RAD FAN WIRING Q #2654086
05/10/19 05:09 PM
05/10/19 05:09 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
Wiring up an electric fan with relay and connected all the wires except for the "yellow" which calls for connecting to ignition. I like to run my fan whenever I want. What do I do with the "yellow"?
Re: RAD FAN WIRING Q [Re: A/MP] #2654088
05/10/19 05:11 PM
05/10/19 05:11 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Run it through a toggle switch if that is the one that activates the fans.
68 Barracuda Formula S 340
Re: RAD FAN WIRING Q [Re: Bad340fish] #2654094
05/10/19 05:37 PM
05/10/19 05:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yep then to a power source from the switch
EDIT
Is this for a race car or street/strip.. I have my race car this way but
I have a thermo relay on my street rod
wave
Re: RAD FAN WIRING Q [Re: MR_P_BODY] #2654102
05/10/19 06:15 PM
05/10/19 06:15 PM
Fredericksburg Va
P
plycuda Offline
plycuda  Offline
P
Fredericksburg Va
depends on how the relay is wired. I have some relays that the yellow wire is the output. my other relays the yellow is the trigger. if its the trigger than hook it to the toggle switch
