MSD 8950 Switch to trigger Dedenbear AS1 cylinder #2652572
05/06/19 11:52 AM
05/06/19 11:52 AM
S.E. Michigan
cl440 Offline OP
cl440  Offline OP
S.E. Michigan
According to Dedenbear the AS1 solenoid on my air shifter draws "about" 1.5 amps.
Do I need to wire a relay with the RPM Switch to trigger the AS1 solenoid?
Also looks like (Unless I am reading it wrong) the 8950 works by grounding the circuit at the desired RPM. So I assume I need full power to the solenoid and the switch creates a ground to trigger correct?
Anyone using the 8950 Switch to trigger there air shifter?
Re: MSD 8950 Switch to trigger Dedenbear AS1 cylinder [Re: cl440] #2652612
05/06/19 01:17 PM
05/06/19 01:17 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Used one for years on 2 different shifters. Works fine. It does switch ground on either the yellow or gray wire. Yellow is normally open, gray is normally closed. A shifter solenoid will typically use the yellow wire to provide ground at the set RPM necessitating the solenoid to have one wire hot with the other being the switched ground. Never used a relay, never saw the need just to run that little solenoid for a split second.
Use a playback tach or data recorder to verify the shift point. MSD chips aren't perfect, electronics lag, shift linkage has to move and the trans has to do it's thing.
Re: MSD 8950 Switch to trigger Dedenbear AS1 cylinder [Re: CMcAllister] #2652653
05/06/19 03:15 PM
05/06/19 03:15 PM
S.E. Michigan
cl440 Offline OP
cl440  Offline OP
S.E. Michigan
I was thinking the same on the relay. It's a split second at 1.5 amps and with a glide only has to do it once per pass so the relay shouldn't be needed.
