Factory Stamped Rocker Arms? #2652678
05/06/19 04:50 PM
05/06/19 04:50 PM
New York
rarefish Offline OP
rarefish  Offline OP
New York
I have a bunch of loose stamped rocker arms. What is a quick way to ID the small block rocker arms from the big block ones?
Re: Factory Stamped Rocker Arms? [Re: rarefish] #2652679
05/06/19 04:52 PM
05/06/19 04:52 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
BB have L and R pushrod seat offsets; SB are centered, IIRC
Re: Factory Stamped Rocker Arms? [Re: BradH] #2652681
05/06/19 05:03 PM
05/06/19 05:03 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
They both have an L and an R rocker.
the number stamped on them is usually that last two of the part number but I'll be danged if I remember the numbers anymore.
Don't be the exception.
Re: Factory Stamped Rocker Arms? [Re: Supercuda] #2652697
05/06/19 05:52 PM
05/06/19 05:52 PM
SB: the OE ones have a pronounced L/R offset but I have some replacement SB ones from the dealer & the pushrod round recesses look "almost" centered (I was expecting the offset) & no numbers just a "X" on the horizontle oil deflector tab on the top side above the pushrod oil hole. Pedestal slot is a weak 7/8" long/strong 5/8" wide.
Re: Factory Stamped Rocker Arms? [Re: RapidRobert] #2652700
05/06/19 05:55 PM
05/06/19 05:55 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Pretty sure you are either talking about magnum rockers or speaking chevy
LA rockers don't have a slot. Or an oil deflector tab.
I assume he's talking about LA rockers because if they were magnum rockers it'd be real obvious.
Re: Factory Stamped Rocker Arms? [Re: Supercuda] #2652702
05/06/19 05:56 PM
05/06/19 05:56 PM
You are correct brother, magnums. Too much going on upstairs! (too many projects).
Re: Factory Stamped Rocker Arms? [Re: Supercuda] #2652703
05/06/19 05:57 PM
05/06/19 05:57 PM
md
mopars4ever Offline
mopars4ever  Offline
md
3418424 and 3418425 were the mopar part numbers for small block 340 360 70-78 and later 318 maybe other years too. not sure of the stamped number Edit: one on ebay had 210RT on it if that helps. Any numbers on yours??
Re: Factory Stamped Rocker Arms? [Re: mopars4ever] #2652707
05/06/19 06:13 PM
05/06/19 06:13 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
As are 3004716 and 3004717,
2536145 and 2536146
4095708 and 4095709
4100774 and 4100775
depending on the year. Probably a couple others too.
Re: Factory Stamped Rocker Arms? [Re: Supercuda] #2652857
05/07/19 08:21 AM
05/07/19 08:21 AM
New York
rarefish Offline OP
rarefish  Offline OP
New York
I had believed that the B/RB rockers were a little longer than the SB rocker arms. Can anyone confirm that there is a length difference between the two?
The ones that I have look at so far are stamped F2RT and F5LT and a few have a stamped triangle with a P in the middle.
Re: Factory Stamped Rocker Arms? [Re: rarefish] #2652871
05/07/19 08:59 AM
05/07/19 08:59 AM
Leucadia, Ca.
V
vdriver Offline
vdriver  Offline
V
Leucadia, Ca.
Small block roughly 3.03"; big block 3.3".
Re: Factory Stamped Rocker Arms? [Re: vdriver] #2654538
05/12/19 10:52 AM
05/12/19 10:52 AM
New York
rarefish Offline OP
rarefish  Offline OP
New York
Thanks... I was at a friend's shop yesterday who had a set of BB rocker arms and I also read 3.3" on them.
Re: Factory Stamped Rocker Arms? [Re: rarefish] #2654583
05/12/19 12:34 PM
05/12/19 12:34 PM
God's Country Maryland
GODSCOUNTRY340 Offline
Small block rockers are 3 1/16" end to end and big block are 3 5/16" for those that just want to measure with a tape measure.
