Re: push rods indy ez heads
[Re: challenged448]
#2652822
05/07/19 01:15 AM
05/07/19 01:15 AM
Posts: 31,082 Oregon
AndyF
looking for a set of push rods for a rb indy ez heads with a hydraulic roller cam There is no such thing on the shelf since you need to know which rocker arms you are using as well as which lifters. Some lifters use a different cup size so you need to measure the lifter to see what size of ball is needed. Some rocker arms use a cup and some use a ball end. You also need to know if you are oiling thru the pushrod or not and you need to know the spring load and engine RPM range so you can figure out what diameter and wall thickness that you need.
[Re: AndyF]
#2652826
05/07/19 02:48 AM
05/07/19 02:48 AM
Posts: 43,315 Bend,OR USA
Cab_Burge
looking for a set of push rods for a rb indy ez heads with a hydraulic roller cam There is no such thing on the shelf since you need to know which rocker arms you are using as well as which lifters. Some lifters use a different cup size so you need to measure the lifter to see what size of ball is needed. Some rocker arms use a cup and some use a ball end. You also need to know if you are oiling thru the pushrod or not and you need to know the spring load and engine RPM range so you can figure out what diameter and wall thickness that you need. Andy pointed out all of the information needed to get you the correct ones for your motor
[Re: challenged448]
#2652869
05/07/19 08:56 AM
05/07/19 08:56 AM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
Make sure the intake pushrods don't have interference with the heads. I had to have mine clearanced on the outside of the intake port casting.
Manton can sell you some checking pushrods. Put them in, adjust them and send it back to them . They will make you a nice set.
Be careful not to float the valves in the motor. Mine floated at 5700 rpm and resulted in some nasty valve train harmonics that ate up some valve train parts. I ended up going solid roller, so I could run more spring pressure. Do you know what seat pressure they set your heads up with?.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
