Re: twodoorpost] #2655115
05/13/19 07:43 PM
05/13/19 07:43 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
The 70 barracuda 318 speed control cable.... If you can't find the exact measurement go longer not shorter you might bind the cable.. twocents
Re: Cruise Control Cable Length [Re: twodoorpost] #2655118
05/13/19 07:50 PM
05/13/19 07:50 PM
Harrisburg, Pa.
Harrisburg, Pa.
My question would be just how is the official measurement taken ??? Fully closed or fully extended ??? Here's another pic showing the travel of the cable...
Re: Cruise Control Cable Length [Re: screamindriver] #2655520
05/14/19 08:48 PM
05/14/19 08:48 PM
Minnesota
RROD Offline OP
RROD  Offline OP
Minnesota
These cables are hard to find. A few are on eBay but have not run across one for a big block ebody.
