aluminum block repair #2654350
05/11/19 02:24 PM
05/11/19 02:24 PM
Missouri
jwb123 Offline OP
jwb123  Offline OP
Missouri
I had some bad luck this weekend, broke a rod and windowed my world products wedge aluminum block. Have not got it out yet, but about a 6 inch square hole in one side. I live in mid Missouri about 80 miles east of St. Louis, do you guys know any good shops that could repair that kind of damage in the area? I know some decent welders in my area but don't know if I want them welding on my block when they have never repaired an engine block. I worry about excessive heat warping it and making it more difficult for the final machining. Funny but it looks like the big end stayed on the crank, because it never lost oil pressure just started vibrating, I expected to see a u-joint bad, until I saw oil dripping out of the blanket. Engine still spins with the starter, and I took off a valve cover and it looks like no valves are even bent. I could not find all the pieces at the track, so they will have to fabricate a piece to fix the hole. But it was on a good run, 6.11 @ 111mph in the 1/8 and clicked it off right before the finish and it still ran 9.71 @ 127mph. So any advice or experiences in having an aluminum block fixed with damage like this, and how the repair held up would really be welcome.
Re: aluminum block repair [Re: jwb123] #2654356
05/11/19 02:41 PM
05/11/19 02:41 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
I figure that you are about 4 hours from BES (Bischoff Engine Services). You won't find anyone better.
Re: aluminum block repair [Re: markz528] #2654394
05/11/19 06:28 PM
05/11/19 06:28 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Did you find the broken piece?
Re: aluminum block repair [Re: jwb123] #2654399
05/11/19 06:49 PM
05/11/19 06:49 PM
ky
68roadrunner Offline
ky
shouldnt be a big problem if it didnt get into anything vital
just have to weld it with the correct rod
Re: aluminum block repair [Re: 68roadrunner] #2654430
05/11/19 09:36 PM
05/11/19 09:36 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
I watched the folks at Dart fixing a block years ago. Fascinating to watch.
I would not have guessed (and that's all it would have been) that you could fix it with pieces missing. Again, would be fascinating to watch.
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: aluminum block repair [Re: DynoDave] #2654473
05/12/19 12:09 AM
05/12/19 12:09 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Gather up all the parts you can and clean it all up when you find a
guy to do it give him all the parts.. he will take the bigger stuff and he
will patch in the other areas.. its not hard but its like doing a puzzle
EDIT
One other thing.. is this a dry or wet block.. a wet block is a lot harder
to do and takes a lot more time and cleaning
wave
Re: aluminum block repair [Re: jwb123] #2654484
05/12/19 01:22 AM
05/12/19 01:22 AM
Isn't Brodix the ones who made those block?
Aren't they close to you scope work
Re: aluminum block repair [Re: Cab_Burge] #2654514
05/12/19 09:08 AM
05/12/19 09:08 AM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Brodix is in Mena AR - probably more than 500 miles from St Louis.
Re: aluminum block repair [Re: jwb123] #2654521
05/12/19 09:53 AM
05/12/19 09:53 AM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
While FAR from an expert, I do know, that lower ac balance (electrode negative or EN), helps drive the impurities out of the cast material before starting the weld puddle. I practice on warranty return cores, that are contaminated with oil,atf and glycol. Find a pro, and it's not a problem. Sorry for the broken block.
Re: aluminum block repair [Re: Cab_Burge] #2654530
05/12/19 10:34 AM
05/12/19 10:34 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
He said it's a World Products block. I don't believe Brodix casts blocks for other people and if I remember correctly they only repair their own.
2011 Drag Pak Challenger
Re: aluminum block repair [Re: jwb123] #2654533
05/12/19 10:42 AM
05/12/19 10:42 AM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
I would contact Lone star aluminum block repair / Terry Haddock and see if he/ they could help you.
https://www.facebook.com/Lone-Star-Aluminum-Block-Repair-148596315157306/?hc_location=ufi
"Just a Bracket car dressed up like a streetcar"
Re: aluminum block repair [Re: Just-a-dart] #2654560
05/12/19 11:52 AM
05/12/19 11:52 AM
Washington
madscientist Offline
Washington
I've personally seen Terry's work and it's worth the shipping costs. He is like the John Marcella of block repair. And that's pretty high praise because Marcella is an artist in his own right.
Re: aluminum block repair [Re: Sammy] #2654709
05/12/19 06:43 PM
05/12/19 06:43 PM
Missouri
jwb123 Offline OP
jwb123  Offline OP
Missouri
I found a couple pieces, but not all of it. It hit really hard the diaper had a lot of small pieces imbedded in it.
Re: aluminum block repair [Re: jwb123] #2654732
05/12/19 07:38 PM
05/12/19 07:38 PM
New York
polyspheric Offline
polyspheric  Offline
New York
What did it do to the sleeve - did the remainder shift in the casting? Are there instructions to replace a sleeve? Does it have to be bored out? (sorry, all I know is motorcycle crankcase repair)
Boffin Emeritus
Re: aluminum block repair [Re: polyspheric] #2654755
05/12/19 08:40 PM
05/12/19 08:40 PM
ky
ky
it probably tore up more than one sleeve in my experiance
cut the old sleeves out with the boring bar, order new sleeves from world, clamp remaining sleeves down where they dont try to raise, heat block in oven to 300*. drop new sleeves in and clamp down letting the block cool, deck the top off the new sleeves and bore/hone to fit
dont ask how i know
Re: aluminum block repair [Re: jwb123] #2654756
05/12/19 08:42 PM
05/12/19 08:42 PM
ky
ky
the pan rail is the hardest to build, its easier if its in one piece to put back in, the 1/4 thick wall can be cut out of sheet alum.
Re: aluminum block repair [Re: 68roadrunner] #2654789
05/12/19 10:08 PM
05/12/19 10:08 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Man I hate to even mention it but isn't Indy Cylinder Head one of the big reap shops for aluminum blocks.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
