Fixing Stretched Lug Nut Holes #2652981
05/07/19 12:26 PM
05/07/19 12:26 PM
MD
floyd Offline OP
floyd  Offline OP
MD
I have some rims
with warpage at the lug holes. Any homemade options for improving/fixing?
Re: Fixing Stretched Lug Nut Holes [Re: floyd] #2653001
05/07/19 01:21 PM
05/07/19 01:21 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
oversize lug nuts are available. Google is your friend beer
Re: Fixing Stretched Lug Nut Holes [Re: floyd] #2653135
05/07/19 07:12 PM
05/07/19 07:12 PM
When in doubt, throw them rascals out twocents work
Ford lug nuts are bigger O.D.on the socket size, maybe they have more contact to the tapered seats on the wheels also scope
Stay safe thumbs
Re: Fixing Stretched Lug Nut Holes [Re: Cab_Burge] #2653136
05/07/19 07:19 PM
05/07/19 07:19 PM
tennessee,usa
mattsmopars Offline
mattsmopars  Offline
tennessee,usa
Check with Resto Rick, I had him repair a lug nut hole on and H wheel for me once. I also have a 68 JK wheel I may send him.
Matt
Re: Fixing Stretched Lug Nut Holes [Re: floyd] #2653243
05/08/19 01:35 AM
05/08/19 01:35 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Maybe an arbor press & some flat steel plates. A metal plug type like in the shape of those round magnets found on stereo speakers.
Re: Fixing Stretched Lug Nut Holes [Re: PhillyRag] #2653504
05/08/19 08:06 PM
05/08/19 08:06 PM
MD
floyd Offline OP
floyd  Offline OP
MD
Tried this today with a breaker bar. Got pretty good results, but a ton of work. Haven’t tried heat yet but that’s next.
B2DA337C-0C64-42FC-A835-2EF2C28EDA19.jpeg917013F2-D139-494E-AD24-DFBFA80E2D04.jpegB2FC6300-555F-4ACD-AC73-37570951D7C2.jpeg
Re: Fixing Stretched Lug Nut Holes [Re: floyd] #2653573
05/09/19 03:13 AM
05/09/19 03:13 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Nice alternative to a press. Maybe just "massage" them down with a hammer/dolly
Re: Fixing Stretched Lug Nut Holes [Re: floyd] #2653666
05/09/19 10:25 AM
05/09/19 10:25 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Those rims need to be repaired properly or trashed IMO. The metal around the holes is displaced and fatigued and will return to that state once a lug nut is torqued to spec. I would not use them for anything more than a roller to move a car. twocents beer
Re: Fixing Stretched Lug Nut Holes [Re: PhillyRag] #2653670
05/09/19 10:35 AM
05/09/19 10:35 AM
moparx Offline
Buying your homeless and unwanted bolt on battery terminals
moparx  Offline
after you fix the holes, use the newer style "bulge" nuts. available in chrome or zinc [?] plated steel. another tip to prevent your problem from reoccurring, is to find a washer with a 1/2" through hole that is slightly thinner than the seating ridges, grind the sides to fit the recess area, then tack weld into place. the washer will prevent the "pull through", and the "bulge" nuts will spread the load over a larger area of the wheel taper.
just be sure the washers and weld tacks are BELOW the mounting surfaces of the wheel[s]. i have done this on a few wheels with great success.
beer
