Page 176 of 180 1 2 174 175 176 177 178 179 180
Re: Real world weight loss program and it` cost.......... [Re: ZIPPY] #2652443
05/06/19 12:56 AM
05/06/19 12:56 AM
Martinsville, IN
cdwmotorsports Offline
Martinsville, IN
Originally Posted by ZIPPY
A tale of two hemi intakes.
(The one I'd expect to be heavier, isn't)
Who would’ve thunk that. I am actually quite surprised. I am also post #3500 in this thread.
eBay-cdwmotorsports
Re: Real world weight loss program and it` cost.......... [Re: ZIPPY] #2652496
05/06/19 09:23 AM
05/06/19 09:23 AM
Get-X Offline
Get-X  Offline
I remember when Barton first came out with his hemi single plane, single carb manifold I couldn't believe how heavy it was. It was left with a lot of material that could be removed for porting which was part of the reason it weighed so much I guess.
'65 Belvedere
'68 GTX
'57 Dodge pickup
Re: Real world weight loss program and it` cost.......... [Re: Get-X] #2653574
05/09/19 04:22 AM
05/09/19 04:22 AM
TN
1DGEMAN Offline
1DGEMAN  Offline
TN
Idon't know if this has ever been covered before but is it possible to have an air cleaner base plate stamped out of aluminum? I have a fiberglass version of the 340 6 pack air cleaner base and cover. It is terrible quality warped and doesn't fit well. I was thinking if a person could find the company stamping out the reproduction air cleaners, Maybe they could do some aluminum ones? Thoughts anyone? I would think there would be a small market for these. Thinking of all the six pack Stock and Super Stock cars running TA hoods.
Thanks, Rod
Real Men shift for themselves
Re: Real world weight loss program and it` cost.......... [Re: 1DGEMAN] #2653581
05/09/19 06:30 AM
05/09/19 06:30 AM
fullmetaljacket Offline
Not sure if an aluminum version of the stock TA 6ix pack cleaners has ever been made, but there is certainly aftermarket low drop profile versions available. I have one on my car for years. Very lightweight and allows for a 14" X 4" high element to be seated.
Perhaps an aluminum lower aftermarket base can be adapted and mated with a stock top base to be some what semi-lightweight and trick.
Re: Real world weight loss program and it` cost.......... [Re: RMCHRGR] #2653615
05/09/19 09:36 AM
05/09/19 09:36 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Originally Posted by RMCHRGR
Originally Posted by JERICOGTX
The finished result.
Hmmmm.... work
According to that picture.......I see several things that could be done! Those support rods could be fabbed out of aluminum unless your FMJ ,,,,,,they would be TITanium whistling
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Real world weight loss program and it` cost.......... [Re: hemi-itis] #2653619
05/09/19 09:41 AM
05/09/19 09:41 AM
No they would be Titaluminum.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #2653626
05/09/19 09:47 AM
05/09/19 09:47 AM
hemi-itis Offline
hemi-itis  Offline
haha
Re: Real world weight loss program and it` cost.......... [Re: hemi-itis] #2653628
05/09/19 09:51 AM
05/09/19 09:51 AM
Actually aluminum would be lighter than titanium, though not stronger.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #2653645
05/09/19 10:43 AM
05/09/19 10:43 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
That rod does absolutely nothing, and can be eliminated.
69 GTX 68 Road Runner
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #2653687
05/09/19 12:28 PM
05/09/19 12:28 PM
TN
1DGEMAN Offline
1DGEMAN  Offline
TN
Who makes it?
Re: Real world weight loss program and it` cost.......... [Re: JERICOGTX] #2653712
05/09/19 01:56 PM
05/09/19 01:56 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
There is actually one thing it does quite well - get in the way!
Not sure how much weight loss I'm going to get into with my Coronet. In fact, it may end up weighing more than it does now since there are some heavier-duty parts going in like a Dana and floor contoured frame connectors. So far the radio is out and not going back in but the climate controls are staying. Ditched the bench seat for factory buckets but that may be a wash for weight, OE buckets are heavy when fully dressed with headrests and the factory floor reinforcement plates. A floor shift column is slightly lighter than a column shift unit. Have a Borgeson steering box ready to go in, that will shed a few pounds up front. If I can't find a bulge hood for under a million dollars I'll get a 'glass one, that will cut a bunch. Putting in a console too. When I get around to finishing the new motor, it'll have aluminum heads so that's a a few lbs there.
No idea what it weighs now but it's a low option, bench seat hardtop with a 383 4bbl, column shifted 727 and an 8.75 so maybe 3,700lbs?
'71 Duster
'72 Challenger
'17 Ram 1500
Re: Real world weight loss program and it` cost.......... [Re: RMCHRGR] #2653797
05/09/19 06:51 PM
05/09/19 06:51 PM
Pardon guys, but I don't agree with "that bracket does absolutely nothing" as it seems to be a support for the main steering column harness/cubby. I had about three or four of those also, but made them out of aluminum and since have been just as sturdy as the steel units. I can post pictures later if y'all need to have a look.
A steering column will tend to be leverage weight and needs support of course. Though in all realness, these mid term B-bodies and their parts are strange to me compared to early B's
Re: Real world weight loss program and it` cost.......... [Re: 1DGEMAN] #2653798
05/09/19 06:57 PM
05/09/19 06:57 PM
1DGEMAN
I made them myself by using solid round stock aluminum and mashing the ends flat and finish sanding to remove all burs and stress residue.
I'll have to post to relive the creation.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #2653816
05/09/19 07:35 PM
05/09/19 07:35 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
I have made struts from steel tubing with ends flattened. They even pass muster when checked with a magnet. rolleyes
Re: Real world weight loss program and it` cost.......... [Re: John Brown] #2653818
05/09/19 07:38 PM
05/09/19 07:38 PM
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #2653832
05/09/19 08:29 PM
05/09/19 08:29 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Not suspension struts, just struts that keep the corners of Nova fenders from vibrating. Made them out of brake line tubing. I may be a cheater, but I'm not stoopit.
Re: Real world weight loss program and it` cost.......... [Re: John Brown] #2653834
05/09/19 08:37 PM
05/09/19 08:37 PM
Gotcha.
Cheat neat and it all looks legit.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #2653875
05/09/19 11:23 PM
05/09/19 11:23 PM
hemi-itis Offline
hemi-itis  Offline
Lee La Lane,,,you know how those stock appearing guys are.......... work sawzall
Re: Real world weight loss program and it` cost.......... [Re: hemi-itis] #2653966
05/10/19 10:19 AM
05/10/19 10:19 AM
moparx Offline
moparx  Offline
Lee LaLane, that he is ! laugh2
beer
Re: Real world weight loss program and it` cost.......... [Re: moparx] #2653996
05/10/19 11:28 AM
05/10/19 11:28 AM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
beer
Stock appearing.
'71 Duster
'72 Challenger
'17 Ram 1500
